Old 12-05-2011, 09:41 PM   #1
FutureFab
Trader Rating: (32)
FutureFab is an unknown quantity at this point
Feedback Score: 32 reviews
Compound turbo rb25 in s13
Ive been running a modified stock log with ebay t70 for two years or so and I had two broken exhaust studs that were bothering me. After taking it apart and fixing them I just couldnt put the stock log back on. So I figured it was time to build a new manifold. I didnt want just another top mount either. It was time to go compound and loose the lag.
The diesel boys have been doing this for years. For those unaware how it works, basically all the exhaust runners go into the little turbo first, it spools and the down pipe goes up to the inlet of the larger turbo. A waste gate before the little turbo opens at X psi and bypasses the little turbine and is routed back into the big turbo before the turbine wheel. A second gate controls the boost of the big turbo and vents to atmosphere.
On the Compressor side, the lil turbos inlet is drawing thru the big turbo until the big turbo spools and pushes thru the compressor of the little one.
So the little turbo spools quick then runs out of top end, as its doing so, the big turbo finally has enough energy and starts making psi and takes over up top. Its a seamless transition and it works great!
I did this on a budget and salvaged parts that were either on my car or on my spare sr sitting in the back. Some things like head flange and stainless elbows I had to buy.
Hardware.
Bb s15 spec r t28
Journal bearing ebay t70 t3
Tial 44 mm to bypass t28 and feed t3
Tial 38 mvs to control boost of big turbo
Empty exhaust side.
The hardware.
I was previously making 1 bar at 4500 with my log/t70 setup. Now I am making 1 bar at 3000. This is still on pump gas. There is lots more to go, now I need to switch back to draw thru maf (maxing out with blow thru) and upgrade injectors beyond the 550s in there now. It actually has more traction in a strait line since there isnt a "hit" of power at 4500, it just spools asap and keeps pulling. If I turn the wheel just a tad, it just breaks traction and goes to limiter unless i feather it. Dont even need to clutch kick, just mash that skinny pedal and chong.
futurefabrication.com
FutureFab is offline   Reply With Quote
Old 12-05-2011, 10:34 PM   #2
Flicktitty
Flicktitty's Avatar
VERY COOL!
i've seen a few people do this on the 2JZ with great success.
IMO this is the way to go if you have fab skills, great work!
Old 12-05-2011, 11:03 PM   #3
fearlessKouki
fearlessKouki is an unknown quantity at this point
unique setup for sure!
fearlessKouki is offline   Reply With Quote
Old 12-05-2011, 11:22 PM   #4
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
this is GOOD SHIT. Impressive stuff! would love to see some videos of that..
ch1873857 is offline   Reply With Quote
Old 12-05-2011, 11:57 PM   #5
Jtuned_andy
Jtuned_andy's Avatar
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Wow, looks like a technical nightmare but if it works that is downright awesome! haha
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 12-06-2011, 11:35 AM   #6
mikey976
mikey976's Avatar
mikey976 is an unknown quantity at this point
Send a message via AIM to mikey976
i think everyone will agree when i say give us some videos
KAe-T goal 400whp with A/C - Hatch VH45 track duty - Titan VK56 tow rig
mikey976 is offline   Reply With Quote
Old 12-06-2011, 02:54 PM   #7
turbociv910
turbociv910 is an unknown quantity at this point
very cool, looks like a pita to install!
www.carolinadyno.com
s13 LSx turbo drag car- 1.42 60 ft, 6.32 1/8
turbociv910 is offline   Reply With Quote
Old 12-06-2011, 06:36 PM   #8
FutureFab
Trader Rating: (32)
Its not too bad to install, just has to be in order. Making it was the pita.
Going to the track after dinner, will take some video.
Old 12-06-2011, 11:01 PM   #9
azn2nr
azn2nr is an unknown quantity at this point
subscribed for results.
ive always wanted to do a compound turbo settup but was always troubled by the complications that come with it.
one problem that troubled me in my research was the recompression that occurs when the big turbo comes on. because the small turbo doesnt care that the air is already compressed it continues to compress it at whatever rate it can, and due to natural backpresure its impossible to slow shaft speed of the small turbo to the point that it wouldnt recompress the air. sort of like the way stacking in line fuel pumps works.
i have no direct experience with it but draw through just seems like a bad idea because of recompression.
azn2nr is offline   Reply With Quote
Old 12-06-2011, 11:38 PM   #10
mxracerjason
mxracerjason's Avatar
mxracerjason has a spectacular aura aboutmxracerjason has a spectacular aura aboutmxracerjason has a spectacular aura aboutmxracerjason has a spectacular aura aboutmxracerjason has a spectacular aura aboutmxracerjason has a spectacular aura aboutmxracerjason has a spectacular aura about
What ECU are you using. I curently have the stock RB25 ecu in mine and the two things that need to change are the rev limiter the stopes at 6100, would like it moved to 7200ish and the speed limiter needs to go. It cuts out at 123mph. I will be upgradeing to a Vi-Pec that will fix all of that, and after it gets tuned it should make about 400+ rear wheel.
mxracerjason is offline   Reply With Quote
Old 12-07-2011, 12:31 AM   #11
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
awesome, wish you had pics ofit on the motor out of the car
idahotuner is offline   Reply With Quote
Old 12-07-2011, 12:36 AM   #12
FutureFab
Trader Rating: (32)
Well my phone battery was dead so i only got one video. Need to host it then post. Will have to do until next week.
Ecu is power fc.
Imageshack wont let me log in from phone or laptop. Have to play that game tomorrow.
Last edited by FutureFab; 12-07-2011 at 01:13 AM.. Reason: didnt need to make another post
Old 12-08-2011, 07:15 PM   #13
FutureFab
Trader Rating: (32)
Finally got the video
2011-12-06_21-03-25_509.mp4 - YouTube
Old 12-08-2011, 07:22 PM   #14
rb20240sx
rb20240sx's Avatar
rb20240sx is an unknown quantity at this point
sweet setup always have thought about doing this
95 SE Serengeti sand- RB25 Neo
rb20240sx is offline   Reply With Quote
Old 12-08-2011, 07:34 PM   #15
twinspool
twinspool is on the path to ruintwinspool is on the path to ruin
that is amazing, just the other day I was thinking about this set up too hahah
twinspool is offline   Reply With Quote
Old 12-08-2011, 08:31 PM   #16
PoorMans180SX
PoorMans180SX's Avatar
Dang, that looks like a blast. I would really like to do a compound sometime in the future.
If you wanted to even add more complexity, you could add a quick spool valve to the T70. Would be interesting to see how it worked.
Old 12-08-2011, 09:19 PM   #17
AS240
AS240's Avatar
Trader Rating: (18)
AS240 is an unknown quantity at this point
Feedback Score: 18 reviews
that is awesome man! do you still have the old stock manifold you were using? did you modify it in any way?
AS240 is offline   Reply With Quote
Old 12-09-2011, 01:22 AM   #18
FutureFab
Trader Rating: (32)
No more room or else Id try and put a QS valve on there. I still need to play around with it if im going to make any more power. Ill probably go dyno to get a baseline, then up the injectors and lean on the big one a bit harder. After that is Neo cams and extra capacity oil pan.
The stock mani was modified in two ways, 1st I put a hole in the collector for tial 44, 2nd was a spacer was welded to the t3 flange of mani to space turbo out to get compressor clearance. I already sold it just to make sure I finished the project and didnt go back to stock.
Old 12-09-2011, 07:44 AM   #19
PoorMans180SX
Are you routing the copper gate to atmosphere? Doesn't that kind of waste the exhaust energy that could be going to the T70? Obviously you don't have much room to work with but...
I guess it would definitely regulate boost better that way.
Old 12-09-2011, 09:56 AM   #20
FutureFab
Trader Rating: (32)
Good eye, that was a experiment. It was using the internal gate routed back in to the big turbo. I could have left it as there was no noticable gain.
Old 12-09-2011, 11:13 AM   #21
Fred Allen Burge
Fred Allen Burge's Avatar
Fred Allen Burge is an unknown quantity at this point
I can not believe you fit all that in there! Nice work, I'm glad it actually worked for you.
Silvia, built 5.3 turbo, 4l80e, [email protected]
Fred Allen Burge is offline   Reply With Quote
Old 12-10-2011, 08:28 AM   #22
AS240
AS240's Avatar
Trader Rating: (18)
did you use a 10mm plate to space the turbo, and did you have any clearance issues with the steering shaft? i have been looking at doing this but there isnt a whole lot of info out there.
Old 12-10-2011, 10:38 AM   #23
PoorMans180SX
I PM'd you some questions good sir.
Old 12-10-2011, 11:18 AM   #24
FutureFab
Trader Rating: (32)
For stock manifold you can use a 10mm spacer on turbos with E compressor housings, like a 57 trim. My turbo had a S compressor cover, so i used two t3 flanges, one cut diagonally from one face to the other making wedges. I turned them the same way to"make a bend" away from the manifold. The second flange was then placed on for the turbo to bolt to. Down pipe clearance was close but some bends made it in there none the less.
Old 12-10-2011, 02:48 PM   #25
AS240
AS240's Avatar
Trader Rating: (18)
would you happen to have any old pics of fabing all that? my brother just got a miller dynasty 200 so i want to start fabing up my own stuff. thanks again
Old 12-11-2011, 03:06 AM   #26
FutureFab
Trader Rating: (32)
Looks like so..
Old 12-13-2011, 04:45 PM   #27
AS240
AS240's Avatar
Trader Rating: (18)
you have true talent man. im going to hopefully modify my manifold this weekend once i finish all my finals. i want to fit a pte5857 with the S housing down there. any advice that you learned along the way is greatly appreciated since this will be my first time fabricating anything. you can pm me if you do so it doesnt clog up your thread. thanks man!
Old 12-13-2011, 10:28 PM   #28
FutureFab
Trader Rating: (32)
My old megan camber arms were totally maxxed out in length and I still had negative camber, so I cut them up and made some new longer ones. They are even lighter than the old ones too. I had Eleven's Paint and Fiber blast these mofo's with a custom blend of red and pearl.
And some more compound pics..
Down pipe vs brakes
4" down pipe clearance.
Old 12-20-2011, 08:21 PM   #29
smgopedguy
smgopedguy is an unknown quantity at this point
Cool Car bro!
smgopedguy is offline   Reply With Quote
Old 12-21-2011, 01:05 AM   #30
FutureFab
Trader Rating: (32)
A couple more videos from this week...
http://www.youtube.com/watch?v=CoIf0hRRXj4
http://www.youtube.com/watch?v=G_6Hy...d1AUAAAAAAABAA
a little blurry on this one
http://www.youtube.com/watch?v=r-VJdIYTqyQ
