05-20-2008, 08:34 AM | #1 |
Excessive Fuel Consumption on KA24de
so for some reason im only averaging 11mpg in city and on the highway my mileage is even worse. City where i live isnt much stop and go.
05-20-2008, 09:01 AM | #4 |
I had the same problem with mine. I decided to take the proccess of emlimination route. After changing tps and some other sensors i change the 02 sensor out and it made a world of difference the car doesnt' sputter and gets awesome gas mileage compared to before.
05-20-2008, 09:03 AM | #5 |
LAID OUT
plugs, wires, cap, rotor, reset timing, change fluids, check/replace o2 sensor, new panel filter, check for vac leaks, check fuel pressure/FPR, pull codes off ECU... @ 11mpg something is seriously wrong with your DE.
05-20-2008, 09:19 AM | #6 |
question how do you pull the codes off the ecu 2nd timing is on point but i think tps might be on the shits cuz idle didnt drop or change slightly when unplugged, 3rd intake no panel filter, and 4th no vac leaks.
05-20-2008, 10:51 AM | #8 | |
LAID OUT
K you can use a multimeter to read your TPS signal at idle, should be .5v iirc. You can loosen the 2 screws to adjust the TPS value at idle, read the FSM, but I think on the KA (and most nissans) you set it to .5v. Now you need to set your idle speed using the idle speed screw. I think you set the speed to 650 with the TPS unhooked, do your base timing, then reattach the TPS. The whole procedure is listed in the FSM, you need to download and read it if you haven't already it has all this stuff in it. Just sounds like your car needs a basic tune up, if it's been a while since you did that you'll probably feel a nice difference after you replace the stuff that wears out. Also go read about doing the seafoam or TB cleaner thru the IACV line sometimes the gunk inside the intake screws with idle and power a little. GL |
06-04-2008, 01:06 PM | #10 | |
06-04-2008, 04:42 PM | #12 | |
LAID OUT
how is your O2 sensor? I would start with all the basics and replace that stuff since you have no codes on the ECU... Air filter, fluids, plugs, wires, cap, rotor, clean MAF, chk/replace o2 sensor, etc.. |
06-04-2008, 05:06 PM | #13 | |
06-04-2008, 07:35 PM | #14 |
Tps readings idle. 1mv tap throttle a little bit and it shoots up to 12 volts right away. Cts is running .87x volts. o2 is going up and down from .9xx v max to .2xx v min. NO IACV
