Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
02-13-2003, 04:20 PM | #1 |
New Title
Coupe vs Fastback
For racing, which one is better and why?
Looks like all of the factory nissan race cars were fastbacks. But everybody who races in ITA (dono about s13's in its, have yet to see one) runs a coupe. Tnord and I were talking about it and just had guesses but no real answers. Coupe is stiffer/lighter stock vs stock compared to the fastback from everything i've heard. But given minium weights and a roll cage, it seems like they would be equally stiff and light. So, since the fastbacks are more aerodynamic, why isn't it the choice for club racers in the US? Only answer I could come up with is maybe the s13 can't reach its minium weight? For the factory racing, I guess they have gobs of power and aerodynamics is more important than 30lbs or however much? If anybody knows or cares to join in on the guessing...
02-13-2003, 05:03 PM | #3 | |
But I also have heard about the coupe bieng stiffer and all.
PROCEED Grip Gambler |
02-13-2003, 05:59 PM | #4 | |
New Title
02-13-2003, 07:09 PM | #6 |
ah yes that too
but you can get the whole hatch in fiberglass... dotn know about what class it is in though, not too keen on that stuff, still learning |
02-13-2003, 08:12 PM | #7 |
Isn't it possible to have a complete roll cage in those race cars? If so, then you just use that to get all the stiffness you need. The body is just a body, hatch or coupe. The hatch is more sporty, some might say and that's why they went with it. It is also probably more aerodynamic. Also, there aren't any s14 hatchbacks, so there's only going to be s14 coupe ITA cars. If I had a race car of that caliber, the body would be as few of peices of fiberglas as possible and the structure would just be tube frame. I don't know if that is legal in all those classes, but I'm sure you can get really close by bending rules and such.
Adam '89 coupe KA24DE+T 14.1 @ 104 MPH '88 Celica All-Trac turbo stock, but no more ecu codes!! |
02-14-2003, 03:23 AM | #8 |
fastback is faster
"fast"back ---> fast! coupe ---> just coupe (ex: can a have a coupe of coffee please?) bad joke
==>>TGL GARAGE<<==.. RIP! S13 coupe KA-T @ 0.5 Bar = SOLD! A31 Cefiro + SR = Current |
02-14-2003, 09:36 AM | #10 |
Rollcages under SCCA IT rules are only allowed a certain number of attachment points (8) and then only at particular locations. Most 240s that you will see racing today are running in ITA or ITS and follow this rule. The older factory cars and some other efforts existed in the GT2 and GT3 classes where tube frame cars were allowed. Absent a tube frame, there is no way make the hatch as rigid as the coupe.
Also, unlike GT cars, IT cars must use original body panels. Carbon fibre and fibreglass replacement panels are illegal (as are lexan windows). Thus, there is not way to overcome the weight of heavy glass in the hatch. Also, while weight rules may ultimately put both the hatch and the coupe at the same minimum weight, the weight in the hatch is located in a horrible position, relatively (high and at the back of the car). There is no "bending the rules" in IT -- you will be protested, they will dismantle your car, and you will be disqualified. See, AARC runoffs where MANY top cars were DQ'ed after a visit to tech. While the fastback might offer a few more mph on the straights, the added weight and weaker chassis make the coupe a better race car for club racing. Where rules are more open and money is no object, the fastback's aero-vantage would make it the winner. See you next week - hopefully w/ pics of a new toy. mark |
02-14-2003, 10:51 AM | #12 |
Well i hear that coupes the the best because of their lack of weight, but i could say the FB would be easyer to add a roll cage to because of its openness. And its much easyer to gut that whole 2lb if that from the hatch, and its easyer to take out the seats, if that even makes a diffrence
02-26-2003, 01:40 AM | #13 |
how much does the glass on the hatch weigh? i know my hatch is really heavy. my struts are bad so i have to use a stick to prop up my hatchlid..
are there any negatives to using a lexan windows? how do they shatter? in shards or large chunks? and how clear is it? and resistan to heat? or direct sunlight it would suck if it melted in the hot cali sun. |
02-26-2003, 02:35 AM | #14 |
Wouldn't the better weight distribution of the hatch give it a slight advantage as well?
Pros to hatch: better weight dist. and better aero. Pros to coupe: lighter and more rigid rear end. Am I missing anything? just how much more rigid is the coupe, and what difference would this make (if any) that wouldn't at least partially be negated by it's poorer weight distribution? |
02-26-2003, 08:46 AM | #15 |
Any weight distribution disatvantage there may be is far easier to overcome than a floppy chassis if you're not allowed extensive bracing. A light and stiff 55/45 beats a heavier, higher cg, flexier 53/47 any day.
03-07-2003, 11:43 AM | #16 |
hey i dont know if this is tru i could care less but this dood i know at Stillen said my coupe was 50/50 with the sr20det. Im jus sayin cuz Stillen usually know there shizzel. Either which way.
Coupe Pros: Its Just Better Hatchback Pros: There are none. Haha no im jus messin. Maybe Im jus a lil biased haha.
Area 51 PS13 Silvia Conversion 230hp 234lb/ft torque to the wheels 11 lbs of boost |
03-07-2003, 12:18 PM | #18 |
well im jus sayin man phil at stillen seemed to know his shizzel when i met him at Area 51. so yeah . Does ne one say hes wrong in that the s13 w/sr20 isnt 5050.
But beyond that coupes r better.haha N dont hate man i jus dont know shiz about my car man. I only got into nissans in june. I was a Honda man before dood.
03-07-2003, 12:23 PM | #19 |
stillen knows so much they sell 2 left Z32tt calipers at there garage sales!!!
sells a full set of brake lines for a 240sx yet its too long and all for the rears i paid 20 bucks for the lines i didnt get the calipers (already had them) overcharge on prices for their products. dont trust stillen! its stealin! they f'd my friends car too when they worked on it! and Area51, arent they going out of business? i went there once, um...rip off! and the SR isnt much lighter then the KA. its a MYTH i aint hating on you, just dont believe businesses who are in it for $$$$ rather then helping people. |
03-07-2003, 02:10 PM | #20 | |
Re: Coupe vs Fastback
As for the Stillen, I know a mechanic that used to wrench on the Stillen 300Z IMSA team. The only reason they used the Stillen bodywork was that some weird loophole in the rules allowed them a weight break if they ran it. No one really liked it much. I personally hate Stillen. I buy all my AP stuff direct. I won't even give them the pleasure of putting a dumb Stillen sticker on my calipers. |
03-08-2003, 01:24 PM | #21 |
Well. I dont buy from Stillen. I buy from Phil. N dood Stillens good for some things man. Find somebody else that can tell me the color of the tach wire off the ECU for the G35(we were installing an AFC ) not even the freakin techs at the dealership knew. Oh and we have the wiring diagram also. it dont say. As for Area 51 man yeah My boi shut down the shop cuz he wanted to get out of it. Too bad u got ripped off though, i got hooked up. But cmon if ur not cool with somebody in the industry ur gonna get ripped off thats just how it is
03-08-2003, 04:52 PM | #22 | |
Sorry to point this out, but EVERY BUSINESS is in it for $$$$! Learned that one in collage |
03-08-2003, 07:39 PM | #23 | |
college not every business is ONLY for money some do it to help people as well. at least the businesses i associate myself with. then again, i get such great prices, must be just me! |
03-08-2003, 07:40 PM | #24 | |
just walking in their show room i was like 'i gotta get the **** outta here' hahah btw, i havent ever paid retail for any product on my 240sx. except gas and tires. everything else was dealer cost or below. or free. sponsors are cool. |
03-08-2003, 08:28 PM | #25 | |
Re: Re: Coupe vs Fastback
But, those were tube framed cars. |
03-08-2003, 10:29 PM | #26 | |
03-09-2003, 12:48 PM | #27 |
its a simple fact that the coupe has a cool rating of 8.9 some people quote it as a full 9.2, i ran it thry the coolno machine and got a 8.96 but i hadnt wash the car in a while, anyhow the fastback is only rated as 7.8, max i've seen stock is 8.3 and that was pushing it
03-09-2003, 01:49 PM | #28 | |
I was trying to be a smart ass |
03-09-2003, 02:39 PM | #29 | |
03-09-2003, 07:20 PM | #30 | |
