Old 03-13-2008, 02:06 PM   #1
Paulpen
Paulpen is on a distinguished road
Anyone know where this wire goes ?
Does anyone know where the yellow wire from the purple plug go ?
I think the red plug is the AAC but the purple one I dont know.
Many thanks in advance
Paul
Paulpen is offline   Reply With Quote
Old 03-13-2008, 06:57 PM   #2
Sileighty_85
Sileighty_85's Avatar
Its been awhile since Ive worked on an RB
If it like an SR there are coolant lines that run through the IACV
The Purple one I believe is a Coolant sensor for the IACV so it can adjust to the change of the engine temp. for Idle A/F Ratios
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-27-2008, 10:35 PM   #3
BIZERK
BIZERK's Avatar
BIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud of
Send a message via AIM to BIZERK
the one with the purple plug is the FICD. The FICD is only need when you have the AC on. so if you aren't going to be installing AC, i wouldn't worry about it.
BIZERK is offline   Reply With Quote
Old 03-28-2008, 11:56 AM   #4
Paulpen
Thankyou
Old 03-29-2008, 08:50 AM   #5
Paulpen
Just an idea but can I somehow wire it so that it ups the idle when my elec fans cut in ?
Old 04-14-2008, 03:28 AM   #6
ichibans13
ichibans13's Avatar
ichibans13 will become famous soon enoughichibans13 will become famous soon enoughichibans13 will become famous soon enoughichibans13 will become famous soon enoughichibans13 will become famous soon enough
You would have to splice the power to the power of your fans (after the switch) and the ground to a grounding point. Then, when your fans are getting power that will get a signal to kick on.
|OO\____/OO| Okinawa JP 2003-2006
Currently: R14 -- Carolina Nissans Elite
ichibans13 is offline   Reply With Quote
Old 04-14-2008, 11:20 AM   #7
Paulpen
May well give that a test go before I tape it all up nicely then
