Nissan Quest Alternator Problems
Hey guys. I am having a problem with the Nissan Quest alternator in my 1998 Nissan 240SX. My problem seems to be slightly different than anything else I searched. I installed the quest alternator, modified it accordingly, and got a slightly longer belt. Install went ok other than the fact that the top mounting hole for the tensioner bracket does not line up to the slot that the bolt goes through. So right now I have no tensioner on the alternator. I wedged a pry bar in the alternator and pulled against it while a friend tightened the bolt for the mounting bracket. It seems to keep tension that way but I don't want to rely only on that. Does anyone know of anything that can be done to make sure that the tensioner will mount up?
