Old 01-05-2012, 12:55 AM   #61
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
First of all, great writing in this build, I can actually read everything you type without getting bored or confused.
When I saw your recirc setup I laughed and said, 'holy shit!' out loud. That is some cool shit right there man, I don't think I have ever seen anything like it before.
Keep on keepin' on, everything looks great.
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 01-05-2012, 07:17 AM   #62
s14unimog
s14unimog's Avatar
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Send a message via AIM to s14unimog
Thank ya thank ya.
Originally Posted by codyace View Post
That's a pretty slick turbo brace, and I really think that will help eliminate (or at least slow down) some of the failures with the tubular manfolds. The *only* think I could maybe suggest (and this is all on assumption) is that if you were to debate on selling them, that you would need to create a brace that could incorperate a few different 'clockings' of the compressor housing (if you know what I mean). This is where some of the rod end/turnbuckle soltuions end up working well as it self adjusts to many different setups. Not nitpicking just dropping the idea out there to ya
Either way, it's a good idea - a much needed one at that.
PS: I don't wanna hear any of the 'southeast temps' comments. It was 8 degreees last night up here
Thanks Cody! I don't intend to sell them for just that reason. There has got to be hundreds of different "bottom mount" turbo positions and equally as many boss locations and actuator mounting orientations to sift through. No thanks; lol. You are right though. Another detail that isn't that obvious in the picture is that the assembly fits there with about 0.01" interference. So as it sits it's actually just barely pushing up on the assembly. My fear was that it would be pulling on it; which might induce a premature failure.
I have to admit I'm a bit of a b*tch when it comes to cold weather but without snow, which I would be all over in the Jeep, I can't do anything with this mid 40's temperature. I would go 100% on my Jeep if I lived in temperatures like that.
Originally Posted by lazysk8er2 View Post
Im not sure if you covered this but running flex pipe with your exhaust will lower the chances of cracking the manifold.
The brace is cool btw.
Ya and I've run them before but that can be hit or miss too. I'm also running poly exhaust hangers, poly engine/trans mounts and the exhaust has no conflict issues with the chassis. I have had the car like this for quite a while without issue and its been tracked often. The failure last time was right through the center of the weld and Tomei also agreed that despite the assembly, it should not have failed like that. If this manifold does the same thing then I'll just repair it myself and continue with the addition of a flex section.
Originally Posted by sex14 View Post
this thread is full of win. btw what wheels are those? are they varsstoen?
Preciate it, I have a set of silver Rota Grids and polished/black J-Line 7SL2's; no Varrstoens
Thanks, I can feel ya on the grammar gripes that plague build threads often; it gets exhausting to try and figure out what they're sayin.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 01-05-2012, 07:54 AM   #63
onehundredoctane
onehundredoctane's Avatar
Love it when people diy and still manage to keep things simple and straight forward, not to mention CLEAN!
So the Uwharries huh? I grew up about 20 minutes from them, I hear there are some tough trails with huge rocks over there. . . never was into 4x4's but as I've gotten older I've been thinking more about it.
Old 01-06-2012, 02:03 PM   #64
s14unimog
s14unimog's Avatar
Ya man, K.I.S.S. I guess; lol. Ya man uwharrie was a riot and worth the 5+ hour drive. I'll probably go back again this year. There are plenty of places to challenge even the higher end built rigs. Shit, I almost rolled my truck twice.
Old 01-17-2012, 10:03 AM   #65
s14unimog
s14unimog's Avatar
Update - 01-17-12
HA! Screw you weather. Fortunately a 40k BTU heater and 8 gallons of propane later, I've overcome it! Cool thing about this little paint project is that it's the first of many things for me. It's the first time I've painted something indoors; which rocks! It's the first time, I got to use my new HVLP gun and its also the first time a paint project hasn't taken my efforts and smashed them to pieces. I have to tell you, painting is an incredibly rewarding part of any project. Instantly your months of hard work has been converted to a finished product. It's also one of the most frustrating things I've had to learn. In the past I've painted a hand full of things (valances, bumpers, wings, motorcycle fairings, etc...) all in all probably 15 or so different projects. Within that list, there has been equally as many headaches; if not more. This time however, not so much; thankfully.
Here's what I did.
Considering there was a good deal of new metal I prepared all of those surfaces with a 3M etch primer. As I detailed in some previous posts (I think) I capped the triangular openings at the back of the inner fenders, plug welded a bunch of the unused holes in the fenders, relocated where the engine harness passes through the firewall, capped and shortened the fronts of the frame rails, ground out all of the factory undercoating, removed the center core support/ hood latch strut and the tub work obviously. Here some pictures of that.
After some thought about what color, and how to produce the finish that would be ideal, I decided to go with something I was familiar with. I've had good success with this SEM's Hot Rod Black on a few bikes. It's tough as nails, fuel and oil resistant (to an extent) and produces the sheen that I wanted for the bay. It's also cheaper than a 2 stage with a flattening agent added to the clear. Here are a couple bikes I've done in the past.
I actually tried "dusting" this bike on the final coat to give it a flatter look.
Supplies! All of this ran about $125
Considering the new inner fender work, I opted to seam seal everything from the underside so that I could retain the stitched appearance in the bay. Here are a couple picture from that. It's a 3M paintable beige.
With all of the involved body prep done, I constructed a paint booth from 1.5mil 20x10 plastic rolls and attached it to my rafters. After about a days worth of pre-heating the body, I waited for a mid 60*F day, to boost my heating ability, and shot the paint.
Covered all of my bases, from prep & cleaning to temperatures to gun settings. Which finally brought me to that all important moment; shooting paint. For those who have not painted an engine bay before, it's not an easy target. You're constantly changing your fan pattern to get in all the nooks and crevasse; not to mention fighting the urge to paint what you must lean over to shoot the more interior features. Either the case, it's done. Fast forwarded for your viewing convenience; lol.
I've let the paint cure for a little over a week now and am now just waiting to receive my exhaust components back from ceramic coating. Should be Friday of this week. Once I have that back, I guarantee I'll have the motor back in and plumbed for good in under 6-7 hours. Now the fun begins!!!
Old 01-18-2012, 10:32 AM   #66
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
Lookin good man... I dig the "protective" cap, should've just thrown a paint suit in with all your materials. I just finished priming my bay, guide coat sanding is a lot of work. Keepin my eye on this. Good luck
My SR20VET
Old 01-20-2012, 05:17 PM   #67
s14unimog
s14unimog's Avatar
Ya.... It dawned on me AFTER I got home, so I said fuck it, I'm not washing paint out of my hair anymore.
On a side note; my exhaust parts are back from ceramic. Is this hot or is this hot?
That's one fine looking 20G if you ask me.
Unfortunately, however they forgot to ceramic coat the manifold hardware. I know it isn't necessary but I really regretted not doing it last time after I bolted the rusted OEM hardware over that pretty ceramic. Not this time.
I did however take a second and rivet in my cold air intake duct; that shit's poppin!
Old 01-20-2012, 05:44 PM   #68
sex14
sex14 is an unknown quantity at this point
awesome build man, thumbs up from a fellow zenki owner.
sex14 is offline   Reply With Quote
Old 01-20-2012, 06:02 PM   #69
homeslicej2
homeslicej2's Avatar
homeslicej2 is making a name for him/her selfhomeslicej2 is making a name for him/her self
Loving this still. I enjoy finding updates on your build. I know that's a Greddy turbo elbow, it looks like a Greddy DP too. Who did the ceramic coating? I've been thinking of having Swaintech coat all of my exhaust (to the test pipe) and hot side IC piping. Did you weld in a bung on the DP for a wideband O2 before the coating?
homeslicej2 is offline   Reply With Quote
Old 01-20-2012, 06:10 PM   #70
JaredP
JaredP is an unknown quantity at this point
looks sick man, i didnt realise in the tub thread that your bay was black (in the pics it looks like it has almost a bronze in it). all the pics answered any questions i may have had too and i cant wait to see the engine in.
ceramic coat sure is nice to deal with too, makes such a different
JaredP is offline   Reply With Quote
Old 01-20-2012, 06:33 PM   #71
s14unimog
s14unimog's Avatar
Thanks man, ya it's a GReddy dump but a Blitz downpipe. I don't use the narrow band O2 sensor so I have my wideband in the dump pipe. Classic Powder & Ceramic in Winterville GA did all of the coating. The guys do killer work and never have any of my stuff for longer than a few days. That's who powder coated all of my suspension arms.
Ya, it was probably the mixture of lighting. It's definitely very black. Thanks.
Old 01-20-2012, 11:46 PM   #72
A54
A54's Avatar
Trader Rating: (40)
A54 is an unknown quantity at this point
Feedback Score: 40 reviews
Nice Thread...
A54 is offline   Reply With Quote
Old 01-23-2012, 08:30 AM   #73
s14unimog
s14unimog's Avatar
Gettin there...
Old 01-23-2012, 09:05 AM   #74
OBEEWON
OBEEWON's Avatar
Paint is as smooth as butter on a baby's bottom.
Old 01-23-2012, 04:43 PM   #75
homeslicej2
Bay looks fantastic. Thanks for the heads up on the powdercoater, but Swaintech's ceramic exhaust coating is far beyond a simple paint or powdercoat. I'm glad Carroll's engine builders has experience with SR's and other imports with tight tolerances. Around here, all the machine shops are used to old Ford/Chevy/Dodge engines with massive tolerances (compared to imports & modern domestics that is). I wouldn't trust any of them with my little 4-banger.
Old 01-23-2012, 05:17 PM   #76
Junior x
Junior x's Avatar
Junior x is an unknown quantity at this point
dammm looks good. glwb
Originally Posted by OWTKAST cpt View Post
wow.. this is better then a victoria's secret catalog..
Junior x is offline   Reply With Quote
Old 01-23-2012, 08:01 PM   #77
s14unimog
s14unimog's Avatar
Thank gawd! I would have gone postal if I had messed that up after everything.
I hear ya. The bottom of my carbon/frp hood can attest for this stuff though. Its amazing how well it works. David over at Carroll's is a real perfectionist, not to mention a really cool dude. If you get to use him in the future you won't regret him.
Old 01-23-2012, 09:40 PM   #78
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Nice choice on the engine bay paint. Flat or Semi Matte is the only way to fly IMO...I hate when the rest of an engine bay is overly shiney.
Old 01-23-2012, 10:34 PM   #79
OnPoint
OnPoint is an unknown quantity at this point
this is so bad ass. I remember seeing that ka-t years ago.
OnPoint is offline   Reply With Quote
Old 01-24-2012, 07:42 AM   #80
s14unimog
s14unimog's Avatar
Thanks Cody, my thoughts exactly.
Nice, it cool that a bunch of people payed attention to that build. That was a different time for sure; lol.
Old 01-31-2012, 12:16 AM   #81
homeslicej2
I just noticed that from a previous post that you put your wideband O2 in the greddy turbo elbow location. I know AEM recommends placing theirs ~36inches downstream of the turbo bc the heat can damage the sensor.
Old 01-31-2012, 01:13 AM   #82
ixfxi
ixfxi's Avatar
this guy is making a lot of people on zilvia look stupid
my suggestion? take notes and pay attention
nice work
Old 01-31-2012, 07:48 AM   #83
s14unimog
s14unimog's Avatar
I run a thermal insulator which pulls the O2 slightly out of the stream. I've heard that it yields an inconsistent reading but I've logged mine in parallel to the dyno operators and seen no difference.
nice work
I appreciate that comment.
In regards to progress:
I've spent the last week or so working on the transmission and final assembly details. I'm literately waiting on my exhaust manifold hardware that was missed during ceramic coating. Its a obnoxious detail that I almost wish I skipped over but I suppose it will be worth it when assembled. Fortunately it gave me a minute to finalize all of the brake lines, rebuilding the slave, swapping transmissions, etc... So as of today, if I got the hardware back I could have it completely installed, plumbed and waiting for the wiring details. So I'll have pictures soon. I can't wait to see everything together!
Old 01-31-2012, 09:13 AM   #84
anarchyperf
anarchyperf's Avatar
anarchyperf is an unknown quantity at this point
Looking good! Look forward to seeing this all together. What engine management are you going to run?
www.anarchyperformance.com - Your source for 240sx Performance!
https://www.facebook.com/anarchyperformance - Like us on facebook
Email: [email protected]
anarchyperf is offline   Reply With Quote
Old 01-31-2012, 10:17 AM   #85
NismoTuner21
NismoTuner21's Avatar
NismoTuner21 will become famous soon enoughNismoTuner21 will become famous soon enoughNismoTuner21 will become famous soon enough
Fucking rad work man! So jealous of your tig skills and work area lol. Can't wait to see it put together and running.
NismoTuner21 is offline   Reply With Quote
Old 01-31-2012, 10:49 AM   #86
s14unimog
s14unimog's Avatar
Thanks! I'm running a Nistune system and data logging boost, EGT and A/F's through my Zeitronix.
Thanks! You and me both man....
Old 01-31-2012, 06:53 PM   #87
JohnnyDrfiter22
JohnnyDrfiter22's Avatar
JohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura about
Wow Amazing Build!!! Wanna produde more catch cans and sell them?? Also what is used to hold up the piping from the air duct
JohnnyDrfiter22 is offline   Reply With Quote
Old 02-01-2012, 07:46 AM   #88
s14unimog
s14unimog's Avatar
Thanks! There will only be a short length (~1-2') of flexible 3", wire-reinforced, hose connecting the front bumper duct to the inner fender air duct, so it won't require any support. I will also fit an inline filter towards the bumper duct to prevent debris and moisture from getting blow into the engine bay.
I would love to produce the parts but I don't have the time to fabricate this stuff. I love doing it for my car but the enthusiasm falls flat when I've got to do a bunch of them. Not to mention, people wouldn't want to pay for what I would have to ask to make it worth my time.
Old 02-01-2012, 01:44 PM   #89
jr_ss
Trader Rating: (34)
Especially on this site... Sorry to say it, but the majority of 240sx owners are cheap asses. Quality is not always in their budget when they purchase goods.
Everything is looking good man. Any updates, such as motor in the bay? I've got to get a build thread going with the VVL project, I just don't have the time to piece everything together to make it post worthy ATM.
My SR20VET
Old 02-01-2012, 03:14 PM   #90
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Send a message via MSN to Big Zee
I love this thread, it's so fun to read, awesome pictures, not hard on the brain and a lot of DIY! one question though, do you still have both S14's ? or did you end up getting rid of the black one ?
I really like your drive-shaft spacer, I hope you don't mind me using that idea for my car
keep up the awesome work!
Big Zee is offline   Reply With Quote
