07-17-2004, 04:36 PM | #1 |
Engine sounds like a spray can
Have any of you encountered this before? If you're hood is up and your car is in idle, it sounds like someone is shaking a spray can in there. I was told it might be a broken valve spring, but was hoping to get some more opinions on it and maybe even what sort of costs there'd be in getting something like that fixed. Anybody??
07-17-2004, 08:36 PM | #3 |
Also sounds like the guides for the timing chain, are broken. There are (4) I believe and all of them are made out of plastic (why nissan did this is beyond me) when you take off your valve cover you will see the piece that is broken. These guides keeps the chain from hitting the top of the valve cover, which causes the rattle sound. I had this happen on both my 240's (93/95). I just let it rattle, it doesn't really hurt anything but is loud when you open the hood.
07-18-2004, 10:58 AM | #4 | |
My 240 vBgarage |
07-18-2004, 11:12 AM | #5 |
your post is too vague.
where is the noise coming from? head or block? here's a tip, put a screw driver up agianst various places of the valve cover and put it up to your ear and see if you can pinpoint where the noise is coming from. if its coming from the block, could be what mr. meph said , in which you're screwed |
07-18-2004, 03:21 PM | #6 |
welcome to the world of KA24. Has this always been with teh car since u had it?? Alot of cars I hear have valve ticking... If its really loud and annoying like something broken inside there.., chances are the timing chain guide broke, easy fix tho, just pull the valve cover and remove the broken piece.
Keep it Classy |
07-19-2004, 12:10 AM | #7 | |
detonation........at idle? Thats a new one. Also FWIW, pretty much all timing chain guides are plastic
90 S13:............fitter, happier, more productive. 04 Yamaha R1: 210rwhp on gas/161rwhp on motor |
07-19-2004, 08:36 AM | #8 |
we need more info...
what kind of engine (or car)... ka24E or ka24DE? for the E any kind of ticking or tapping is not a good sign. for the DE it could be alot of things; but usually the simple causes are loose timing chain guides (2 metal ones) or low oil. |
07-20-2004, 01:35 AM | #10 | |
1991 240sx SE, 5spd fastback |
07-20-2004, 07:06 AM | #12 | |
there are two guides for the upper chain.
07-20-2004, 08:42 AM | #13 |
Yep the KA likes to sing rattles. My old 91 KA (170k) made that sound too. But starngely, my 95 KA engine doesnt make that sound (prolly because of the milder cams)
==>>TGL GARAGE<<==.. RIP! S13 coupe KA-T @ 0.5 Bar = SOLD! A31 Cefiro + SR = Current |
07-20-2004, 05:51 PM | #14 |
When I first got my 93 it was making a noise like the coming from the valve cover and it was freaking me out..Last week I changed the oil and I havent heard it since. It only did it at idle..either that or the road noise was too loud to hear it at higher rpms...it would go away if I just revved the motor...and I have 150,000mi
07-20-2004, 06:20 PM | #15 |
just to clear up what might be confusing for ppl:
ka24E has the plastic guides. ka24DE has metal guides. rattling is usually a much more serious problem in the E. 240sx.org has a great FAQ on the ka24E rattle problem in their FAQ section. mav : it sounds like u were runnign on low oil. when ur oil gets low iirc the chain tensioners dont do their job and the timing chain gets a little slack and pings against the front chain guide. there are multiple causes on the DE... first thing to do is remove the 2 upper timing guides and check the upper and lower tensioner while u have the front timing cover off. for that u need sockets, gasket, gasket remover and a timing light. it's a easy 1-2 hour job, there's info on 240sx.org for the tensioner and a faq on zilvia for the guides. if u ignore this u'll end up with little bits of metal floating around in your engine from the chain pinging against the loose guides all the time. when i took mine out they had grooves in them. oh joy. |
07-23-2004, 07:08 AM | #17 |
take a look at where the valve cover screws go through gasket. usually that is where it gets stripped first when you're taking it out. if it looks really messed up, change it. iirc it's not a particularly expensive part.
fyi i reused mine the first time. after taking off the valve cover 3 times (my car sucks) i finally changed it b/c it started leaking. another option (that might not be kosher) would be to put a small amount of silicone gasket around the area where the screws sit. |
