Old 12-08-2004, 09:12 PM   #1
Ohio Drifter
Ohio Drifter is an unknown quantity at this point
FMIC x V-Mount intercooler
Hey gear-heads!
I'm trying to decide what kind of intercooler I'll install on my car. Does anyone know what are the main advantages of the V-Mount setup?
Thanks!
Ohio Drifter is offline   Reply With Quote
Old 12-08-2004, 09:21 PM   #2
Loofee95SE
Loofee95SE's Avatar
Loofee95SE is on a distinguished road
Send a message via Yahoo to Loofee95SE
well for 1 the pipping will be much shorter than the traditional Front mount setup which mean the turbo will take less time to spool-up. equal better respond. also there will be nothing in front of the radiator because of the V setup..the air are force to both the Radiator and Intercooler. which is also good.
How ever u must take the intercooler size in to consideration..as well as VENTED HOOD to let the air out after it gone thru the IC and ...misc stuff.... just my.02 C
I need more Boost!
Loofee95SE is offline   Reply With Quote
Old 12-08-2004, 09:37 PM   #3
Ohio Drifter
Thanks man!
That is exactly what I was thinking, a shorter piping route and an open way for the radiator (plus the extra intercooler protection). I have already an Invader VIS CFH and the intercooler that came with the kit that I bought (boostdesigns) is a perfect fit btw the radiator and the engine. But wouldn't the intercooler work in a higher temp due the warm air from the radiator and the overall temperature of the engine bay?
Old 12-09-2004, 12:08 AM   #4
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
it has nothing to do with the turbo spooling up. The turbo will spool up the same if you are running 1000ft of piping, you just wont feel it for 23 sec later. The reason is. The turbo can only provide so many cfm's. In other words, the longer the piping the more cubic inches (or whatever cubic measure you would like to use) there are to fill. Im sure thats what you were refering to. Also a v mount setup is very hard to have the air flow distributed equally to the radiator and the ic without some sort of splitter in the middle. Also the v mount setup will suck ass if you crash and have to spend a month waiting for custom parts to come in. Unless you are a fabricator with the ability to tig weld, cut fmic, and radiators in half.
blu808 is offline   Reply With Quote
Old 12-09-2004, 01:17 AM   #5
timmybgood
timmybgood is an unknown quantity at this point
do some searches brotha, theres mad info about v-mounts out there. unless you're going pretty hardcore with your car though...you don't need it.
1995 SE
timmybgood is offline   Reply With Quote
Old 12-09-2004, 07:20 AM   #6
Ohio Drifter
Yeah... I guess that it is too much work for nothing.
Thanks anyway guys!
Old 12-09-2004, 06:42 PM   #7
240pwrdrift
240pwrdrift is an unknown quantity at this point
Both have FMIC and V-Mount have the good and bads. It all going to depend on how much $$$ you have.
My opinion on v-mounts :
Boost lag is shorter +
Looks cool +
Custom work -
Cut out front support to fit -
Have to move radiator -
My opinion on FMIC
Boost lag is greater depending on pipe size and i/c core design -/+
Price if someone make it -/+
Look cool with the proper front end +
peace
240pwrdrift is offline   Reply With Quote
Old 12-09-2004, 06:51 PM   #8
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
If you cant weld its not worth it
wootwoot is offline   Reply With Quote
Old 12-09-2004, 07:04 PM   #9
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
Neither. You should do like some idiot on touge forums did.....
hahahahahaha
RBS14 is offline   Reply With Quote
Old 12-09-2004, 07:48 PM   #10
Ritz S14
Ritz S14's Avatar
Ritz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud of
If it had a hood scoop, it would be pretty functional. If he didn't, it's just the same as not having an intercooler.
Ritz S14 is offline   Reply With Quote
Old 12-09-2004, 08:01 PM   #11
RBS14
RBS14's Avatar
but he doesn't.
Old 12-10-2004, 12:37 AM   #12
ruthlesstyper
ruthlesstyper is an unknown quantity at this point
wow. starion intercooler. hmm. haha
ruthlesstyper is offline   Reply With Quote
