Old 05-25-2011, 09:32 PM   #1
hockeyrules
hockeyrules is an unknown quantity at this point
First SR Pull
I searched for this and couldn't really find what I was looking for.
But this is my first engine pull, I am pretty mechanical so I am pretty confident I can do it.
I would just like some tips and tricks that you guys have used.
So far I have labeled and pulled the main engine harness(MAF,CAS, Injectors etc..), taken out the shifter, and started working on the PS.
What other wiring do I need to unclip?
Besides wiring, the radiator, and ps, is there anything else that I need to undo?
The car is an s3 w/sr.
Thanks for any advice!
hockeyrules is offline   Reply With Quote
Old 05-26-2011, 07:26 AM   #2
hockeyrules
really nobody has pulled an sr
Old 05-26-2011, 08:23 AM   #3
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
You'll need to unbolt the driveshaft, unbolt all the grounds, and water lines behind the motor running through firewall, pull your power steering pulley off the motor, unbolt the exhaust after the o2 housing. just make sure anything attaching the engine to the car is off. all wiring etc...
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 05-26-2011, 08:30 AM   #4
whowutwut
whowutwut is an unknown quantity at this point
Send a message via AIM to whowutwut
I would think this is no different than pulling any other engine.... KA or SR ... . Just unhook everything, unbolt the mounts, and slowly lift the engine out. If you're in your home garage, make sure your ceiling height can accomodate the engine hoist up in the air pretty high.
Since you've taken out the shifter it looks like you're pulling both the engine/trans out together... so make sure you drain the transmission fluid or you'll have a nice mess to clean up. Also, make sure the car is high enough for the transmission to swing down as it comes out... The engine will come forward a little, then you have to get it at an angle to get it out of the bay. good luck
whowutwut is offline   Reply With Quote
Old 05-26-2011, 08:41 AM   #5
hockeyrules
Thank you!
Yea I know, I just have an sr in the car that's why I was looking for more specific info. Thank yuo
