Old 12-28-2008, 07:29 PM   #1
Hashiriya415
Hashiriya415's Avatar
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
s13 moving engine 2CM back for better weight balancing
anyone every moved a KA24DE in a S13 more towards the rear.
any issues with the driveshaft? Is there enough room for the yoke to be sliding in and out of the tranny?
Hashiriya415 is offline   Reply With Quote
Old 12-29-2008, 01:33 PM   #2
smelly240
smelly240's Avatar
smelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfection
2cm isnt enough to matter i dont think. it'll change like .01% or some small amount like that.
battery relocation is going to balance it more than that. or a fiberglass bumper.
and you'll want a 1 piece driveshaft if ur going through all the shit to move the engine that tiny bit -
if you want to make a real change by moving the engine - move it back 6 inches.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 12-29-2008, 03:37 PM   #3
Hashiriya415
6" will cost me, I'm trying to do this for free 2cm maybe 3cm at the most
Old 12-29-2008, 10:51 PM   #4
alzahakar
alzahakar's Avatar
alzahakar has a little shameless behavior in the past
You would be wasting more time than it's worth. Unless you have performed every other weight reduction you can and drive in super competitive events, it's not going to do shit for you. Seeing as your driveshaft and engine are still stock and you haven't relocated the battery and you are worried about cost, leave it all alone. Do your suspension work and weight reduction if you are worried about weight balancing. Or just leave it all alone if you are just trying to impress your honda driving friends at work.
alzahakar is offline   Reply With Quote
Old 12-29-2008, 11:58 PM   #5
Hashiriya415
anyone else
Old 12-31-2008, 01:54 AM   #6
schmauster
schmauster is an unknown quantity at this point
not worth it!
schmauster is offline   Reply With Quote
Old 12-31-2008, 09:19 AM   #7
iwishiwas-all*
iwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfection
2cm??? lol buddy there s probably 1cm of horizontal play in the mounts as is, def not even worth it
IG @gabednconfused
https://www.youtube.com/user/gabedm
iwishiwas-all* is offline   Reply With Quote
Old 12-31-2008, 09:49 AM   #8
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
Assuming your only issue is the propeller/driveshaft length, you should finalise engine placement and then give the Driveshaft Shop a call. They can spec out a shaft for you.
As for your other issues, I will not comment on them because you didn't ask for comments on engine placement.
g6civcx is offline   Reply With Quote
Old 12-31-2008, 09:54 AM   #9
murda-c
murda-c's Avatar
Does your car have abs? If not u could use an abs driveshaft because its shorter.
Or you could y'know, leave it where it is so its not a pain in the ass to get to your transmission bolts and your turbo isn't even closer to your BMC.
Old 12-31-2008, 11:05 AM   #10
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
Hell, the engine probably rocks back on it's mounts more than 2cm when you accelerate. Really, 2cm?
ryguy is offline   Reply With Quote
Old 12-31-2008, 02:29 PM   #11
smelly240
smelly240's Avatar
Does the engine roll back? I dont think i ever noticed mine moving any way but side to side.
either way 2cm=stupid.
Old 01-01-2009, 02:31 AM   #12
schmauster
lean your seat back when you are driving and it will make more of a difference than 3/4 of an inch!
Old 01-01-2009, 02:39 AM   #13
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
Get subs. Done and done
"I am Norwegian, and are not familiar with your urban words :P"
jskateborders is offline   Reply With Quote
Old 01-01-2009, 02:47 AM   #14
mrmephistopheles
Inactive Admin
mrmephistopheles's Avatar
2cm is nothing. 10-20cm is worthwhile.
Koguchi had an S13 that he moved the engine back substantially on.
FALKEN DRIFT 2007 (1st car)
S15 with RB26, 27.5cm back.
Nissan Silvia S15 RB26DETT Review - Import Tuner
Originally Posted by PHLIP
