Old 08-31-2008, 11:37 AM   #1
purekoryo
purekoryo has much to be proud ofpurekoryo has much to be proud ofpurekoryo has much to be proud ofpurekoryo has much to be proud ofpurekoryo has much to be proud ofpurekoryo has much to be proud ofpurekoryo has much to be proud ofpurekoryo has much to be proud ofpurekoryo has much to be proud ofpurekoryo has much to be proud ofpurekoryo has much to be proud of
gear oil for differentials
I will be using OEM Mitsubishi Diaqueen LSD Gear fluid SAE 90 for my EVO 9 transfer case and rear diff; however, I was wondering if I can use the same fluid for my S13 as well.
purekoryo is offline   Reply With Quote
Old 08-31-2008, 11:42 AM   #2
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
Good use of the semi-colon.
On which component of the S13 do you want to use the Diaqueen?
g6civcx is offline   Reply With Quote
Old 08-31-2008, 11:43 AM   #3
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Why do you want to use the diaqueen oil?
racepar1 is offline   Reply With Quote
Old 08-31-2008, 11:59 AM   #4
bigtom
bigtom is not welcome here anymorebigtom is not welcome here anymorebigtom is not welcome here anymorebigtom is not welcome here anymorebigtom is not welcome here anymorebigtom is not welcome here anymorebigtom is not welcome here anymorebigtom is not welcome here anymore
redline shockproof heavy. has the friction modifier in it.
bigtom is offline   Reply With Quote
Old 08-31-2008, 05:54 PM   #5
purekoryo
because it comes in 1 gallon can, but I will only be using just a tad over .5 liter on the EVO.
Old 08-31-2008, 05:58 PM   #6
purekoryo
that's as far as I can go in my English skills. Give me some math, and I will to the ground.
I just put some MT-90 in the tranny, but I want to use Diaqueen on my rear diff.
Old 08-31-2008, 06:48 PM   #7
Modrified
Modrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of light
fsm recommends gl5 gear oil on the diff. if it is i don't see why not. i like the mt-90 as well on my tranny.
Modrified is offline   Reply With Quote
Old 08-31-2008, 08:42 PM   #8
g6civcx
g6civcx's Avatar
This is my personal recommendation. Keep in mind that a lot of people don't have experience with Evos, or cars in general. Take it for what it's worth.
If you have a stock diff, Nissan recommends GL5 75W, 80W, 75W-90, 80W-90, 85W, 90, or 140 depending on the temperature. 80W-90 is preferred for most temps below 104*F. Consult the FSM for more details.
The Diaqueen is GL5 90. Nissan diffs are not as picky as Evos so you can use the Diaqueen if the temp is between freezing 32*F and 104*F.
If you have an aftermarket diff, the manufacturer recommends only using their brand of LSD fluid. Cheap people like to use conventional GL5 80W-90 and Ford friction modifier. I don't recommend this route but you can if you're short on cash.
My recommendation is conventional GL5 80W-90 for stock diffs and brand name LSD fluid (Kaaz, Tomei, etc.) for aftermarket diffs. Save your expensive Diaqueen for your Evo.
Others please feel free to comment.
Old 08-31-2008, 10:47 PM   #9
Pho Man
Pho Man's Avatar
Pho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymorePho Man is not welcome here anymore
Send a message via AIM to Pho Man
I'm running 75w-90 Mobil 1 syn. In my Stock Rear Diff. right now. Eventually when I get my J30 installed will probably switch over to the Redline.
Just Cause it's the holidays doesnt mean you have to drive like an A**!
Pho Man is offline   Reply With Quote
Old 09-01-2008, 10:30 AM   #10
bigtom
i have had the mt-90 go thin when it gets hot and lost some trans missions. first thing to go was syncros then bearings. never tried it in a diff though.
Redline is GL-5 and will modify to 75-140 when hot.
Old 09-01-2008, 11:29 AM   #11
Massimo Power
Massimo Power's Avatar
Massimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to all
Send a message via AIM to Massimo Power
No it doesnt have friction modifier in it. You have purchase it seperatly.
www.massimopower.com
PH: 1(951)402-5386
EM:[email protected]
Special Thanks To:
www.aeperformance.com
www.domospeed.com/blog
For Their Continued Support
Massimo Power is offline   Reply With Quote
Old 09-02-2008, 05:12 PM   #12
purekoryo
wait a minute, I thought MT-90 is the best fluid for our tranny. anyone else have had problems with the fluid? If so, I may switch to shockproof heavy duty, but I read that it was not good for our tranny long term.
Old 11-02-2008, 09:09 PM   #13
MAXIMUS_PR
MAXIMUS_PR's Avatar
MAXIMUS_PR is an unknown quantity at this point
hey there is ton of information as not to use GL-5 on Nissan Transmissions here is the why
" What happens if API GL-5 gear oil is used in an API GL-4 gear oil application?
API GL-4 and API GL-5 products typically use the same extreme pressure (EP) additive system, with the API GL-5 having about twice the concentration of a API GL-4. In service, these additives become active under extreme load and temperature when the protective oil film can be squeezed away. EP additives work by forming wear-resistant compounds with the metal of the gear tooth surface. As the gears mesh, these compounds shield the gear teeth from direct metal-to-metal contact that would cause wear and damage to the gears. If too little of the active additive is present, proper protection would be compromised. Too much of this additive could cause excessive chemical corrosion of the gear surface. If an API GL-5 gear oil is used in a application where API GL-4 gear oil is called for, chemical corrosion of "yellow metal" components may occur, such as bronze synchronizers, brass bushings, etc. This may lead to shifting difficulties or shortened equipment life."
basically it will eat non ferrous metals inside your transmission(on a SR20det set up) switched to MT90 on the other transmission 2 years of abuse never ever broke down
redline,amsoil,castrol have GL-4 and some others
MAXIMUS_PR is offline   Reply With Quote
Old 11-02-2008, 09:13 PM   #14
initial_drifter
initial_drifter's Avatar
initial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of light
like someone stated above I use the Heavy Duty Shock oil from Redline 75w-250
initial_drifter is offline   Reply With Quote
Old 11-03-2008, 05:32 AM   #15
g6civcx
g6civcx's Avatar
My recommendation to you is to contact RedLine directly and ask their technician what they recommend for your application. Be sure you have your FSM handy so you can tell them what Nissan recommends and they can tell what they recommend as a replacement.
On my Evo, when I talked to RedLine they recommended a specific ratio of their fluids to achieve the recommended viscosity for the gearbox.
Old 11-03-2008, 10:47 AM   #16
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
Mobil 1
75w-90
gets the job done and readily available at auto stores
JRas is offline   Reply With Quote
