Old 01-05-2003, 09:07 PM   #1
DamnedButDetermined
DamnedButDetermined's Avatar
DamnedButDetermined is an unknown quantity at this point
What are the best automotive lifts, at the best prices?
I have been looking all over the internet for good prices on quality lifts, but i can't seem to tell the difference between manufacturers. I want to get the best lift i can so that it will never need to be repaired. It has to have a low ground clearance, b/c it will be lifting very low cars. I want it to lift at least 6' high. It hopefully will be under $4,000!!!!!!!!!
Here is what i have found so far...
http://www.americanautomotiveequipme...5318/index.htm
http://www.autoequipmentonline.com/a...lignlifts.html
http://www.mohawklifts.com/intro.htm
Please tell me your opinions, and what local shops are using in your area!
thanks,
DbD
DamnedButDetermined is offline   Reply With Quote
Old 01-05-2003, 11:31 PM   #2
kandyflip445
kandyflip445's Avatar
kandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfection
Send a message via AIM to kandyflip445
I've heard that snap-on lifts are good...never used on myself though. I can't remember what kind of lifts we use at school but I'll check. I like one of them but I don't think has the "low ground clearance" that you want. It is a hydraulic (sp?...really sleepy) lift. Two other ones we have are pneumatic lifts but they are in the floor. The other two are hydraulic lifts but they are pieces of ****.
How low are you talking. 2-3"? What? How heavy are the vehicles you are gonna be lifting? How high is your ceiling?
kandyflip445 is offline   Reply With Quote
Old 01-06-2003, 02:02 AM   #3
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
ha ha ha ha with snap on expect to get hit with a strap on!
Have you ever seen thier prices? yeah good quality but your not opening up a damn shop that brings in over 30 grand a month!
Why dont you go to some different shops and ask what lifts they use.
You have your lifts that get built into the ground which are more expensive and are a pita to remove if you relocate or get shut down. and then you have the ones that are bolted in.
see if they have some kind of auto lift forums.... you never know they have forums for 80's disco music
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
