Old 08-01-2008, 01:46 AM   #1
xkamikazestormx
xkamikazestormx's Avatar
xkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfection
lowering the rear
if this is in the wrong section please move it.
well i have a s14 with megan coils and i want to make my rear lower. but since the threaded shock body bottoms out against the shock mounts i dont know of a way to make it go lower.
i know in the fronts you can take off 2 collars but what about the rear? i have like 6 inches of threaded part left but i cant lower it more cause it bottoms out.
if anyone has any input on how to make it lower let me know.
thanks in advance zilvians.
xkamikazestormx is offline   Reply With Quote
Old 08-01-2008, 01:48 AM   #2
DriftCat
DriftCat's Avatar
DriftCat is making a name for him/her selfDriftCat is making a name for him/her selfDriftCat is making a name for him/her self
You can lower it but you'd also have to tighten the dampening.. I'm getting Megan coilovers too I wish I already had them so I could tell you how exactly but I've never really got to play around with them before sorry.
DriftCat is offline   Reply With Quote
Old 08-01-2008, 01:51 AM   #3
xkamikazestormx
what do you mean tighten the dampening?
you mean preloading the springs? because my problem is the rears do not have the hole (unlike the fronts) so i cant get it past the point its at right now.
thanks for your input tho
Old 08-01-2008, 01:54 AM   #4
DriftCat
DriftCat's Avatar
sorry I thought you were saying you could drop it but when you did it was bottoming out. That'd be the result of your car being lowered but not stiff enough to keep from full compression. Like I said that was the only thing popping to mind but I'm having to imagine the set up you're looking @ from memory of looking @ my friends once. hopefully someone with em will hope in here any minute now haha they're fairly common too...
Old 08-01-2008, 01:56 AM   #5
xkamikazestormx
sorry my question was kinda confusing.
because on my friends s13 he was able to remove the collars in the rear and actually go lower since the shock body itself is shorter in length compared to the s14.
Old 08-01-2008, 01:56 AM   #6
Teddy
Teddy's Avatar
Trader Rating: (44)
Teddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfection
Feedback Score: 44 reviews
www.realize-jp.net
Teddy is offline   Reply With Quote
Old 08-01-2008, 01:57 AM   #7
xkamikazestormx
teddy i dont care about your opinion LOL.
Old 08-01-2008, 01:59 AM   #8
brokeAs240sx
brokeAs240sx's Avatar
Trader Rating: (40)
brokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond repute
Feedback Score: 40 reviews
For the megans, once you hit the bottom of the threaded shock body, that's it. The only thing left is preloading the spring or getting a shorter spring.
bew bews!
brokeAs240sx is offline   Reply With Quote
Old 08-01-2008, 02:00 AM   #9
DriftCat
DriftCat's Avatar
yeah my friend has an s13. never had to fiddle that in depth in dropping more than it wanted to let him though so I'm not sure how you could sweet talk a little extra out of them. please and thank you if that doesn't work try teddy's idea. cut springs! =p
Old 08-01-2008, 02:01 AM   #10
xkamikazestormx
ah are you serious? where would i be able to get a shorter spring? you think eibach can get them? and if i preload the spring would it make a difference?
Old 08-01-2008, 02:01 AM   #11
Teddy
Teddy's Avatar
Trader Rating: (44)
Yeah Eibach has them I believe
www.realize-jp.net
Old 08-01-2008, 02:02 AM   #12
xkamikazestormx
Originally Posted by S13Teddy View Post
pwned.
i am not going to saw my coils LOL.
i guess if theres no other choice ill just contact eibach
Old 08-01-2008, 02:05 AM   #13
DriftCat
DriftCat's Avatar
good call cut springs freak me out. I've rolled in them before and just from the shape of them being off like the top never tapers out a good seat for the mount they tend to sit crooked and vibrate...at least these did so we had a super rapid metal popping sound and we definately got scared just driving to the store for milk let alone tryin to push them @ all on a fun road.
Old 08-01-2008, 02:16 AM   #14
brokeAs240sx
Trader Rating: (40)
you can also get swift springs - a few of the vendors carry swift springs here; I think FRSport still carries them, but you have to call (not on the site).
I got swift springs for my megans. stock is 6", depending on how much thread you have left, you can go 5" or maybe even 4". I would probably just go 5" to keep a decent amount of travel possibility.
Preloading the spring is usually not recommended unless used to corner balance a car (hence the invention of dual height adjustable) - you can search for more info on that; a little preloading doesn't hurt too much though.
Going with a shorter spring will give you less total travel, obviously - so you will have a greater chance of bottoming out.
Also, if you do decide to get Swift Springs or Eibach springs, you may want to consider getting a pair for the fronts as well - they feel totally different (as well as much lighter) than the ones that come w/ the Megans, might as well replace the entire set.
bew bews!
Old 08-01-2008, 02:21 AM   #15
xkamikazestormx
hmm ..
thanks brokeas240sx! ill look into getting a shorter spring i guess
Old 08-01-2008, 02:49 AM   #16
joshchewuhh
joshchewuhh's Avatar
Trader Rating: (56)
joshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfection
Feedback Score: 56 reviews
Send a message via AIM to joshchewuhh
spartan laser that bitch
joshchewuhh is offline   Reply With Quote
Old 08-01-2008, 03:52 AM   #17
JDM671
JDM671's Avatar
Trader Rating: (37)
JDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to JDM671
Touke <3
JDM671 is offline   Reply With Quote
Old 08-01-2008, 04:07 AM   #18
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
wait u guys preload ur springs to lower more? i thot u droop it. i droopped mine and it helped a little. i have the same prob as the OP on my JIC's
lexus baby
5t341tH is offline   Reply With Quote
Old 08-01-2008, 04:26 AM   #19
murda-c
murda-c's Avatar
yeah this thread has been full of fail.
Old 08-01-2008, 05:37 AM   #20
xkamikazestormx
ya i kinda thought the same thing. cause i thought adding preload raises your car.
but im kinda scared to run like negative preload lol. isnt that bad
Old 08-01-2008, 05:57 AM   #21
240esux
240esux has a reputation beyond repute240esux has a reputation beyond repute240esux has a reputation beyond repute240esux has a reputation beyond repute240esux has a reputation beyond repute240esux has a reputation beyond repute240esux has a reputation beyond repute240esux has a reputation beyond repute240esux has a reputation beyond repute240esux has a reputation beyond repute240esux has a reputation beyond repute
Send a message via AIM to 240esux
yes. if you lower from preload you have a better chance of blowing your coils alot faster.
240esux is offline   Reply With Quote
Old 08-01-2008, 10:26 AM   #22
Clowny
Clowny's Avatar
Clowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to behold
Send a message via AIM to Clowny Send a message via Yahoo to Clowny
thats what ive always heard too. dont think preloading them a little would do much damage, but doing it to the point where the car is where you want t is probably not good.
Clowny is offline   Reply With Quote
Old 08-01-2008, 10:33 AM   #23
wow-thats-a-cool-car
wow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfection
Send a message via AIM to wow-thats-a-cool-car
get a torch and get the coils hot and compress them
or buy some cement and pour it into the trunk of you car to add weight and lower your rear.
Or pay a really fat dude to permanently sit in your back seat or trunk to add weight and lower the rear.
Or raise the ground everywhere in the world and that would make your car look lower
wow-thats-a-cool-car is offline   Reply With Quote
Old 08-01-2008, 10:42 AM   #24
Clowny
Clowny's Avatar
thats what i keep tellin prople when i get in my car. i am my own lowering kit! lol.
Old 08-01-2008, 11:07 AM   #25
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
I'm curious. What do you mean by this?
I'm not sure I understand what's going. Can you post a pix or explain it again?
g6civcx is offline   Reply With Quote
Old 08-01-2008, 11:18 AM   #26
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
he's saying when he's turning the threaded part,(the part that turns when using the spanner wrench to lower the car), it stops. kind of like bolting in a bolt and it runs out of threads and you cant turn it anymore. just like that.
s13silady is offline   Reply With Quote
Old 08-01-2008, 12:07 PM   #27
murda-c
murda-c's Avatar
after all that you drew a front coilover.
You can see where in the rear coilover on the left, the black threaded body can only thread so far into the silver bottom mount before it hits the end.
The fronts don't have this problem and you can just take out the locking collars when you want to go lower.
Old 08-01-2008, 12:09 PM   #28
xkamikazestormx
ya i just hoped that i can get it lower but i guess not ..
Old 08-01-2008, 12:13 PM   #29
SoSideways
SoSideways's Avatar
Megans should allow for a little bit of rear spring droop to get you to the height you need.
The only reason why rear shocks will blow, is if the shock is A) bottoming out, or B) operating in a range they weren't designed to do.
Now, I know Stance GR+ will allow for some droop with no problems, as they were designed to do have a little droop in mind.
The Megans... well I think some people have drooped the springs on their's a little bit and haven't had any problems, so it's really a "just do it and see" type of situation.
Old 08-01-2008, 12:21 PM   #30
xkamikazestormx
how much lower would i be able to go by doing that?
