01-10-2011, 11:25 AM | #1 |
Ka24e wont start! - Help
Ok, let me give you a little history first. I changed the timing chain on my car about 3 month ago due to chain rattle/big oil leak. After I changed it the leak went away, but there was rattle at start up. As time progressed the rattle became more prevalent. On Christmas Eve the car had a really loud rattle on my way to work. While getting off the freeway off ramp the car lost power. I tried jump starting it, but I was pretty confident the battery was ok. To add to this, the week prior I noticed that when the car was idle it would run fine for 5 seconds and then the rpm drop to almost stalling then back to normal. It kept doing that.
Fast forward, I tore apart the car and noticed the timing guide was in pieces but the main culprit was the nub where the tensioner presses against broke off. I put everything back together and went to start the car. The car turned but didn’t start. Things I have done, • New battery – tested with voltmeter at 12.47 • Cleaned all ground points – tested the engine and starter ground points and all came back at 12.47 • Double checked timing – TDC on compression , cam gear pointing pretty much straight up and dizzy pointing at #1 spark plug • Code on ECU was 11 which mean crank postion sensor. I tested point A and point D per the manual and they seemed ok. • Pulled starter and took to autozone – they ran it several times and it had zero issues. • Checked wires and distributer cap with voltmeter and they were ok. • Fuel pump turns on and pulled fuel filter to see if there was gas and there was. That all the testing done for fuel • Tried doing compression but the car won’t turn anymore • Tested Ignition coil and it was fine So as mentioned the car turned in the beginning but now it doesn’t or barely turns once. It usually just makes a click when I turn on the ignition. Since the cark isn’t turning over I can’t check compression. When I turn the crank by hand it’s now very hard to turn. I can only turn it with a breaker bar (I was able to turn it by hand prior to the new chain). When I turn the crank I can feel vibration as if the crank is struggling to turn. I did all of this when it was raining off and on so I’m not sure if moisture plays a role. Before I throw my truck off the bridge I want to see if I’m missing something |
01-15-2011, 06:19 PM | #4 |
Ok, well I hooked the a remote starter to the starter to hopefully turn the motor over to check compression. When I did that the starter spun but the spindle didn't pop out and engage. I ended up pulling the starter again and had it tested. It tested fine and I saw the spindle pop out during the test.
Now I did a voltage drop test and when I crank the engine over it drops down to 9 volts...now i'm finally on to something. It's possible that it's due to engine drag but I'm not to sure as of yet...any ideas while I continue working on this? |
