what do I need for a racing seat?
Just the seat, bracket and harness, correct?
Would these work together? Corbeau Forza Fixed Back Racing Seat - Enjuku Racing Parts, LLC Circuit Sports Super Low Double Lock Seat Rail - Nissan 240SX S13/S14 89-98 - Enjuku Racing Parts, LLC OMP Road 4 4-Point Street Harness - Enjuku Racing Parts, LLC And is there a way to mount the harness without a cage or a rear strut bar? Can I bolt it to the seat and the oem seatbelt points? |
![]() Join Date: Apr 2008
1: if your putting a harness in, then your taking preventive measures to insure your not thrown from the car in case of a rollover etc.
2: if you don't have a cage and just a harness bar then your relying on the roof to not completely collapse on you and if that's the case then the factory belt will heed the same results as a harness without a cage. 3: bolting that shit to the floor is tacky and completely fucking retarded and unsafe read/scroll and have a look Installation- and Operating Instructions |
![]() Join Date: Jan 2010
Trader Rating: (26)
I lul'd.
If you're going to half ass it, then don't do it at all. If you want to look dope with a racing seat and mount your dope harness somewhere stupid and get into an accident, you'll probably die. Step 1: Have a respectable car to your setup in. Step 2: Have a safety approved seat. Step 3: Have brackets for said seat. Step 4: Have approved, non-expired harnesses. Step 5: Have a proper harness bar to mount said harness. Step 6: Mount your harness, seat, and brackets. Veer away from any steps and you're probably going to die. |
![]() Join Date: Oct 2006
Trader Rating: (35)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 35 reviews
Have you sat in that seat? You need to sit in the seats you are considering buying. Nothing worse than buying a seat from an online store , then it arives and feels crappy or you dont fit, then you have to pay to return it, and then you have to pay a restocking fee. Just take those into consideration.
#11 | |
Trader Rating: (26)
You could always measure yourself and compare them to the measurements that they supply. Every company supplies exact dimensions. Maybe you can sit in friends seats, too. If you don't have a single friend or know someone who has seats, then maybe it's a sign.
ha.ha.ha. you're quite the asshole aren't you?
Trader Rating: (26)
No. I gave you a little bit of common sense and you had a stupid remark. It's called measurements. That's how seats are put together. Measure yourself, compare it to the measurements of the seat you want, and bam; you've found the seat that'll best suit you.
Before you even think about buying a seat, harness, and brackets, maybe you should invest in a cage with a proper harness bar because if you mount the harness on the floor [as advised more than once], you'll regret it. It sounds like you're more about budget style anyways so do what you want. We're just advising you how to do it properly, safely, and a way that won't make you look like a complete retard. And with that, mods: close this shit. It's another one of 'those' threads. |
![]() Join Date: May 2009
you guys should see dude's other threads. "is it hard to get good at drifting? is it easy? are some people better than others?" and "i've got no driving experience whatsoever. I've only driven three competitions, how long will it take me to get good at drifting?"
#17 |
![]() Join Date: Oct 2011
Why do people think harness bars are acceptable?
Not trying to start shit, just wondering where and when it became ok to use a harness bar outside of a slow-speed event like an AutoX. And OP, Google is your friend.
May the bridges I burn light the way. |
Well dude, keep things in perspective. You're asking a relatively easy question that you could probably answer yourself with a few minutes perusing Google.
Plus if you're asking us how to install a "racing seat" in a "race car" then you're totally fucking doing it wrong bud. Please do some research about safety equipment and the necessity to use such hardware in case of emergency. We don't put Takata harnesses on our S13's to try and pose it off as cool. Let alone use Chinese fake parts such as Circuit Sports seat rails to keep us safe and planted. I'd rather not fly out my car thanks ![]() Stick to OEM for now as it can actually save your ass. Later add a bucket seat that is FIA-approved with known-good rails such as Bride/Buddy Club/Sparco. Worry about harnesses when you need it; you'll know when you do |
#21 |
![]() Join Date: Jan 2013
I'm not sure if anybody mentioned this or not since I only skimmed the thread but the forza seat you are looking at is bottom mount and the rail that you have posted is for sidemount seats. Its best to stay away from bottom mount seats like the forza because they tend to sit high in our cars. Since you are looking for a cheap seat I would check out the buddy club seats since they are the about cheapest sidemount seats that I would trust.
Also like others have said I strongly advise against running a harness without a cage. Not only is it unsafe to have mounted at the wrong angle but it is also dangerous to have (even with a harness bar) in the off chance that you roll your car because you can't duck down like you can with OEM belts. Just some food for thought. |
#22 |
Take it from my brother, the crash test dummy. It is better to at least have a harness bar in case of a crash.
First time he crashed, he had racing harnesses connected right to the floor. Killed his back. Next time he had an accident, he had a harness bar, and it at least didn't make him bed ridden for a week. If you ever happen to check out Formula D, they usually have multiple seat manufacturers there with seats for you to try out. Some can be really tight and uncomfortable. I am very skinny and found some seats to be very confining. I don't know what you will be doing with your car, but if you are racing, a lot of places will require a roll cage. If you want racing seats just for looks, just forget about the harnesses and stick to stock seatbelts. |
#23 | ||
