Old 10-10-2010, 12:09 PM   #1
frost318
frost318 is an unknown quantity at this point
changed slave and master now cant get in gear.
I have a s14 sr20det. I recently had a problem with my clutch sticking to the floor. I Checked the slave cylinder and i had a leak. So i decided since i was going to change my slave cylinder i was going to do the master also. After installing both with oem parts on the car. So i started the car and tried to put it in gear could not get it in gear. My question is if the car starts then why i can not get it in gear?
frost318 is offline   Reply With Quote
Old 10-10-2010, 02:43 PM   #2
modulation
modulation is an unknown quantity at this point
They have nothing to do with each other? You can put the car in gear with it off..
Did you bleed your master/slave after you replaced them? Get rid of the clutch damper if you did it probably has air in it, and makes bleeding a pain in the ass.
If you refuse to get rid of your damper then put your car on ramps and bleed it that way.
modulation is offline   Reply With Quote
Old 10-10-2010, 04:33 PM   #3
frost318
I bled it down but i still have the damper. i will try to remove it.
Old 10-10-2010, 08:03 PM   #4
nismoracingsx
nismoracingsx's Avatar
Trader Rating: (32)
nismoracingsx is an unknown quantity at this point
Feedback Score: 32 reviews
+1, sounds like huge air pocket
nismoracingsx is offline   Reply With Quote
Old 10-10-2010, 08:24 PM   #5
wyteboichris
wyteboichris has a spectacular aura aboutwyteboichris has a spectacular aura aboutwyteboichris has a spectacular aura aboutwyteboichris has a spectacular aura aboutwyteboichris has a spectacular aura aboutwyteboichris has a spectacular aura about
did you make sure to bench bleed the master cylinder before pedal bleeding the slave? If not that's probably the issue. Once you have tried that, if it still persists, you probably have a bad master cylinder (although it is "new" wouldn't be the first time)
Signature Infraction! Read the Rules for Signature Sizes..
wyteboichris is offline   Reply With Quote
Old 10-12-2010, 12:07 PM   #6
frost318
I did not trying bench bleeding. I will give it a try and see what happens. thanks
