11-28-2010, 04:06 AM | #1 |
weird..high pitched noise
alright, so a 2 days ago my car started making this high pitched noise.
almost sounds like a semi truck. so i figured the alternator was going bad. my lights would go bright whenever i revved my car etc.. at first it wasn't to bad, it would only get really loud when i got to the higher rpms. then it started doing it right when i would turn on the car. would do it for a few seconds then just go down, but continue to do it at high speeds. so i went and switched out the alternator(the pulley on the old one seemed to be super loose) started up fine and everything..but when i drove away the noise comes back at around 2500, the same semi truck sound noise i was mention, then at about 3500, it gets really high pitched. i dunno wtf it is..thought it was the alternator for sure. its quite aggravating. could it be one of the pulleys or anything? thanks in advanced |
11-30-2010, 06:54 AM | #4 |
dont listen to that retard
Post Video
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
11-30-2010, 07:48 AM | #5 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
Have you inspected your belts?
My dad's old Nissan Pickup used to do this. It was caused by old/worn belts. Swap them out. They're cheap and easy to replace. That should fix your problem. |
11-30-2010, 03:31 PM | #6 |
ill try to get a video of the sound. hopefully u guys can make the sound out, cause it gets really at 3500 rpms, so hopefully the high pitched sound doesnt get too drowned out.
i actually only inspected the alternator belt, and it looked in pretty good condition still. didnt inspect the other belts tho. i figured the alternator belt was the one being lame, since changing the alternator somewhat helped out with the problem. ill check em tho. |
01-17-2011, 05:34 PM | #7 |
alright. super late, i know. but i finally changed the belts. the noise would end up going away sometimes and then it would come back -.-;
so now, the car sounds a lot better. i had gotten to a point where the car would make the high pitched noise when i would start the car on cold days. i would rev it a couple of times to make it go away. so i changed all the belts, and the car stopped making the sound. only prob is that it would make it when i would rev the car to 4500(was testing it) so we tightened up the belts a little bit cus we left one a little loose, and now it makes the noise at 3000 rpms. do i just gotta mess with the belts and find the right tension to tighten them at or what? thanks in advanced (oh yeah, when i removed the belts, one of em looked really worn down) Last edited by XxHybridx; 01-17-2011 at 05:36 PM.. Reason: . |
01-18-2011, 01:53 PM | #8 |
Look at this video, if this is the problem, replace clucth fan. and DONE!
YouTube - KA screach noise |
04-19-2012, 10:20 AM | #12 | |
Here: Let me google that for you How hard was that?
