Old 12-05-2007, 09:38 PM   #1
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Sea Foam Engine Cleaner....
did a search...didnt come up with ne specific on the topic...so thought i would ask
anyone ever try this stuff in their motor??? ive heard mixed reviews...som say that it works like a champ and others say its actually kinda bad for your engine
ive been contemplating trying it out...but didnt wanna try it til i got some input (the head in the SR is a little dirty...wanted to clean it all down with B12 when i had the valve cover off for the rocker arm stoppers...but yah...thought it woulda been a not so good idear at the time lol)
so yah...input away
Old 12-05-2007, 09:40 PM   #2
burnsauto
burnsauto's Avatar
burnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfection
Send a message via AIM to burnsauto
i know alot of oldschool guys swear by the stuff..
personally, ive never used it.
burnsauto is offline   Reply With Quote
Old 12-05-2007, 09:42 PM   #3
kevtrinh
kevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond repute
I have used it. On cars with higher mileage it really does help out. I noticed better response after my use.
kevtrinh is offline   Reply With Quote
Old 12-05-2007, 09:43 PM   #4
Vernal
Vernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymore
Send a message via AIM to Vernal
I heard the same thing (mixed reviews). Yea I work at a brake and suspension shop with a bunch of old school gear heads and they like it. Me and my friend did it in his firebird (it was a beater, so it didnt matter either way) and nothing bad happened. We didnt feel a difference but it was fun pumping out all that smoke.
Vernal is offline   Reply With Quote
Old 12-05-2007, 09:43 PM   #5
SexPanda
SexPanda's Avatar
ive used it 4 times. My engine runs great, and it really does help it as far as i can tell.ive got a ka with 186,000 miles on it. Just make sure you follow the directions to a T.
Old 12-05-2007, 09:47 PM   #6
soreballz
soreballz's Avatar
Be warned that Seafoam can kill a catalytic converter in some instances, and the carbon that it removes from the combustion chambers and valves can clog up the o2 sensor.
Aside from that, Seafoam is great. Just don't suck it in too fast. Hydrolocking is bad. lol
-Kyle
Old 12-05-2007, 09:52 PM   #7
SidewayZ-s14
SidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enough
If all goes well, let me know! My SR head is pretty messed up! I guess the dude NEVER changed the oil! If he did he did it very rarely!
SidewayZ-s14 is offline   Reply With Quote
Old 12-05-2007, 09:52 PM   #8
SexPanda
SexPanda's Avatar
http://www.seafoamsales.com/motorTuneUpTechGas.htm
that should help. If you add it to your oil, run it for like 50 miles, then change it, then run it for a few hundred, then change it. then you should be good.
Old 12-05-2007, 09:53 PM   #9
240sxorty
240sxorty is an unknown quantity at this point
I've used it. There are three ways to use it.
Warm up the engine. Unplug the vacuum line to the brake booster and pour in a third of a can while its running then turn it off and let it sit for a while. bout 15 minutes. then turn it on.
The next is to put a bottle in your crankcase run it for a while.(don't' drive it) drain, refill, do it again at 100 miles then again at a 1000 miles.
Last, just put it in your gas tank. Works great this way and your car runs like a champ while its in the tank, but goes back to normal when you refuel.
I've tried all three ways. Be careful to follow directions on the vacuum line method. I heard of someone setting their car or engine on fire that way.
I've used it on a v6 and my sr. cleaned up the idle a bit. runs better. I think really shines through when you've got a real crappy running car.
240sxorty is offline   Reply With Quote
Old 12-05-2007, 09:54 PM   #10
2ilvia
2ilvia's Avatar
2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore
ive used it just to see all the smoke, but id be worried about it dislodging large peices of carbon build-up if there is any, and scraping the walls
2ilvia is offline   Reply With Quote
Old 12-05-2007, 09:55 PM   #11
LongGrain
LongGrain's Avatar
ive used it on my 240, but my 240 is low mileage and had no problems whatsoever, so i didnt notice a difference.
never tried it on an engine that was running rough or anything.
LongGrain is offline   Reply With Quote
Old 12-05-2007, 09:56 PM   #12
SR_Elliott24
SR_Elliott24 will become famous soon enoughSR_Elliott24 will become famous soon enoughSR_Elliott24 will become famous soon enough
Send a message via AIM to SR_Elliott24
I used it on my old car had like 100XXX+ miles on it ran like it just came off the lot afterwards. Just make sure you arent in a garage when you do it lets out lots of smoke. However, I have heard not to use it on some old cars because supposedly it can cause leaks in lines due to corrosion.
I believe its something like:
1/3 container into the fuel tank
1/3 container into the crank case
1/3 container through a vacuum line
I believe you are supposed to do an oil change afterwards but not 100% sure.
Works great though.
SR_Elliott24 is offline   Reply With Quote
Old 12-05-2007, 09:57 PM   #13
240sxorty
I put it in my crank case and it turned the oil to almost the consistancy of water. I wouldn't recommend driving at all.
Old 12-05-2007, 09:57 PM   #14
SexPanda
SexPanda's Avatar
you know what else works very well? Ok, flood your cylinders with fuel, then let it sit for a few days. Dry start it a few times, then change the oil and sparkpilugs. Run it for a few minutes, then change the oil again. The carbon and shit comming out of your engine will amaze you!!!
Seriously, dont do that. I accidentally did that to my engine changing the fuel injectors. Im really suprised my engine isnt dead seized... But ti did clean it out good! But dont do it
Dont do it, dont do it dont do it... and about driving it. I kinda misinformed you. When i did it, i let it run for about 2 minutes. My friend told me thats how you did it. But the oil wasnt very... oily after that.
Old 12-05-2007, 10:02 PM   #15
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
I use it in my cars. Used it in my sister's 91 accord with the old SOHC f22 in it and made a day and night difference in that 200k mile motor.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 12-05-2007, 10:05 PM   #16
silvia-junkie
silvia-junkie has a spectacular aura aboutsilvia-junkie has a spectacular aura aboutsilvia-junkie has a spectacular aura aboutsilvia-junkie has a spectacular aura aboutsilvia-junkie has a spectacular aura aboutsilvia-junkie has a spectacular aura about
i use gm top engine cleaner, same basic principal. it ment the differece of my older ka passing for NOx and not. i just changed the oil afterward.
as for driving, you run the engine during the procedure but i would recomend driving it afterward with the same oil.
silvia-junkie is offline   Reply With Quote
Old 12-05-2007, 10:14 PM   #17
S13Boosts
S13Boosts's Avatar
S13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfection
I have used.. it on older cars with high mileage it really does clean it out. just gotta use alot.
S13Boosts is offline   Reply With Quote
Old 12-05-2007, 10:22 PM   #18
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
Ive used it on my 130k ka24de, night and day difference.
My car would idle like shit before and it felt very slugish, then i sea foamed it using the 3 methods.
Car ran like a new car.
But i ve been scared to try it on my sr, would it fuck anything up since its a turbo motor?
projekt_s13 is offline   Reply With Quote
Old 12-05-2007, 10:24 PM   #19
kandyflip445
kandyflip445's Avatar
kandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfection
Send a message via AIM to kandyflip445
http://www.bgprod.com/products/fuelair.html
My 240 vBgarage
kandyflip445 is offline   Reply With Quote
Old 12-05-2007, 10:46 PM   #20
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
well im runnin an SR with about 65k on the engine (ive had it for about 5 years now)...and ive got no cat and a apexi PowerFC DJetro...so im not too sure about adding it to the gas tank
might try it by just adding it to the crank case and doing an oil change immediatly
Old 12-05-2007, 10:47 PM   #21
Farkel
Farkel's Avatar
Location: B̷͈͇̠̗͔̼̝̓̎͛͂A̧̡̠̩̭̹̼̭͔̎̃̈́̍͂ͬͬ̚Y̯̜ͨ̒̾̽͊͘ ͈͙̰
Farkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura about
Send a message via AIM to Farkel
I remember doing this a year ago, I'm sure it's the same method on a 240sx but run it through the brakebooster line closest to the engine:
[ame]http://youtube.com/watch?v=N0-1J0u2RPo[/ame]
★ ★ GRANDMIGHTY.COM ★ ★
Farkel is offline   Reply With Quote
Old 12-05-2007, 10:47 PM   #22
4thHorse
4thHorse's Avatar
4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice
Youtube has tons of Seafoam vids and some are pretty funny. I guess your car will smokes like crazy so beware of tree huggers.
^post as same time as above
4thHorse is offline   Reply With Quote
Old 12-05-2007, 10:56 PM   #23
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
seafoam is bad ass. I've only used it for the fuel system though. I've been told by a friend who has a pretty old school state of mind that it's not good to use in the crankcase with a turbo'd motor. The main reason is because the ingredients in seafoam may unbalance the additives in the oil which could diminish it's lubrication performance. Hence, heat of turbo may coke the oil easier... possibly. but yeah, seafoam is bad ass for the fuel system as far as i know.
louisdaboois is offline   Reply With Quote
Old 12-05-2007, 11:23 PM   #24
soreballz
soreballz's Avatar
Seafoam in the oil on a turbo motor = bad idea.
-Kyle
Old 12-06-2007, 01:59 AM   #25
stinky_180
stinky_180's Avatar
Trader Rating: (26)
stinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud of
Feedback Score: 26 reviews
Send a message via AIM to stinky_180
i dont think i'll ever use it, but it does seem like a good idea for some engines.
SoCal RallyX Coverage and MTB Ride Reports
WheelsDirty
stinky_180 is offline   Reply With Quote
Old 12-06-2007, 02:06 AM   #26
BustedS13
BustedS13's Avatar
great for cleaning out vaccuum lines, great for unclogging your IACV. it's no bullshit, definitely go for it.
Old 12-06-2007, 02:16 AM   #27
!Zar!
!Zar!'s Avatar
Just run it in your gas tank.
Fuck sucking it in vac lines.
Old 12-06-2007, 04:04 AM   #28
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
There are better alternatives than Seafoam for all three applications listed.
I would not, at ALL recommend putting seafoam in your oil.
I used to be in the Seafoam advocate camp, but I found out better methods for cleaning out your engine.
If you want to clean your combustion chambers, look into water injection. I'm not talking about the system to cool your incoming intake charge, but sucking up a 1/2 quart or so of distilled water into your engine while it's hot. Same delivery method of Seafoam, but instead of burning into white smoke (which is pale oil & napatha) it vaporizes & steam cleans your engine. It's very effective for carbon removal. If your engine has lots of carbon buildup, regardless if it's Seafoam or Water, o2 sensors and cats might get blocked due to excessive carbon debris flying out.
As far as the gas tank, there are a few off-the-shelf items that are very good. The first one is well known, Chevron Techron Concentrate. Works well & also popular among the Porsche guys. Gumout Regane in the clear bottle with yellow liquid is also good. Make sure you get the exact one listed. Those two are meant to be dumped into your tank all at once.
Lucas Upper Cylinder Lubricant is also good, but it's meant more as a long-term thing, adding 2~3 ozs. per 10 gallons of gas. A 32oz bottle lasts me a few months, it's popular on BITOG with alot of the guys, shown to increase MPG by one or two points.
The last item that i'd put in my oil crankcase is something you can't buy in the store. It's called Auto-Rx, and it's probably one of THE most popular products on BITOG. It's designed to stay circulated in your crankcase for ~2,000 miles, where it actually has time to remove a good amount of carbon deposits. Do you really think something in your crankcase for 50 miles would do much?
There are also two more products that you have to mail order, and they are Fuel Power 3000 (FP3000), which is similar to Lucas UCL & Lube Control 20(LC20), which is an oil additive. Both can be ordered through vendors on Bobistheoilguy - www.bitog.com .
Check it out. Shit's hot.
Anto is offline   Reply With Quote
Old 12-06-2007, 06:35 AM   #29
Rayne
Rayne's Avatar
Rayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfection
As you have noticed several people have used the product. If you have a high mileage engine and the previous owner did not take care of it well. Seafoaming the engine can be bad if you are not prepared to deal with the problem it may uncover. As an example: For some people the carbon buildup in the combustion chamber is actually helping the engine by keeping a hole closed up. The same goes for the fuel system. What ever you do...do not be shocked if an issue with your engine comes up after everything is said and done.
Other wise...go for it.
Rayne is offline   Reply With Quote
Old 12-06-2007, 06:55 AM   #30
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
just man up and seafoam it your idle will be rock solid
i put some in the brake booster line and the iacv line
-los
[ame]http://video.google.com/videoplay?docid=2815050171826306781[/ame]
los_inc is offline   Reply With Quote
