07-09-2008, 03:22 PM | #1 |
Upgrade rear sway bar only?
I have a 1993 S13 Hatchback mainly for drifting.
Currently I have: Eibach Sportlines Springs Tokico Blues Shock Absorbers I am thinking of just upgrading the rear sway with Tanabe rear sway bar. So, I will have Front bar 24mm and 22 mm in the rear. Do you think this is good idea? http://en.wikibooks.org/wiki/Nissan_...tion/Sway_Bars If I were to upgrade both bars, I will get Suspension Techniques Front and Rear Sway Bar. Do they come with the stock endlink bushings and the bracket bushings? In the near future, I will get: Energy supspension Rack and Pinion Bushings Set Megan Street Coilover (With the coilover, do you think I should just keep the two stock sway bars and replace the sway bar bushing?) Tein Tie Rod and Tie Rod End SPL PRO V2 tension rods Rear Tanabe Sustec Strut Tower Bar If I were to do adjustment for the rear suspension, I will get: Megan rear upper control arms (RUCA) Megan Rear Toe Arms Megan rear traction rods What do you think of this setup for drifting? Thanks! Tanabe rear sway bar |
07-09-2008, 03:27 PM | #2 |
Well as a general rule, upgrading the rear sway bar will promote oversteer, but it's really dependent on the other things done to the car. If I were you, I'd do a little research on the forums, as there are a few threads on this subject already.
07-10-2008, 09:16 AM | #3 |
I want to increase the steering response. There is dead spot with my steering.
I know I should replace: Rack and Pinion Bushing (ordered from Energy Suspension; waiting for the part) Aluminum Steering Bushing Tie rods + Tie rod ends Tension rod What else should I do? I know I can get HICAS steering rack for quicker ratio, but it is over my budget. Thanks! |
