Old 05-02-2014, 09:08 AM   #1
acslater9
acslater9's Avatar
acslater9 is an unknown quantity at this point
Gas Pedal loose
I started a thread a couple of days ago about the gas pedals plastic piece was broken, but I do not think that is the problem.
When I push my gas pedal all the way down the cable slowly returns back to its position. I literally tightened the crap out of the throttle cable yet it still does the same issue.
Also, if the cable is not in the correct position when I start the car it raises in RPMs like crazy.
Any idea what's going on? Any suggestions is appreciated, Thanks.
acslater9 is offline   Reply With Quote
Old 05-02-2014, 11:18 PM   #2
Rayne
Rayne's Avatar
Rayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfection
Are any of the bolts holding the gas pedal to the firewall loose?
Rayne is offline   Reply With Quote
Old 05-03-2014, 06:42 AM   #3
acslater9
acslater9's Avatar
Nope none. I have gone under to check the pedal countless of times and there is nothing holding anything back.
Once I push the pedal the cable is slowly retracting back to its original place. I'm going to check the throttle chamber soon. Hopefully I get an answer.
Old 05-03-2014, 11:35 AM   #4
Scratchoz
Scratchoz is an unknown quantity at this point
I had a problem where mine would idle high...I would check the return spring.
Scratchoz is offline   Reply With Quote
Old 05-03-2014, 04:29 PM   #5
acslater9
acslater9's Avatar
Dude that is exactly what is happening when I start the car! I get high idles somewhere around 1-2k rpms.
Where is the return spring located? Thanks
Old 05-07-2014, 02:05 PM   #6
acslater9
acslater9's Avatar
Well I decided to get a new throttle body cable and install it to see if it fixed the problem and nothing. The problem still exist.
I removed the intake piping and it looks like the throttle body is not closing fully. Any suggestions? Thanks.
Old 05-07-2014, 02:10 PM   #7
e1_griego
e1_griego's Avatar
Trader Rating: (24)
e1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond repute
Feedback Score: 24 reviews
Is the throttle pulley bent?
It's probably the throttle body itself that's got a problem, or the spring on it.
e1_griego is offline   Reply With Quote
Old 05-07-2014, 03:32 PM   #8
acslater9
acslater9's Avatar
Nope the throttle pulley is not bent. When I pull the pulley back it goes down by itself but the throttle body is not closing all the way. When I physically push it down then the throttle body is closed.
I was actually thinking about the spring also. Any possible way to fix it? Honestly I was looking at it and it looks like it will be a bitch to remove/replace.
Old 05-07-2014, 04:02 PM   #9
e1_griego
e1_griego's Avatar
Trader Rating: (24)
it's 4 bolts to replace the throttle body.
Old 05-08-2014, 05:16 AM   #10
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
Take a picture of how you have the cable routed. I'm wondering if you have a tight squeeze on it somewhere. I know that clamp on the fire wall right at the top, and behind the valve cover, if you have the cable in there and the clamp is too tight, the cable will have a slow response time returning back to its normal position.
I like my bikes how I like my b¡tches...naked!
2014 Triumph Street Triple
kruked is offline   Reply With Quote
Old 05-08-2014, 05:23 AM   #11
Rayne
Rayne's Avatar
The return spring is part of the gas pedal assembly. Look at the Factory Service Manual for a picture.
Old 05-08-2014, 05:44 AM   #12
Rayne
Rayne's Avatar
Clean the throttle body with throttle body cleaner and an old toothbrush.
