Old 12-19-2010, 02:26 AM   #1
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
Thumbs up SupaDoopa's supa awesome buildasaurus!
So, I figured I'd start one of these eventually and suppose now is a decent time seeing as I have nothing to do and insomnia is setting in pretty hard. I tried to include anyone who helped make it possible and trust me - it is a constant on-going build that I will always be fiddling with so be sure to check back as things are always going to be different in one way or another.
Anyways, a few months back, I traded my '99 Miata that was slammed on the ground with some nice wheels for a '91 240SX hatch that was COMPLETELY spotless meaning no rust, no rot, nothing at all. It had a ding here or there, but that's easily fixable; rot, well, not so much. I've had a few before but only beat the crap out of them and went from shell to shell and I figured this time I'd go big and do it the right way - no cheap imitation crap, no cut corners, no half assing. So, I got started. The first thing I did was rip out the KA-T motor and get rid of it. The idea was to go SR20DET. Now, I don't hate the KA24DE's, just not the build I was intending on running with.
Below is how I got her [minus the wheels, it came with some gross ricer wheels I put in storage as spares that will do me no good now - read on to realize why] and she needed help. She was a HICAS car with ABS which sucked but good came out of it in the form of a VLSD and power options which I don't mind the least bit. She did have some crappy intercooler piping that was all mismatched to barely work and a FMIC that was pretty hurt.
This is the modified list of the things it had when I picked it up. I was told when I picked it up there was more/different parts but after hard investigation, half of the stuff was missing or not as quoted.
Engine:
S14 KA24DE
S14 T28 turbo [which was blown]
HKS wastegate actuator
HKS Super Dragger 2 [3.25" exhaust]
Custom made bottom mount manifold and downpipe [cracked to shit]
370cc injectors
Clutchnet 6-puck unsprung clutch [destroyed and it was OEM]
Solid aluminum motor and transmission mounts
Chassis:
Function & Form type 2 coilovers
Tein tension rods
Inner tie-rod spacers [non-existant]
VLSD differential
Interior:
KPH cluster
SPOTLESS interior
Carbon fiber vent block for 2 gauges [was in the trunk somewhere]
AEM UEGO
AutoMeter boost gauge
TRUST E-manage to tune with support tool [didn't like to work a lot, faulty wiring]
Exterior:
SE lip
SE wheels with rubber
Wingless hatch with covered holes [he covered them with duct tape]
This is the motor I picked up. It's a S13 blacktop with perfect compression. Only issue was the clutch fan was missing two fins which is something I can overlook. I ended up going electrical fans anyways so the fact it had missing fins wasn't even a concern. Harness and everything looks almost perfect minus a little build up around the throttle body but with some cleaner, she was fine. Some people say don't trust JDM Engine Depot [jdmenginedepot.com] but for the most part they were pretty good. I went to pick up the motor which is the mistake a lot of people have. Some plugs were cut but I had a spare harness so it wasn't a big deal. Only thing that was missing was an ignitor, really. I'd do business with them again [but as others have warned, I wouldn't have them ship unless you plan on gambling].
This is the heart transplant of me removing the motor. I didn't have a good camera at the time so excuse the kinda crappy pictures in some of these. Blackberry's fail with photos.
Very shortly after acquiring the motor and removing the KA-T setup, I hit up some vendors [MVPMotorsports, FRSport, and 240SXMotoring - all are GREAT companies to work with] and started getting some parts for the build. Surprisingly, some of the product I got seemed better than I anticipated. It was more of a "get parts to have it run and get something a little better later on" kind of thing, but after examining everything, I'll probably roll with it all.
After the motor was completely out and everything was in order, I put the SR20DET back in the Nissan Titan and headed a state over to drop my car at Fujii-SPL to get the motor dropped in, tubs added, and a little swag. I HIGHLY recommend these guys - they're very professional, skilled, and priced WAY below the product they put out. I was so impressed with what they've done and I highly recommend them like I said. Their power steering lines are top notch! They even did a few custom items for me for free. I can't say enough great things about them. This is what the car looked like when it was unloaded off the car trailer and in transition to when the OEM tubs were cut and the new wells were tacked in.
As they worked diligently, I had a couple color schemes I wanted to roll with ultimately leading with purple engine bay with hella flake, white exterior, and at this point the wheel color isn't too important. With that said, the color I went with came out BEAUTIFULLY. Don't mind how the color looks different in a few pictures - the lighting REALLY brings out the colors. In the sun, it's brilliant.
Then the bad news came in that the T25 was blown. It didn't really bother me because I planned on going bigger as I had a GT2871R laying around. I meant to rebuild it as it had a few rock chips on the fins that really just made me want to fix it; I am HELLA OCD with that kind of stuff. So, with that aside, I decided to go buy a brand new S15 Spec-R dual ball bearing T28 with STANCE reclocking kit and gaskets, tubes, and pipe kit from Nissanparts.cc which also helped me out. While I was in shop-mode pre-black Friday, I decided to buy a few things to replace the bland interior crap that will get me raged looking at for any longer which were the steering wheel and seat. It came with single cam seats but the driver's side was beat to hell like they all are from entering and exiting the car. I replaced the wheel with a PERSONAL deep dish 3-spoke and the seat with a REAL, yes REAL, Bride VIOS III Low Max sitting on BRIDE FG super low seat rails.
Then I heard back from Fujii-SPL that the car ran with no knocks, noises, ticks, or any issue at all which was GREAT news. I did take the valve cover to examine the motor but that doesn't tell me anything about the bottom end and I didn't really want to rip apart the motor that looked mint so I rolled the dice and lucked out. This is the teaser picture they e-mailed me.
When I got that, I basically shit my pants instantly. The car looked 110% better under that hood. Everything was clean, perfect, and again clean. Granted it's going to be changed thirty times over, in her current state, she's a pretty girl. And this is how she looks now. These pictures are actually a couple days old, so they're not completely current. As the days go buy and I get more done, I'll snap some pictures.
As of now, this is the setup:
Engine:
S13 SR20DET black top
Semi-wire tuck done professionally by Fujii-SPL
SPEC Stage 4 6-puck sprung clutch
NISMO motor mounts
NISMO tranny mount
NISMO oil cap
ISIS radiator
ISIS radiator hosing
ISIS twin radiator fans
ISIS FMIC
ISIS FMIC piping
HKS flanged hot pipe
HKS SSQV
Megan turbo elbow
Fujii-SPL power steering lines [See them here!, GREAT guys]
Fujii-SPL metal coolant reserve tank
Chassis:
PBM RUCA's
PBM toe arms
Tein tension rods
VLSD diff
Super HICAS delete [full system deleted from pump to subframe]
ABS delete [new hard lines run]
Z32 30mm aluminum brakes
Z32 e-brake conversion
Ichiba 5-lug conversion hubs
Muteki SR35 purple locking lug nuts
Z32 1 1/16 BMC
Interior:
PHLIP #15 pool ball shift knob
KPH cluster
PERSONAL 6-bolt 3-spoke steering wheel
NRG 2.5 quick release
NRG slim hub adapter
BRIDE VIOS III Low Max [driver]
BRIDE FG super low seat rail [driver]
AEM UEGO
STRI 52mm DSD electronic boost gauge
Relocated battery to the trunk
Exterior:
SE lip
MB Battles 17x9.5 all the way around
Wingless hatch
Vertex body kit
I also have a massive for sale thread trying to get the missing pieces to getting her run a little better. I'm trying to snag some 550cc injectors and either PowerFC or NISTUNE. I've got plans to do so much more so sit tight and let me know your questions, comments, things you would have done differently, but please keep the flaming and bullshit to a minimum.
Special thanks thusfar:
NissanParts.cc - Your #1 Source for OEM Parts and Accessories
www.FujiiSPL.com
MVP Motorsports
www.240sxmotoring.com
FRSport.com - Aftermarket Performance Parts
www.Zilvia.net
240sxONE
Old 12-19-2010, 02:28 AM   #2
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
RESERVED for futher content.
Old 12-19-2010, 02:34 AM   #3
4DOOR_LIFE
4DOOR_LIFE's Avatar
That engine bay is pretty awesome. Diggin the color, but its screamin for an ISIS turbo manifold or something other than stock.
can't wait to see the progress, looks really good so far. Wish i had this kind of money to put into my daily.
Instagram: @Elegant.Company
Old 12-19-2010, 02:37 AM   #4
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
I actually plan on going tubular with MAZWORX when I get that GT2871R up to snuff and snag an external wastegate and such.
Old 12-19-2010, 06:27 AM   #5
apex
apex's Avatar
Trader Rating: (44)
apex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond repute
Feedback Score: 44 reviews
build looks good but wtf happened with those tubs??
Red Rocket
apex is offline   Reply With Quote
Old 12-19-2010, 12:54 PM   #6
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
What do you mean, what happened to them? They're wider than what people run so it has a little notch in it. They aren't the small ass trailer tubs people hack up and use - fully custom.
Old 12-19-2010, 02:43 PM   #7
xBtony
xBtony's Avatar
God damn im in love with that engine bay. the color is really close to what i had in mind for my car. Looks dope dude. I like how huge the tubs are too. Nice work.
xBtony is offline   Reply With Quote
Old 12-19-2010, 02:43 PM   #8
Magnum375 Jr.
Magnum375 Jr. is an unknown quantity at this point
Looks awesome, For the time being you could sand down and try to either polish that exhaust manifold or repaint it with some black hightemp paint.
Magnum375 Jr. is offline   Reply With Quote
Old 12-19-2010, 02:51 PM   #9
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
I'm digging the purple. Keep it up, we need more!
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 12-19-2010, 02:55 PM   #10
Sileighty_85
Sileighty_85's Avatar
Very Nice, I Love the Color as well.
Nah take it to a machine shop ans they can wire brush the ports and throw it in a tumbler.
I had mine cleaned for $20 then painted with VHT paint.
Paints been holding great so far (2 months). Just follow the instructions on t he can, Primer it and bake it.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-19-2010, 03:03 PM   #11
holybushoffire
holybushoffire's Avatar
holybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant future
Send a message via AIM to holybushoffire
How much clearance do you have between the hotpipe and tub? it looks pretty close.
"I am not good English, I like the drift"
CHINA DRIFT
"some guys have a better relationship with their car than their wife haha. sad but true."
SECRET SOCIETY
holybushoffire is offline   Reply With Quote
Old 12-19-2010, 04:51 PM   #12
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
I have decent clearance, and I may coat it. I have a couple things I want to do before I worry about the ONLY eyesore in the engine bay especially knowing I will be going tubular in the very near future. Going to basic in February is going to be a damper on the work for a couple months, but when I come back, the build will continue and will continue STRONG; ARMY STRONG.
Old 12-19-2010, 05:43 PM   #13
holybushoffire
Army strong and purple is a good way to support the lift on don't ask don't tell lol
Just playin, hoping to see what comes next.
CHINA DRIFT
SECRET SOCIETY
Old 12-19-2010, 05:45 PM   #14
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Haha. Wanted to originally go lime green exterior with purple accents, but kinda veered away from it - I don't need unwanted attention while just driving down the street not that I don't get that already, but I'd like to keep it to a minimum. Expect more very soon.
Old 12-19-2010, 06:32 PM   #15
tricky_ab
tricky_ab's Avatar
I'm diggin the bay so far! Keep it up!
Old 12-19-2010, 06:35 PM   #16
240SXK
240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light
This car has the biggest penis
240SXK is offline   Reply With Quote
Old 12-19-2010, 08:16 PM   #17
drift_limo
drift_limo's Avatar
drift_limo is a well-known jackass
Send a message via AIM to drift_limo
Whats the point of having tubs that are that wide?
everything else looks on point.
dirtypenguin.wordpress.com
drift_limo is offline   Reply With Quote
Old 12-19-2010, 09:10 PM   #18
smelly240
smelly240's Avatar
smelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfection
looks pretty - but working in the engine bay with those tubs is gonna suck. I love how tubs look... I just dont like the confined space. I think my turbo would def hit the tubs in your car.
For reference - mazworx manifold / billet 6262sp
I'm thinking you might wanna stay bottom mount with the lack of space.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 12-19-2010, 11:15 PM   #19
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
The point for wide tubs is to get the best possible angling I can without smashing into my OEM wells while being able to run a decent sized tire in the front. As for top mount, it was test fitted and will fit with about 2 inches to spare. I will most likely stay bottom mount, though. The tubs are only a little wider than the widest part of the strut tower - the reason they look huge is because the strut towers aren't straight up and go up at an angle, so it looks like they're massive. Also, when you hit full lock, with the angle of the tire, I want them to be able to clear as well. It's all for a purpose.
Old 01-23-2011, 06:01 PM   #20
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
UPDATED - She's almost there.
VERY SMALL amount of things to do under the hood. Rest of the time will be focused some suspension work, wheels, and interior workies.
Old 01-23-2011, 06:19 PM   #21
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
Feedback Score: 92 reviews
the purple, seems to make me like this car even more, you gonna go with a different exterior color ?
S-Nation S13 is offline   Reply With Quote
Old 01-23-2011, 06:30 PM   #22
va240dude
va240dude's Avatar
Trader Rating: (161)
Feedback Score: 161 reviews
Looking good man!
180SXオタクだ!
Old 01-23-2011, 06:46 PM   #23
Pure_JDM
Pure_JDM is an unknown quantity at this point
The reason people are giving you shit about your tubs is because they ARE overkill. There's no way they allow anymore steering angle than "hacked up trailer tubs", because you're limited in THAT extreme of an angle with the rear of the tower. All in all I like your engine bay... it looks really nice with the purple, I just figured I would let you in on why the criticism. And they ARE going to make working on the engine a bitch.
Pure_JDM is offline   Reply With Quote
Old 01-23-2011, 07:49 PM   #24
wannabdr1ftr
wannabdr1ftr's Avatar
wannabdr1ftr is an unknown quantity at this point
That purple looks awesome...i love where this thread is going. Those tubs are intense though.
wannabdr1ftr is offline   Reply With Quote
Old 01-23-2011, 08:57 PM   #25
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
I'm in love with the color of your engine bay.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 01-24-2011, 01:01 AM   #26
MJenkins1101
MJenkins1101 is an unknown quantity at this point
It's absolutley gorgeous, when do we get to see the body painted?
MJenkins1101 is offline   Reply With Quote
Old 01-24-2011, 03:10 AM   #27
drift_limo
drift_limo's Avatar
This is exactly what I was thinking.
Old 01-24-2011, 03:44 AM   #28
daftphunk
daftphunk's Avatar
daftphunk is an unknown quantity at this point
Color of the engine bay made me re-read through this topic. Those huge ass pics are almost as big as your tubs, but that's cool. Hope it all works out.
daftphunk is offline   Reply With Quote
Old 01-24-2011, 03:58 AM   #29
anton1o
anton1o's Avatar
anton1o is an unknown quantity at this point
Send a message via MSN to anton1o
Yerrrrrr boi!
anton1o is offline   Reply With Quote
Old 01-24-2011, 07:24 AM   #30
tricky_ab
tricky_ab's Avatar
Any current plans for the exterior?
