South Western States Arizona, California, Hawaii, and Nevada. |
07-14-2005, 02:36 PM | #1 |
A/C recharge: 916 or 415?
Anyone know a place to get my A/C recharged? One place quoted me $140, is that about what it costs everywhere, or does anyone know cheaper places?
07-14-2005, 02:40 PM | #2 |
That's about the right price. Gonna be the same anywhere. I got mine recharged at Acutech.
SOLD: 91 240SX Coupe SR20DET, 05 Evolution 8 NEW: 08 Evoluton 10 |
07-14-2005, 03:12 PM | #3 |
Trader Rating: (73)
Feedback Score: 73 reviews
I got this ad here, for an A/C Performance check it's $30, from MasterCareUSA.com. But then if you already had a prob, they'd probably tell you $140 bucks to fix, plus that $30 for the inspection. LOL, so I guess that doesn't help.
07-14-2005, 04:45 PM | #4 |
i dont need an inspection, i'm fairly certain i'm just low on freon, which isn't something thats disposed of easily or messed with...i think its a gaseous substance too
07-14-2005, 08:33 PM | #5 |
Man w/ CTSV & a Car Seat
Dood, if ur sure u dont have a leak and all u need is a recharge, just go to kragens and get the charge kits. I used it on my 97 4 yrs ago when i had AC and it worked. All you have to do is connect it to the low pressure side of the compressor.
07-15-2005, 08:52 AM | #8 |
Just make sure you get a decent charge kit line with a gauge on it, dont over pressurise it. The difference was day and nite after i recharged it with those kit.
07-15-2005, 09:21 PM | #10 | |
hahaha wtf R13??? no ur car does not use R12 only the older car pre '95 i beleive uses that.... ur car uses R134a freon.... if u don't feel comfortable doing it urself i can do it right for u for a small fee plus the cost of freon....
--240sx Driver Since 2002 to 2013-- |
07-16-2005, 10:51 PM | #12 |
i wasn't sure what the cut off from r12 to r134 was, but i then checked the FSM and saw the correct chemical.
Of course, it's all moot. I have a busted hose connector that needs to be replaced. |
07-17-2005, 12:15 AM | #13 | |
07-17-2005, 10:10 AM | #14 |
07-23-2005, 12:29 AM | #15 |
I'm pretty sure the cutoff was 93 - so my understanding is:
-93 = R12 94+ = R134a go to kragens or autozone - you can get the bottle + valve for around $40 max
93 S13 Vert: KA, 5 Spd, intake, exhaust, coilovers, etc 94 bronco: 6"+35" |
07-23-2005, 12:40 AM | #16 |
Well, I just had my low pressure/suction hose replaced and the whole system recharged at a shop. Part cost me $112, work $200. Shit.
Anyone need the upperhalf of the low pressure hose? I only needed the lower section |
07-24-2005, 02:39 PM | #17 |
I bet its the low pressure line that connects to the compressor. Ive known like 3 S14 guys who broke that shiet *including me* I bought the part from nissan *$180 iirc* bought 3 of those recharge kit and it worked for me. This was in NJ so i wasnt sure if cali sells em still. But i coulda sworn ive seen those same kits at kragens.
07-24-2005, 04:06 PM | #20 |
FYI R12 is ozone depleting, thats why it was taken off the market. R134 will work, but if your freon leaked out any leaks are essentially going to be bigger ones with 134 because the molecules are smaller. They do make this stuff that you can pump through the AC system which is UV sensitive, so you run the car for a couple minutes then use a blacklight to find where the leak is coming from. then you replace that part.
07-24-2005, 04:31 PM | #21 | |
damn u got ripped off... u should have came to me to get ur a/c work done... i just finshed installing my a/c in my sr20det powered s13... i had to get the high side and low side lines refitted to work with the newer compressor and everything works now... total cost was $132... $22 for two cans of r134a, $100 for two lines to replace all rubber hoses and compressor fittings, $10 new reciever/dryer.... now i have cold ass air coming out of my vents....
07-24-2005, 04:36 PM | #22 | |
just a matter of circumstances...you didn't post in time, therefore he didn't go to you...lol i mean everyone who can't do a certain task is bound to get ripped off in some ways. he paid for labor too, remember, it's like $80-90 per hour. and jon, did you even save the pressure gauge? because buying r-134a alone is only a few bucks (like $5-10). it's the gauge that was expensive. |
07-24-2005, 04:57 PM | #23 |
sorry, everything's gone, except for that upperhalf of that line. I've been cleaning out alot of the stuff lying around my house so if there's any random spare parts you need, let me kno fast!
07-26-2005, 08:07 PM | #25 | |
is all of that really necessary to do a recharge? I tried the r134 refill only and it seems like the a/c only wants to work when I'm not at idle wtf is up with that? Is it because I didn't get all of that junk in that ebay auction?
2004 Honda S2000 NFR | 2007 Acura TL CBP | Project ***Coming Soon*** |
