Old 05-02-2012, 11:21 AM   #1
jlawdet
jlawdet is an unknown quantity at this point
SR blow-thru set up S13 SR
Got a new blow thru set up and have a couple questions
1. What mods do you have to do the stock MAF so it doesnt leak
2. What advantages have ppl seen since doing it aka better throttle response, fuel mileage or power? and yes im running my BOV atmospheric
Searched for awhile didnt seem to find direct answers to my questions
Thanks guys
jlawdet is offline   Reply With Quote
Old 05-02-2012, 11:33 AM   #2
Matej
Curious about doing this with the stock MAF as well. Just so I can run the turbo open.
If the boost and MAF are kept stock, would going blow-through be plug-and-play, or is tuning still required?
I think the MAF should be fine up to 15psi or so, if I recall correctly.
Old 05-02-2012, 11:42 AM   #3
jlawdet
no tuning that im aware of on a stock maf. Only z32 or a mistu maf or something. But i dont have the money for a dejetro or i would just go full standalone. But as long as the stock MAF wont leak cause then the shit just wont run plus im pretty sure that will ruin the MAF too
Old 05-02-2012, 02:29 PM   #4
jlawdet
Nobody knows anything or can point me in a direction?
Old 05-02-2012, 02:36 PM   #5
Om1kron
Om1kron's Avatar
you can't run blow through on a stock SR. that is the short and simple answer. you need engine management and a map setup. PERIOD, I will not go into specifics nor do I need to. The engine was designed to run a certain way, if you want it to run opposite of the way it was designed you should be able to do the research on what is needed to accomplish such.
I'll give you a hint, you need engine management and a map setup as stated somewhere earlier in the thread... oh wait the beginning of my response.
Thanks and have a good day
/thread.
Wayne
Old 05-02-2012, 02:48 PM   #6
jlawdet
right dude cause its hasnt been done a million times lol with great results. Didnt ask for attitude just guidence. Dont have the money for a d-jet hence my solution by doing a blow thru.
Old 05-02-2012, 02:50 PM   #7
Om1kron
Om1kron's Avatar
Great, so because it's been done million's of times you lied about searching and you have all of the info you need. Thanks for clearing that up for me.
Wayne
Old 05-02-2012, 02:57 PM   #8
G5SR20240
G5SR20240 is an unknown quantity at this point
better to run a speed density setup
G5SR20240 is offline   Reply With Quote
Old 05-02-2012, 03:11 PM   #9
jlawdet
Talking
You need to read lol i said i couldnt find any specific answers to my concerns such as the maf needing to be glued or silicone etc.....so i didnt lie about anything lol i used the forum as it was intended ........searched couldnt find so i posted......HATER!!
Old 05-02-2012, 04:48 PM   #10
Kingtal0n
Kingtal0n's Avatar
Do not try to run a blow-through setup on an SR20DET
Old 05-02-2012, 04:51 PM   #11
jubee
jubee is an unknown quantity at this point
just ignore the blow hards bro!!
basically i have seen a couple sr guys try and run a blow through setup but the prob is when you start seeing boost the maf pops off from the intercooler pipe. Now you ask, how about I just tighten the clamps down more? you then realize after tightening it down so much that you then break your maf =(.
this has pretty much happen to everyone i know that has attempted a blow through setup.
I think the only real advantage to doing it has been to be able to run your BOV to atmosphere, and you can just put a screen or just stick a filter right on the turbo.
IMO its pointless, but i hope i kinda answered your question.
jubee is offline   Reply With Quote
Old 05-02-2012, 05:10 PM   #12
boosted KA24DE
boosted KA24DE's Avatar
boosted KA24DE is an unknown quantity at this point
You need to read lol i said i couldnt find any specific answers to my concerns such as the maf needing to be glued or silicone etc.....so i didnt lie about anything lol i used the forum as it was intended ........searched couldn't find so i posted......HATER!!
save your money and do it right the first time, save your self a huge head ache. your talking about silicone and trying to mend something that works perfectly fine being in front of the turbo. You are trying to experiment with something you have no apparent knowledge of so leave it alone. please choose function over looks for your setup.
JDM Fashion isn't always good!
boosted KA24DE is offline   Reply With Quote
Old 05-02-2012, 07:03 PM   #13
Matej
All the research up to this point has led me to believe the opposite.
Why would it not work?
Old 05-02-2012, 07:09 PM   #14
Om1kron
Om1kron's Avatar
So what is the main issue with using a blow-through setup? The MAF popping off?
I could see that being a problem with the plastic MAF's such as the Z32, but if I were to use the stock S13 MAF I think it could be easily amended.
The regular maf itself receives air before the turbo, no pressure runs through it therefore there isn't 7-10lbs of air pressing against those little resistors that tell your ecu how much fuel and timing and yada ya your car needs.
take your maf off of your car, and give it about 5 lbs of pressure with your finger and then let me know if it still works when you put it back on your intake. (and I'm talking about the electric part that is held in by two screws)
I sometimes wonder if you guys try to use your brains before worrying about having a cool open mouth turbo on a stock setup LOL!
Wayne
Old 05-02-2012, 07:15 PM   #15
boosted KA24DE
hesitation on closed throttle and the idle is somewhat rough. all things that lead to tuning issues which he is trying to avoid so why create a headache he is trying to avoid in the first place by tuning. its a catch 22. besides cracking under boost, possible premature heat soaking of maf if turbo running hot and maf is on hot side leading to maf reading being way off. Anyone trying to do this with out proper tuning is just asking for trouble. take a hint and don't encourage this if you wouldn't do it on your own car. just because joe shmoe did it and it was fine doesn't mean it will work for you. too many variables to go wrong and screw your car up
Old 05-02-2012, 07:39 PM   #16
Matej
It was to be for a tucked engine. I thought I could get rid of the extra piping and filter.
I suppose if it will not work with the stock ECU then I will not do it.
Old 05-03-2012, 05:57 AM   #17
jlawdet
Its not for looks bro lol its so i dont have the surge cause of my bov and my engine bay is tubbed so putting my MAF on the opposite side would save alot of head aches for my since i will have a clutch fan and a shroud. Ill keep doing my research and see what i can do. Im not one to give up because one or two ppl say no or not to do it.
Old 05-03-2012, 12:06 PM   #18
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
I'm tubbed, I use stock fan and shroud, with a bigger z32 maf, fits fine. If you really want your shit to stop stalling, recirculate your BOV.
di-devol is offline   Reply With Quote
Old 05-03-2012, 12:36 PM   #19
hobbs
Trader Rating: (43)
hobbs is on a distinguished road
Feedback Score: 43 reviews
Wow...some people are clueless.
Z32 MAFs are a hot wire setup, do some research before you blab on and on about how it can't take boost. Running a Z32 MAF blow though is fine, you will run into issues with popping the glued on cap of the Z32 MAF. FWD SR20 guys have made a billet weld-on Z32 MAF housing, looks like this:
The cap is held on by allen bolts and with gasket holds pressure you're fine. Be sure to have a good catch can setup, if you have oil in your intake tract it will fuck with your MAF.
hobbs is offline   Reply With Quote
Old 05-03-2012, 12:43 PM   #20
pacotaco345
pacotaco345's Avatar
If you want cool turbo noises just don't run a bov... You can still use a conventional maf setup and your car won't stall. Just do it with cheap ass t25s tho where you can afford to go through a turbo a year.
Old 05-03-2012, 12:58 PM   #21
bussitcustoms
bussitcustoms is an unknown quantity at this point
Sounds like youre just looking for an excuse to sound superior, and flex your badass Internet muscles. If you don't know what you're talking about, or don't have anything nice to say, keep it to yourself. Blow through setups on SR's have been done successfully, without a standalone ecu. My tuner (who does MOSTLY rom tunes) has done a few of them.
bussitcustoms is offline   Reply With Quote
Old 05-03-2012, 01:52 PM   #22
Kingtal0n
Kingtal0n's Avatar
1. Let them try if they must; we are clear conscious because we warned against it.
2. Ask yourself: IS the benefit worth the time investment? What exactly is the benefit? Supposedly, you can run an atmospheric bypass...
Wait a minute, don't many people with SR20 engines run atmospheric bypass valves without recirculating them already? Are these cars special or magical? Is the ECU really dumping fuel into their engines when they shift?
A fact for your consideration:
When you lift your foot from the pedal, such as during a shift, the ECU goes into a FUEL CUT mode, where NO fuel is being injected. So DESPITE the fact your bypass may be atmospheric... the ECU does not even notice!
SO WHY DOES IT MATTER THEN?
Ok, the meat and potatoes. The ECU does not ALWAYS fuel cut at the right time, and the bypass does not ALWAYS open or close when it should be. There are situations, that depend both on the MAF location, Bypass location, bypass manufacturer, design, age, vacuum source, etc... hundreds of variables determine whether or not the ecu will be adding fuel when it should NOT be adding fuel.... THOSE are the times that a recirculated bypass is important, THOSE are the times when it DOES ACTUALLY MATTER if you recirculate or not.
Knowing this, I offer a simple piece of personal experience:
If you desire an atmospheric bypass and/or you do NOT want to recirculate, simple buy an AUTHENTIC HKS SSQV and stick it on the hot pipe. That particular bypass valve has been PROVEN to remain shut when it needs to be shut, and offers the atmospheric quality you desire without the necessity of recirculation. the ONLY drawback is that the HKS SSQV is a "tight" bypass, your turbocharger will still experience surge, which is not a good thing. But HAVING the bypass that serves SOME purpose is better than NOT having a bypass at all.
So to recap:
1. Recirculate if at all possible, using a push type bypass, such as Greddy Type-S, set to its weakest setting.
2. If fail recirculate, run an authentic HKS SSQV on the HOT PIPE with a dedicated vacuum source.
Old 05-03-2012, 04:11 PM   #23
jlawdet
Talking
busssssssss lol
Old 05-04-2012, 09:43 PM   #24
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
I'm doing it on my current KA24DE-T Project. I'm part DSM guy and we do blow thru setups all the time running GM sensors and MAFT. You do need to do your homework and weight your PROs and CONs if you're just running a basic to mild setup then this may not necessarily be worth of a mod at all.
- Stock S13 SR ECU running Nistune or Tunercode
- Wired GM LSx Coilpacks for Ignition
- Ford Lightning 90mm MAF Sensor
- VMP Weld on flange on the IC piping.
Things to consider for blow thru setup.
- Type of MAF you want to run. Seen some FD Cars actually rock blow thru with FORD Cobra MAF.
- Retuning will be involve regardless if you remain stock maf or upgrade. You will be running a bit lean if you just do a plain convert.
- MAF Placement is also critical they're some general rule which place it few inces away from the TB and a bend.
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
Old 05-09-2012, 09:43 AM   #25
blundar
blundar is an unknown quantity at this point
I've run several blow-though setups on Nissans with great success... Then again, I'm a tuner and I'm not afraid of tuning a MAF transfer function/VQ curve. With that said, I think a *modern* blow-through setup (like what GroundPerformance is advocating above) is pure awesomeness. I've dealt with them countless times in the domestic world and they performed flawlessly. They continue to do so on Nissans. As long as you can keep the sensor element clean, they provide more consistent behavior across different conditions, weather, etc. than just about anything including a MAP based system.
Oh yeah, modern Hitachi meters seem to do the best with blow through. These are generally the "slot-style" meters that screw into a flange. Examples: 05-10 Mustang, HPX, Pro-M slot style, OEM 350Z to name a few. As long as it has VOLTAGE output not FREQUENCY output, it should be at least usable. Older MAF elements seem to fare less well. I'm not sure why.
One thing though - YOU CANNOT ACHIEVE SUCCESS WITH A BLOW THROUGH MAF SETUP WITHOUT EXTENSIVE TUNING. Blow through completely changes how a meter reads - you might as well have put a different meter on the car. Even if I had tuned a car with the exact same meter in the exact same diameter pipe I wouldn't call a mail-order tune for a blow-through setup more than a "basemap" because of how sensitive the sensors are to orientation and other minute differences. Blow through makes the meter *EXTREMELY* sensitive to orientation because of the difference in air speed at various parts of the pipe. This is particularly true close to bends or angles. Bottom line: you will need a CUSTOM tune to run a blow through setup effectively. Virgin stock ECUs will not do it - you will need at a minimum a ROM board and a custom tune.
I've run:
-HPX Meter Blow through MAF 3.5" Charge pipes RB26 on R32 ECU (looks to be able to read ~1000-1200hp, 720hp and counting so far)
-Z32 MAF blow through stock housing on RB20 with RB20 ECU (looks to be able to read about 375-400hp, ~340hp so far)
-HPX meter blow through MAF 3" Charget pipes with Nismotronic NEMU setup (basemapped, still needs fully tuned)
-Stock 05 Mustang meter with voltage diviider in 2.75" pipes Nismotronic NEMU setup (basemapped, still needs tuned)
blundar is offline   Reply With Quote
Old 05-09-2012, 10:16 AM   #26
Sterlz
Sterlz's Avatar
Sterlz is an unknown quantity at this point
If thats your only reason for doing it, then why don't you just recirculate your BOV? Get a bung get it welded get some hose call it a day....you wouldn't run the risk of messing something up.
http://sterlz.wordpress.com/
Sterlz is offline   Reply With Quote
Old 05-09-2012, 02:01 PM   #27
ryandriftingfat
ryandriftingfat's Avatar
ryandriftingfat is an unknown quantity at this point
Sacrificing normal engine operation for looks.
WYLD STALLYNS
http://instagram.com/ryandriftingfat
ryandriftingfat is offline   Reply With Quote
Old 05-09-2012, 02:37 PM   #28
Matej
It is just an engine. Who cares.
Old 05-09-2012, 02:47 PM   #29
bussitcustoms
Getting rid of a significant amount of piping isnt just for looks.
Old 05-09-2012, 02:48 PM   #30
ryandriftingfat
Hopefully you do. I'm sure the tow truck driver will complement your gangster blow-through setup though.
On the intake? LOL OK. If OP is worried about charge piping, go mid-mount. But this thread isn't about that.
WYLD STALLYNS
