Old 12-19-2011, 07:05 PM   #1
usdm180sx
usdm180sx's Avatar
Converting kouki 190sx cluster from kmh to mph
Oops, sorry for the typo I meant to post "180sx" not "190sx" lol
Now that the wiring issues of these clusters has been solved, it's time to take it to the next level. Has anyone done a kph to mph calibration on one of these clusters?
Here is a writeup of the kph to mph calibration on a zenki/chuki 180sx cluster so you know what I am posting about:
180mph speedometer for S13 240sx (using JDM speedo) or fine tuning for gear ratio change - zeroyon.com
-Norm!
Old 12-19-2011, 07:42 PM   #2
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
Good move, I clicked on this thread ready to unleash a blitzkrieg.
Attention Zilvia retards & illiterates:
See this as a learning opportunity. If you cannot fix your mistakes, at least acknowledge and perhaps even attempt to correct them, as properly demonstrated here. This will save you from total annihilation.
This message brought to you by the department of spelling, grammar, and punctuation.
omgRWDgoodness! is offline   Reply With Quote
Old 12-19-2011, 07:49 PM   #3
bigs
Old 12-19-2011, 07:59 PM   #4
usdm180sx
usdm180sx's Avatar
Ummm, yeah......so has anyone done the calibration yet??
-Norm!
Old 12-23-2011, 09:35 PM   #5
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
wangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfection
Feedback Score: 36 reviews
Send a message via AIM to wangan_cruiser
thats a helpful write up. ill try it when i get a jdm cluster for my sr swap. thanks
wangan_cruiser is offline   Reply With Quote
Old 12-24-2011, 02:08 AM   #6
GeneStarWindGSW
GeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant future
Would this work on JDM clusters for s14s?
http://zilvia.net/f/showthread.php?t=637070 last of my parts f/s
GeneStarWindGSW is offline   Reply With Quote
Old 01-12-2012, 06:57 PM   #7
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Bit of an old thread I know, but just to post some info out there.
Took apart my gauge cluster and found out the speedometer doesn't resemble neither the regular S13 clusters we're accustomed too nor the S14 speedometer.
There isn't a speed adjustment potentiometer or solder points resembling those found on the S14 speedometer.
Possibly some of the solder points on the 180SX Kouki speedometer could be used to convert from km/h to mph, but I'm not savvy enough to figure it out.
Best, and possibly easiest, option in my opinion is to go with the Dakota Digital Universal Speedometer Signal Interface:
http://www.dakotadigital.com/index.c...rod/prd126.htm
I'll more than likely be purchasing one at the end of the month if I can't figure out how to convert to mph for cheaper.
Pix:
Dakota Digital setup on an LS1 S14:
4 Wires is to easy. Sure it's a $80 or so hit to the wallet, but as the saying goes "you gotta pay to play."
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 01-16-2012, 12:42 PM   #8
guitaraholic
guitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of light
I remember doing mine last year. It was pretty easy, just took a couple of trials to get it right. I think I am off by about 1-2 mph at 60. The line of resistors work by a factor of 2. Each one adjust it 1/2 of the next (ie, first my drop it 50%, the next 25%).
I just soldered mine up it took twice to get it completely right. I would get an initial mph vs rpm on a few runs, the more points on the plot, the better reference you will have if you are on.
The only thing I have to do now is calibrate the odometer to track miles instead of km. Not a big deal right now, because she's been in storage for the past 7 months while I'm overseas, and I won't be driving her too much in the next 7-8 months because my next project is this.
guitaraholic is offline   Reply With Quote
Old 01-18-2012, 04:17 PM   #9
J90lude
J90lude's Avatar
J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude
I always thought once you get the jdm gauge cluster your ok. Didn't know it was soldering involve. Then again....
"Drive it like you running from the cops"
J90lude is offline   Reply With Quote
Old 01-22-2012, 02:00 AM   #10
DreamN
DreamN's Avatar
Trader Rating: (54)
I believe you're talking about the S14 gauge cluster. This thread is about the 180SX Kouki gauge cluster.
In regards to the 180SX/Silvia clusters in Zenki/Chuki models, yes. They are plug and play.
The 180SX Kouki is not as the harness and plugs are different.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 01-22-2012, 04:30 PM   #11
J90lude
J90lude's Avatar
Gotcha
Old 01-22-2012, 04:44 PM   #12
krappy
Trader Rating: (41)
krappy is an unknown quantity at this point
Feedback Score: 41 reviews
this mod only works on older 180sx gauge clusters and will not work on the newer 180sx kouki clusters.
krappy is offline   Reply With Quote
Old 05-08-2012, 02:20 AM   #13
davidpham
davidpham's Avatar
davidpham is an unknown quantity at this point
i need this but the link isnt working! =[
davidpham is offline   Reply With Quote
Old 01-11-2013, 09:28 PM   #14
jamg
jamg is an unknown quantity at this point
i read that all you need is a resistor?
anyone know anything else about it?
jamg is offline   Reply With Quote
Old 01-11-2013, 09:34 PM   #15
usdm180sx
usdm180sx's Avatar
Pix:
Cool let me know if u get it working. Thanks!
-Norm!
