Old 09-24-2008, 02:43 PM   #1
turbo98
turbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of light
No compression...need help please!11!1!!
Ok, ran the car pretty hard last night, after a race I decided to coast from 120 so I put the car in neutral and it dies, won't start back up...got it towed, pulled the plugs and cylinder 1 spark plug prong was smashed onto the electrode, not melted, smashed. Next, I decided to do a compression test and I have zero compression in all cylinders. The rest had no problems with spark plugs. I'm think maybe bent valve(s)....someone please chime in!
Car: 1997 240sx KA-T
Motor: supertech pistons, eagle rods, cometic gaskets, arp studs...tested the compression the week before, ran 160 across the board...
turbo98 is offline   Reply With Quote
Old 09-24-2008, 03:35 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Hmm...how is it even possible to get no compression in all 4 cylinders? You sure you're gauge isnt fucked up?
CLICK HERE!!!
Old 09-24-2008, 03:40 PM   #3
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
+1 on the fucked up gauge
did u have ur t/b open when you did the test?
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 09-24-2008, 03:44 PM   #4
turbo98
yeah sure did...no doubt at all. I'm leaning towards jumped timing, that would explain no compression in all cylinders. Exhaust cam could be out of time just enought to be open and let the compression out...
Old 09-24-2008, 03:59 PM   #5
neilsan
neilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-known
That wouldnt explain why your plug got smushed, though.
If the motor is still interference when using dished / low compression pistons, then if you jumped a tooth you might have munched some valves. A piece of valve bouncing around would explain the damaged spark plug.
When rebuilding the motor, did you use new OEM parts for the timing chain set? like 5 years ago I rebuilt my first KA with an InnerFireGear timing kit, aka TOPLINE, from ebay. I some how didnt notice when installing it but the lower tension side arm wasn't machined right and was being sandwiched against the block, unable to pivot at the bottom like it's supposed to. The excessive chain slack destroyed the opposite lower guide, and subsequently almost took my motor with it.
neilsan is offline   Reply With Quote
Old 09-25-2008, 08:18 AM   #6
turbo98
The motor was built before I got it...so I have no idea. I think I'm just gonna go ahead and pull the head off and see what's up and hope it's just valves!
