Old 07-23-2006, 01:05 PM   #1
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
Coilover install...keep red seal for the mount?
I have this thing with mounting something metal to metal especially when it comes to coilovers...I'm not fond of installing them without the red washer that seals out water and keeps the contact area a clean mounting surface.
How many of you install new red washers at the mounts when installing coilovers? Can I order the paper washers from Nissan?...I couldn't find them on trademotion
Thanks
sean350z is offline   Reply With Quote
Old 07-24-2006, 12:35 AM   #2
harlockssx
harlockssx will become famous soon enoughharlockssx will become famous soon enoughharlockssx will become famous soon enoughharlockssx will become famous soon enough
Thanks
I never used them (red seals) myself, but I guess it wouldn't hurt...
Old School
harlockssx is offline   Reply With Quote
Old 07-24-2006, 12:46 AM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
NemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfection
Send a message via AIM to NemeGuero
its a dirt/dust seal.. that's all
NemeGuero is offline   Reply With Quote
Old 07-24-2006, 09:20 AM   #4
caall99
caall99's Avatar
caall99 is an unknown quantity at this point
Send a message via AIM to caall99
so where does one get it??? i want to keep my freshly ordered megans nice and clean
Signature over limits
http://www.zilvia.net/f/showthread.php?t=21036
caall99 is offline   Reply With Quote
Old 07-24-2006, 09:28 AM   #5
!Zar!
!Zar!'s Avatar
It has nothing to do with keeping the coils themselves clean, being as how 95% of the body is exposed.
Running them on the front would be pointless, being as how the camber plats have adjustment slots, so dust/water can still pass through there.
It's purely optional. If you still have them, then use them. If not then don't worry.
Old 07-24-2006, 10:04 AM   #6
sean350z
sean350z's Avatar
yea i just want to have that added layer of protection of aluminum to steel contact (not worried about dirt)...not that they should move enough to cause wear but...i'm just anal about those kind of things.
thanks for the advice guys...going to call stealership to see if there are replacements b/c mine are deteriorated and i would like new ones.
EDIT : For those who want to replace theirs, the part numbers are
54329-58S00 (front)
54329-01U00 (rear)
Old 07-24-2006, 10:39 AM   #7
S13Eye
S13Eye's Avatar
S13Eye will become famous soon enoughS13Eye will become famous soon enoughS13Eye will become famous soon enough
Send a message via AIM to S13Eye
Thanks for the part numbers. They should be added to the FAQ. I will be getting a set of those seals, for the exact same reason you wanted to. It would also seem that the seals would serve as road noise insulators to an extent.
Here in the midwest our cars are exposed to a lot of corrosive road chemicals. Any protection, no matter how small is a good idea.
S13Eye is offline   Reply With Quote
Old 07-24-2006, 10:54 AM   #8
sean350z
sean350z's Avatar
FYI those part numbers are for S14...pretty sure they'd be very similar to S13s
Old 07-24-2006, 12:17 PM   #9
trsilvias13
trsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to behold
Or you can simply go to any home depot, autozone, kragen,etc.. and get one of those make your gasket paper thing.
trsilvias13 is offline   Reply With Quote
