Old 05-08-2009, 10:54 PM   #1
ttLOVEjh s13
ttLOVEjh s13's Avatar
ttLOVEjh s13 is an unknown quantity at this point
Send a message via AIM to ttLOVEjh s13
s14 what size s14 rear sway bar is good for drifting....?
I'm planing on upgrading my rear sway bar for sliding... just really want to know whats the right Size/brand I should get.
GamerTag:JHLOVETT
ABS?? We dont need ABS where we'er going
ttLOVEjh s13 is offline   Reply With Quote
Old 05-09-2009, 09:32 AM   #2
2fizzleforshizzle
2fizzleforshizzle is an unknown quantity at this point
I run a 22mm adjustable progress bar on my s13. Solid on the stiff setting!
2fizzleforshizzle is offline   Reply With Quote
Old 05-09-2009, 07:37 PM   #3
ttLOVEjh s13
my wife have the same set up on her s13 with the 22mm on the rear. but i want to know whats good for the s14....
GamerTag:JHLOVETT
Old 05-11-2009, 12:45 AM   #4
NME-S14
NME-S14's Avatar
NME-S14 is an unknown quantity at this point
ive heard tanabe sustech are nice.
whiteline are legit, no crazy labels just performance. they have been in the game a LONG time so they are really good.
im getting st(suspension techniques) there lime green, beefy and come with end links when you get em from enjuku racing.com so there backed by them and on there cars.
NME-S14 is offline   Reply With Quote
Old 05-11-2009, 12:46 AM   #5
redsx13
redsx13's Avatar
redsx13 is an unknown quantity at this point
just get something that is both thick and adjustable, that way you can play with it a little. Just because someone runs a certain size bar doesn't mean that's what you should buy, some peoples opinions/setups can be completely wrong and usually are.
redsx13 is offline   Reply With Quote
Old 05-11-2009, 04:26 PM   #6
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
OE SE rear bar and put the savings into coilovers and your golden.
Alot of ppl dont even have a rear sway bar, or at least disconnect an endlink. Some decent springs should be good enough.
Bigsyke is offline   Reply With Quote
Old 05-11-2009, 06:37 PM   #7
ttLOVEjh s13
I have coilovers already, Drift Speed hook it up. they sold me there kei office setup from there s14...
GamerTag:JHLOVETT
Old 05-12-2009, 01:04 AM   #8
redsx13
redsx13's Avatar
why?? wouldn't that drastically increase the rear grip and increase the front causing understeer??
Old 05-13-2009, 06:23 AM   #9
redsx13
redsx13's Avatar
im even looking for some input on this, anyone want to clarify?
Old 05-13-2009, 09:22 AM   #10
ballinnmiami240sx
ballinnmiami240sx's Avatar
ballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura about
I think he got it backwards. alot of people disconnect the front swaybar. I run stocker. Work on them handz daddy!!
1994 FD3S Drift // 945garage // sumospeed.com
ballinnmiami240sx is offline   Reply With Quote
Old 05-13-2009, 05:32 PM   #11
Timeattack_S13
Timeattack_S13 is an unknown quantity at this point
Tanabe Racing Development USA /inc.
27.5 mm diameter bar -- good for the drift. But thing is, I called Tanabe, and they actually have stiffness numbers for the swaybars. It's a lot more useful than just knowing how big the bar is... that way, you can really tune your suspension stiffness... like add in the stiffness of the springs + swaybars and get some really good calculations.
Timeattack_S13 is offline   Reply With Quote
Old 05-13-2009, 09:01 PM   #12
redsx13
redsx13's Avatar
Im actually thinking of changing my rear sway out for a smaller one because my 240 oversteers way too much, its only with crappy tires though, with good tires its perfect, but its not always easy to find good used tires.
