Old 05-23-2005, 03:13 PM   #1
Hypertek99
Hypertek99 is a well-known jackass
Need help taking out the dash.
I know I know do a search. I did already and didn't find anything. I'm doing a digital swap right now but can't seem to get the dash out. It's the face piece in front of the gauge cluster that i can't get out. Has anyone done a whole swap on this??? I got the HUD dash so that's why i'm taking out the dash.
Hypertek99 is offline   Reply With Quote
Old 05-23-2005, 07:41 PM   #2
kouki-gymkhana
kouki-gymkhana is on a distinguished road
Check out the pictorial walk-through on www.jdmrice.com.
**The atypical S-chassis enthusiast***
kouki-gymkhana is offline   Reply With Quote
Old 05-24-2005, 12:18 PM   #3
Agent_S13
Agent_S13's Avatar
Agent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to all
Thanks kouki-gymkhana for the reference post!
Just what I was looking for!
Another bookmark for my dash removal!
-Aaron
'91 240sx coupe
Agent_S13 is offline   Reply With Quote
Old 05-24-2005, 01:14 PM   #4
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
dash removal is pretty straightforward. just a few bolts, screws, and blammo, gauge access.
MakotoS13 is offline   Reply With Quote
Old 05-24-2005, 05:47 PM   #5
daredevildoug
daredevildoug's Avatar
daredevildoug is making his/her stupidity well-knowndaredevildoug is making his/her stupidity well-knowndaredevildoug is making his/her stupidity well-knowndaredevildoug is making his/her stupidity well-known
and dont forget to drop you steering collum. it makes life a whole lot easier..
-de
daredevildoug is offline   Reply With Quote
Old 05-25-2005, 03:34 AM   #6
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
you don't need to remove the dash sir.
Take off your steering wheel cover
Bolt down the steering column (the nuts are red)
unbolt your stock cluster out.
Getting the digicluster's wiring in there is a slight challenge if you've got burly hands.
SochBAT is offline   Reply With Quote
Old 05-25-2005, 10:56 AM   #7
Hypertek99
Thanks for the site. Really made it easier to drop the steering column. I got the digital cluster in, but i have a few more questions. When i'm at a stop the speedo reads 7mph. Do i need to get it recalibrated??? also my seatbelts don't do back when i open and close the door now unless the key is in the ignition.
Old 05-25-2005, 05:15 PM   #8
Xren17
Xren17 is an unknown quantity at this point
I'm assuming that you're putting in JDM cluster. If you need to adjust in order to read MPH instead of KPH you can go here. Also I think you can recalibrate the speedo yourself if you read the instruction below.
http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=1
Xren17 is offline   Reply With Quote
Old 05-26-2005, 11:29 AM   #9
kouki-gymkhana
Ummm, I thought that's how the seatbelts are SUPPOSED to function. They go forward when you open the door regardless of whether the key is on but only go back when the key is on.
