Old 07-31-2011, 04:21 PM   #1
stevecorrado88
stevecorrado88 is an unknown quantity at this point
Sr20det throttle body second fail!!!!
so i keep snapping the butterfly inside the tB so im not to sure if its due to one of the screws coming loose or just something in between the peddle and the bracket on the mani, but its always the left side screw closes to the pulley and it always comes loose and the bar is snapped already when i check it.
stevecorrado88 is offline   Reply With Quote
Old 08-01-2011, 04:18 PM   #2
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
If your breaking them your going to continue to break them. Your probably running an aftermarket intake manifold and you need to make a custom bracket that lines the cable up strait with the pully.
I dont know if the stock tb is more sensitive to this but I went to an n15 tb and custom bracket at the same time and havent had issues since
4x4le is offline   Reply With Quote
Old 08-01-2011, 04:28 PM   #3
stevecorrado88
Ya I just made a bracket and make a stopper for the pedal
Old 08-01-2011, 05:20 PM   #4
steve shadows
steve shadows's Avatar
steve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfection
Send a message via AIM to steve shadows
This is why I just went straight to the Q45 TB on my last build and recommend to most of my customers now as well. Otherwise I would look into the Tomei unit or you could tack weld the bolt/butterfly piece together to make sure they are solid, I have seen that before as well. The key like others will say is to make sure the pulley is not pulling at too awkward of an angle on the arm...
Like Me on FaceBook !
steve shadows is offline   Reply With Quote
Old 08-02-2011, 07:29 AM   #5
s14unimog
s14unimog's Avatar
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Send a message via AIM to s14unimog
^Steve, Brandon, It's not that entirely. I have broken two of them as well and damaged a motor from a dislodged screw. The bottom line is that the 240sx throttle cable does not have the correct pull length for the SR throttle body pulley diameter. It's not a torsional loading of the hinge its self but rather the fact that the throttle body stop hits before the pedal hits the floor and your foot pressure is stronger than the hinge. I addressed this in two of my thread "Check your screws" and "Snapped another throttle body - SR20DET - PICS"
What is funny is that a few guys will get in here and start drawing you pictures of how you're adding extra load on the hinge by placing the pulley further out, and that is true, but NOT the reason why it breaks. The standard pulley is located more inboard so it can bottom out and deal with the stress a little better but the problem is your heavy foot not getting a chance to knock against the floor. Look on the second page of the second thread, you'll see the pedal stop I made. Stevecorrado88 hit it right on the head.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 08-31-2011, 09:41 AM   #6
stevecorrado88
Not good guys so I made a new bracket for the cable and a stopper for the pedle and after driving the car for about a month my third tb just broke. I didn't even have the tb open all the way so it would not put stress when it hit the stopper. So does anyone have any more ideas and a tb forsale??? My new plan and I had this on my old car was to us a stock sr cable holder and turn the pulley facing out and it's been working like that for years.
Old 08-31-2011, 02:40 PM   #7
stevecorrado88
Could I be forcing too much air through the tb and would not running a bov cause too much pressure on the door when it's closed???
Old 09-01-2011, 07:23 AM   #8
s14unimog
s14unimog's Avatar
^highly unlikely, how much boost are you running? You're going to need to post up some pictures or something. Ever since I made that foot stop, I haven't had an issue. Are you welding the screws on the back side or how have you caught on to these failures and not sucked in a screw?
Old 09-01-2011, 08:15 AM   #9
stevecorrado88
I have a stock foot stop, and I'm running a 3071r on 21psi.
Old 09-01-2011, 08:57 AM   #10
s14unimog
s14unimog's Avatar
see that's your problem. That pedal will not hit the foot stop before the pulley hits the stop on the throttle body. Did you not check out my threads?
Old 09-01-2011, 09:14 AM   #11
stevecorrado88
I just installed the stock stopper lastnight. I had one on there before to where the tb never hit the stopper n it still broke.
Old 09-01-2011, 09:44 AM   #12
s14unimog
s14unimog's Avatar
are you sure it was rigid enough to stop your foot pressure? I never realized, until I looked at it, but I was able to put enough pressure on the assembly to hit the factory stop, before I installed my spacer. You have to consider the minuet movements of every component when you're stomping down on the pedal. That's why I made my stopped that big, b/c I'm not pushing the pedal lightly when feathering the power in a drift.
Old 09-01-2011, 10:14 AM   #13
stevecorrado88
I'm gonna put washers under the stock foot stopper to where it doesn't hit the tb stop and I'm gonna try n weld my broken tb cuz I'm using a ka one and I would rather use a sr tb
Old 09-01-2011, 10:52 AM   #14
s14unimog
s14unimog's Avatar
I doubt that will be reliable; at least on the S14 chassis. The stopper on the floor is a flimsy piece and uses the floor to brace off of. It only has a single self tapping screw in it.
