Old 10-20-2006, 08:51 AM   #1
junks13
junks13 is an unknown quantity at this point
Question WANTED: oversteer
ok iv been into drifting for a year or so and iv always thought if i had more power i could drift better despite what i had read and heard but im starting to understand it 90% suspension but heres the prob i cant afford a set of $1500 coilovers but after a little research and alot of understeer that maby you dont have to have expensive coilovers or a 1000hp so heres what im thinking some pretty stiff springs like 250 to 300lbs in the rear and a 28mm godspeed or whitline adjustable sway bar for the rear and alittle softer spring for the front this is my first attemp to modify sus other than lowering so tell me what you guys think its a 90 240sx with terrible understeer thanks in advance
down_SHIFT
junks13 is offline   Reply With Quote
Old 10-20-2006, 09:58 AM   #2
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
i'm not a drifter, but i'd imagine the things you'd need to do for your car to oversteer would be
- E-brake more when understeer occurs
- Skinnier tires
- Release throttle or foot brake on turn in for better weight transfer to the front to loose traction in the rear
if those things don't cause oversteer then work on suspension upgrades
sean350z is offline   Reply With Quote
Old 10-20-2006, 10:00 AM   #3
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
It's a trap. Don't do it.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 10-20-2006, 10:26 AM   #4
Slidin240Wayz
Slidin240Wayz's Avatar
Slidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfection
Stiffer rear- oversteer
Stiffer front- understeer
There are websites describing the change/adjustment in every suspension part.
Carlos
Slidin240Wayz is offline   Reply With Quote
Old 10-20-2006, 11:25 AM   #5
theicecreamdan
work on changing your driving style to create under/oversteer. When you can do both to some degree you can start working on how the car responds to what you input to make oversteer a little easier to induce.
The car handles how you drive it.
theicecreamdan is offline   Reply With Quote
Old 10-20-2006, 11:33 AM   #6
TheSquidd
TheSquidd's Avatar
TheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfection
Send a message via AIM to TheSquidd
FS: Oversteer
125$ shipped. No lowballing. PM for pics.
TheSquidd is offline   Reply With Quote
Old 10-20-2006, 11:43 AM   #7
junks13
hey squid ill take two of those
sean it does't work that way the more weight you put on the front the more traction it takes to hold it
and slidin240 can you post a link to the website you mention
down_SHIFT
Old 10-20-2006, 12:26 PM   #8
LB.Motoring
LB.Motoring's Avatar
i donno.....
75 shipped.
or else.
Robby Leuer
Old 10-20-2006, 12:40 PM   #9
McRussellPants
McRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond repute
One time my car understeered so bad that my momma got scared and said you're moving in with your auntie and uncle in bell air.
McRussellPants is offline   Reply With Quote
Old 10-20-2006, 12:42 PM   #10
chmercer
chmercer's Avatar
chmercer has a reputation beyond reputechmercer has a reputation beyond reputechmercer has a reputation beyond reputechmercer has a reputation beyond reputechmercer has a reputation beyond reputechmercer has a reputation beyond reputechmercer has a reputation beyond reputechmercer has a reputation beyond reputechmercer has a reputation beyond reputechmercer has a reputation beyond reputechmercer has a reputation beyond repute
chevy 2500 rear leaf spring conversion
chmercer is offline   Reply With Quote
Old 10-20-2006, 12:42 PM   #11
McRussellPants
PS.
Old 10-20-2006, 12:47 PM   #12
TheSquidd
TheSquidd's Avatar
Originally Posted by McRussellPants
900th French Prince Reference...
Old 10-20-2006, 02:44 PM   #13
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
i wrote something but it was punctuated so i had to delete it since the meaning would be lost in translation either way understeer rocks for throttle steering in transition its nice to have more control over what your rear wheels are doing rather than just letting them swing out and possibly snap oversteering into a spin
AceInHole is offline   Reply With Quote
Old 10-20-2006, 03:23 PM   #14
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
weld the diff
Hi
Var is offline   Reply With Quote
Old 10-20-2006, 05:17 PM   #15
akuma s14
akuma s14's Avatar
akuma s14 is making a name for him/her selfakuma s14 is making a name for him/her self
If you are really looking to build in over steer into the car all you have to do is play with the toe stting (make it positive) on the back wheels. But - that is kind of lame & it wqil give you almost automatic oversteer + snappy back fun. Best way to get oversteer is save some money for an event, go to it, be humble enough to admit you don't know how to drift,the ask someone who does to ride along with you and show you why you suck. Then you'll learn something Timmy and actually you won't be killing space on the motorsports topic when you should be chilling on the bunny slope. hope that helps.
Please send 792.00 rnb via playpal to [email protected]
AKUMA WORLD
www.land-ho.net
www.driftbuffet.com
akuma s14 is offline   Reply With Quote
Old 10-21-2006, 12:29 AM   #16
McRussellPants
Originally Posted by TheSquidd
Cliche is hating George Bush for "being Hitler".
The Fresh Prince responses are more or less just stale.
But I still refuse to treat a thread with this much bullshit in it with respect.
Old 10-21-2006, 04:00 AM   #17
kenversusryu
kenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nice
^^ You like to recycle your jokes dont you.
understeer happens to the best of us. Just use whatever is in your arsenal... e-brake, cheap balding tires in rear, good grippy tires in front, sway bars etc.
kenversusryu is offline   Reply With Quote
Old 10-21-2006, 09:27 AM   #18
!Zar!
!Zar!'s Avatar
Kick the clutch.
Old 10-21-2006, 10:20 AM   #19
cfrost
cfrost's Avatar
cfrost is close to perfectioncfrost is close to perfectioncfrost is close to perfectioncfrost is close to perfectioncfrost is close to perfectioncfrost is close to perfectioncfrost is close to perfectioncfrost is close to perfectioncfrost is close to perfectioncfrost is close to perfectioncfrost is close to perfection
Send a message via AIM to cfrost
just keep practicing..you can do a lot with a stock 240sx and an LSD (or without an LSD, if you have enough experience). Springs and shocks will make it good enough to roll
cfrost is offline   Reply With Quote
Old 10-21-2006, 02:45 PM   #20
TAMTANIUM
TAMTANIUM's Avatar
TAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the rough
Check out this link http://www.wtrscca.org/tech.htm
and you can do it, just keep trying. You don't need coilovers or expensive items. It's all about skills.
TAMTANIUM is offline   Reply With Quote
Old 10-22-2006, 12:06 AM   #21
anthony240
anthony240's Avatar
anthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really nice
Send a message via AIM to anthony240
it's actually more like 90% driver skill, 10% car.
after doing everything i can to add oversteer to my car, i found the car to be harder to control. i had to fight the steering wheel more. after multiple practice runs, i tuned my suspension for a little understeer. now, i enter turns earlier and make corrections as needed going into the turn, and hit the clipping points.
18+ to come//21+ to swallow
anthony240 is offline   Reply With Quote
Old 10-22-2006, 03:41 AM   #22
ciGARRETTsRbad4u
ciGARRETTsRbad4u is making a name for him/her selfciGARRETTsRbad4u is making a name for him/her self
250-300 lbs is not stiff. In fact, thats pretty soft of a spring.
If the car is stock, it probably understeers because of the way you drive it. I'm not trying to "diss" you and say you can't drive or anything like that.
Try changing the way you drive the car.
How are you trying to initiate your drift? How fast are you going?
ciGARRETTsRbad4u is offline   Reply With Quote
Old 10-22-2006, 10:32 AM   #23
yokotas13
yokotas13's Avatar
i thought it was the 3500 cause its stiffer?
yokotas13 is offline   Reply With Quote
Old 10-24-2006, 03:29 AM   #24
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
I'm guessing you dont have an LSD? Spend >100 bucks and get your diff welded from flybert/luke and you will have enough oversteer. Hell I have a basically stock car and I get TOO much oversteer.
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 10-25-2006, 11:32 PM   #25
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
I could have sworn a welded diff will cause more understeer if you do not change your driving style..Ya know, since it will push harder and all into the turn not allowing the car to rotate
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 11-05-2006, 04:26 PM   #26
Var
Var's Avatar
This is very very very true. Welded diff cars plow like mad. But once you figure it all out it can be very fun. If i took this post seriously i would have given real advice on what to do.
Hi
