Old 02-24-2014, 03:05 PM   #1
rj180sx
rj180sx is an unknown quantity at this point
SR20DET Burnt clutch smell
Hello again I've been a member on this forum for awhile now even though my account got deleted because I haven't used it in a while because I've gotten out of the S-Chassis for a while, but now I'm back.
I bought this S13 with a redtop SR a few months back and never had a problem with it besides a few injectors dying , turbo nuts vibrating loose and now this.
I've put a few bolt ons on the car, like FMIC, BOV, 255 lph fuel pump, boost controller, etc.
I've ran it at the drag strip a few times with slicks and done a burnout here and there and never had a problem even with the oem clutch that came with the SR until recently. The clutch started to feel weaker about a month after I last drove it hard, but it never really felt like it was slipping, but I was pretty sure it was about to go.
One night at a friends shop I decided to test that theory by doing a burnout on street tires, 1st gear was fine then when I shifted into second (to put more stress on the clutch) it slipped pretty bad and I smelled the clutch so I let off.
I couldn't get rid of the smell so I parked it in the garage for about 3 days with the Window down and the smell was gone. I drove it the next day and didn't smell anything with or without the Window up until I parked the car and got out. The smell was lingering around the car for hours. Basically the smell is always there right after I get done driving, or when it's sitting at idle, especially with the hood popped.
I know the clutch is done and the input shift bearing is bad(for months now) do any of you guys had experienced the same problem? If so is it just the clutch or anything else? I've never had this particular problem with any car before.
Any help would be greatly appreciated.
rj180sx is offline   Reply With Quote
Old 02-24-2014, 05:00 PM   #2
cotbu
cotbu's Avatar
First of all. that's not how you test for a slipping clutch!
The smell of the clutch is an indicator alone.
You test for slipping clutch in the highest gear, ease off the clutch pedal, the more the pedal comes up, the more the clutch engages. if you can let the clutch half way out it's slipping, if you let it out all the way, you need a new clutch. if the moment you ease off the clutch the car stalls your probably good. this test take more finesse the dumping the clutch.
If you know the clutch is bad well......!
Why does it matter what anyone else experienced?
No! My last 3 clutch didn't smell when the went out.
You usually change problem parts when they show signs of wear because who want's to be stranded or sitting in the pits.
Old 02-24-2014, 05:25 PM   #3
rj180sx
I know how to test for a slipping clutch. It didn't smell like it neither until I did the burnout, it wasn't slipping nor did it feel like it was slipping, I wanted to test how much more it can handle before I end up going to the track again and then end up paying for a massive tow bill.
The engagement was super high and I didn't care if the clutch completely went by doing a burnout since it was already at the shop.
The reason I asked if anyone has had the same problem is to see if it's more than just the clutch since you can smell it in neutral at idle.
Old 02-24-2014, 05:36 PM   #4
cotbu
cotbu's Avatar
OK! Gotcha!
