01-01-2013, 06:53 PM | #1 |
Trader Rating: (163)
Feedback Score: 163 reviews
S13 Center Vent Gauge Plates
Item: 352 (3) 52mm Gauge Plate: $45 Shipped 1 in stock Item: 352A (3) 52mm Angled Gauge Plate: $75 Shipped 8 in stock Item: 260152 (1) 52mm and (2) 60mm Gauge Plate: $45 Shipped 0 in stock Item: 360 (3) 60mm Gauge Plate: $45 Shipped 2 in stock Item: 160V (1) 60mm Gauge Plate With Vents: $65 Shipped 1 in stock Item: 160252 (1) 60mm and (2) 52mm Gauge Plate: $45 Shipped 1 in stock Item: 252V (2) 52mm Gauge Plate With Vents: $65 Shipped 2 in stock Item: 252AV (2) 52mm Angled Gauge Plate With Vents: $85 Shipped 4 in stock Item: BLANK Blank Gauge Plate: $19 Shipped 1 in stock All Angled Gauge Setups Include Universal Brackets: The brackets can be cut/modified to accommodate virtually any gauge. This will ensure the gauges do not budge when mounted in the plate. On top of that, the mounting bracket gives you the ability to also make a mounting system to hold the plate to the dash. You can simply tap out the center of the bracket and use some threaded rod to make a rock solid mounting system. I like to cut some aluminum strips to make "washers" and then some simple wing nuts to fasten it in the dash. The wing nuts make it simple to fasten while the dash is still in the car. You can find examples of the modified brackets and mounting system below. Note: I do not sell the mounting system, as it can vary depending on the brand and model of gauge. So I leave that to the consumer if they so choose. Example of Modified Bracket: Example of Modified Brackets Mounted: Example of Mounting System Utilizing Modified Mounting Brackets, Threaded Rod, "Washers" and Wing Nuts: Last edited by Broadfield; 06-08-2013 at 07:38 AM.. |
01-02-2013, 03:42 PM | #8 |
Trader Rating: (129)
Feedback Score: 129 reviews
Broadfield: its got shit 240s need.
01-02-2013, 06:19 PM | #10 | |
I have not had a chance to research/fabricate any new parts yet. I know that there's not much of a demand for something like that, so it's not at the top of my list. If you want to send me a vent setup and let me take my time with it, I will sell you the outcome for cheap if it works out. I completely agree! You can Paypal me at: [email protected] Please enter in the comments box what the payment is for and make sure NOT to gift the payment. Also make sure your correct shipping address is associated with your Paypal account to prevent shipping delays. Thanks, Toby |
01-03-2013, 07:38 PM | #13 |
Well there's no "modular" place to put something like this in an S14.... so no. But I can mold in anything you want in the vent area, ash tray area etc. You can find some examples of my work here:
http://broadfield.wordpress.com/custom-interior-pieces/ |
01-05-2013, 04:37 PM | #15 | |
I stand by the fact that all of my work looks like it belongs and has a nice flow to it. I'm not trying to cram 10 pounds of crap into a 7 pound bag. If everything "can" fit, then the price would range from $250 - $450 depending on how you want the gauges mounted(angled, flushed, surfaced etc.) and how you want it finished(smooth or textured). |
01-08-2013, 02:28 AM | #19 |
Is the blank plate still available?? I talked to you once about it long time ago but erased my inbox one day and lost the email we were talking in lol that and i haven't really worked on my car, if it's available I'll take it! Just need your PayPal
01-08-2013, 03:45 AM | #20 | |
Replied... thanks for the purchase!
01-28-2013, 06:22 PM | #27 |
01-28-2013, 06:32 PM | #28 |
You need to remove the 2 vents by popping each end out with a plastic pry tool or a flat blade screw driver. Once you have the two vents out, you will be able to see the plastic retaining tabs that hold the vent housing/surround in the dash... two on the top and two on the bottom per vent opening. Simply take a 90 degree hook pic and pull the taps inward as you pull/pry out on the vent housing/surround. It will take a little finesse, but should take no longer than 5 minutes. That's all that needs to be removed to install the plate.
01-28-2013, 07:28 PM | #29 | |
This guy! Makes awesome custom accessories and helps when you run into problems? Badass. |
01-28-2013, 07:47 PM | #30 |
Yeah, it can be tedious with those tabs. You almost need 10 hands so you can pry all of them inward at the same time. Because if you pry it inward and then release the hook pick to move onto the next tab, the first tab will probably drop back in. You may have to pry up a tab, place something thin in there under that tab to keep it out while you work on the next tab. Or, just pry the shit out of the tabs so you essentially bend them inward permanently... even breaking them. I doubt you will ever need to put that vent back in.
Tags |
angled gauge, broadfield, gauge, s13 gauge pod, vent plate |
