07-16-2014, 05:46 AM | #1 |
GKTech - Solid Subframe Conversion Bushes/Solid Subframe Bushes
The GKTECH solid subframe conversion bushes are a direct replacement of the standard items and allow you to fit an S14/S15 rear subframe in your S13/180sx. The solid bushes also ensure that movement of the subframe is kept to a minimum. They eliminate axle tramp whilst also raising the subframe which helps to correct the roll center on lowered vehicles. Unlike most other kits on the market our kit includes multiple spacer inserts to adjust the height to your liking and also includes rubber isolation washers to reduce vibrations and in-cabin noise. - CNC Machined from 6061-T6 aluminium - 16 Piece Set + rubber isolation washers Vehicle Compatibility: - Nissan 180SX - Nissan S13 Silvia - Nissan Skyline R32 GTS-T (2WD) - Nissan Cefiro A31 Price: 109 AUD (approx. 93 USD) Shipping cost: From 77 AUD (approx. 72 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/soli...on-bushes.html FAQ What's involved in installing these conversion bushes? You'll need to remove the standard bushes from the S14/S15 subframe that you're installing. There's a few ways to remove the standard bushes which option you choose is up to you (google is your friend). Once you've got the standard bushes removed you need to press fit the new bushes in their place. TIP: put the bushes in the freezer for a few hours before installing them. This will shrink them slightly to make things a little easier. What's the advantage of installing an S14/S15 subframe? The S14/S15 subframe has better geometry than the S13 unit and also offers more track (ie. width). What’s the advantage of these bushes? Besides allowing you to install an S14/S15 rear subframe in your S13, the solid bushes offer a more solid rear end = better driver control and feel. Do these cause much vibration/noise in the cabin? Not really. Obviously anything solid or more rigid is going to cause an increase in noise and vibration however I'd hardly say that it's noticeable. Chances are if you're installing these you've already got coilovers, your car is lowered, you've got an aftermarket exhaust etc. etc. Solid Subframe Bushes The GKTECH solid subframe bushes are a direct replacement of the standard items and ensure that movement of the subframe is kept to a minimum. They eliminate axle tramp whilst also raising the subframe which helps to correct the roll center on lowered vehicles. Unlike most other kits on the market our kit includes multiple spacer inserts to adjust the height to your liking and also includes rubber isolation washers to reduce vibrations and in-cabin noise. - CNC Machined from 6061-T6 aluminium - 16 Piece Set + rubber isolation washers Vehicle Compatibility: - Nissan 180SX - Nissan S13 Silvia - Nissan S14 200SX - Nissan S15 200SX - Nissan Skyline R32 GTS-T (2WD) - Nissan Skyline R32 GTR (AWD) - Nissan Skyline R33 GTS-T (2WD) - Nissan Skyline R33 GTR (AWD) - Nissan Skyline R34 GTT (2WD) - Nissan Skyline R34 GTR (AWD) - Nissan Cefiro A31 Price: 109 AUD (approx. 93 USD) Shipping cost: From 77 AUD (approx. 72 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/soli...me-bushes.html FAQ What's involved in installing these solid bushes? You'll need to remove your subframe and then your standard bushes. There's a few ways to remove the standard bushes which option you choose is up to you (google is your friend). Once you've got the standard bushes removed you need to press fit the new bushes in their place. TIP: put the bushes in the freezer for a few hours before installing them. This will shrink them slightly to make things a little easier. What’s the advantage of these bushes? The solid bushes offer a more solid rear end = better driver control and feel and also raise the subframe to help correct the roll center on lowered vehicles. Do these cause much vibration/noise in the cabin? Not really. Obviously anything solid or more rigid is going to cause an increase in noise and vibration however I'd hardly say that it's noticeable. Chances are if you're installing these you've already got coilovers, your car is lowered, you've got an aftermarket exhaust etc. etc. For any inquiries please e-mail us at [email protected]. Last edited by GKTECH; 07-17-2014 at 05:30 AM.. |
07-16-2014, 01:18 PM | #2 |
Trader Rating: (129)
Feedback Score: 129 reviews
Good lord that's cheap. I paid over double this when I did my s14 subframe Into s13 swap 3 years ago.
