Old 02-11-2013, 11:09 PM   #1
GMMTC
GMMTC is an unknown quantity at this point
180sx ATS 2-Way into Q45 Housing?
I have an ATS 2-Way in a stock 180sx housing. I want to swap it to the Q45 housing so I can use the 2-way instead of the q45 vlsd and keep 4.08 gearing but with the beefier axles.
I did read somewhere that with proper shimming and/or machining the stub axles someone swapped in their s13 ring and pinion. Although I'm worried that since I'd be swapping the 2-way over it may not work with the q45 stub axles needed to run the big axles? But my knowledge is pretty limited here, so if someone could shed some light that would be helpful.
GMMTC is offline   Reply With Quote
Old 02-11-2013, 11:37 PM   #2
Kaomon
Trader Rating: (77)
Kaomon is an unknown quantity at this point
Feedback Score: 77 reviews
OOOOOO ATS deftforce, you don't see that often anymore. sorry I'm not much help, but you sir have a really really nice and clunky diff!
Kaomon is offline   Reply With Quote
Old 03-02-2013, 04:45 PM   #3
GMMTC
Thanks, I can't wait to use it
Anyone have any clue?
Old 03-02-2013, 06:54 PM   #4
240sxScores
240sxScores's Avatar
240sxScores is making a name for him/her self240sxScores is making a name for him/her self
Send a message via AIM to 240sxScores
I think you should find out and report back. Do you have both housings ?
240sxScores is offline   Reply With Quote
Old 03-03-2013, 08:29 PM   #5
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
i'd recommend contacting a reputable driveline shop, bring them both housings and both internal sets, have them compare side by side, and they can give you an accurate answer
deftforce = carbonetics. only the name changed. my first carbonetics lsd said ATS on the box.
Old 03-03-2013, 09:41 PM   #6
The Dude
The Dude's Avatar
The Dude is an unknown quantity at this point
I think you need to match the internals with the input shafts. I dont believe that your lsd is going to accept those q45 shafts. If you have both then try it and find out.
The Dude is offline   Reply With Quote
