Old 03-27-2011, 08:42 PM   #1
Gription
Gription's Avatar
Gription is an unknown quantity at this point
Send a message via AIM to Gription
SR20 Autometer Tach+tach adapter install??
I'm trying to get my auto meter tach to work with my s14 sr. I have the auto meter tach adapter (part # atm-9117) and an Ultralite series 3 3/8" gauge but it still doesn't seem to work.
The tach is wired properly so no worries there, but I'm not sure if I have the tach adapter wired right or not. The way I have it is:
Black- Ground
Gray- To Tach Signal Input
Red- Coil Packs 12v+ wire (blue wire on engine harness)
Red/Green- Coil Packs 12v+ wire (same as above)
This is how the instructions seemed to reccommend but I am still getting no reading at all on my tach. I'm trying to find info from someone who has done this before since all the searches I've found come to a dead end.
I know there are people out there using auto meter tachs on sr's so please chime in if you can help! Thanks
Gription is offline   Reply With Quote
Old 03-28-2011, 09:13 PM   #2
Pantaloons
Pantaloons's Avatar
Pantaloons is an unknown quantity at this point
the red wire should be an acc wire i think
Facebook
Twitter
Pantaloons is offline   Reply With Quote
Old 03-29-2011, 06:33 AM   #3
Gription
Gription's Avatar
I had it going right to the battery and it still didn't work
Old 03-29-2011, 09:16 PM   #4
Gription
Gription's Avatar
so I read somewhere that you're suppossed to tap the red/green signal wire from the tach adapter to all 4 coil pack signal wires after they leave the igniter chip, but I'm hesitant to try it because it seems like every time one coil pack get a signal then it would send the signal to the other three as well since they would all be connected to the same wire. seems like a good way to fry an ecu, but I could be wrong..?
Anyone??
Old 03-30-2011, 01:58 PM   #5
napz510
napz510's Avatar
Trader Rating: (36)
napz510 is an unknown quantity at this point
Feedback Score: 36 reviews
Black- Ground
I know there are people out there using auto meter tachs on sr's so please chime in if you can help! Thanks[/QUOTE]
On the coil pack 12+ wire, cut it and the other end connects to the red and the other connects to the red/green. I think this is what I did...just try it.Goodluck!
napz510 is offline   Reply With Quote
Old 03-30-2011, 07:02 PM   #6
Gription
Gription's Avatar
hmmmm.... that makes sense. will try it and let you know. Thanks!
Old 03-30-2011, 09:08 PM   #7
Gription
Gription's Avatar
Definitely worked. Thanks a million man!
Old 12-14-2011, 01:36 PM   #8
patsS14
patsS14 is an unknown quantity at this point
which coil pack did you use for the cut??
patsS14 is offline   Reply With Quote
