![]() Join Date: Apr 2007
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
![]() Ksport Hydraulic Handbrake INSANE PRICES!!! YOU MUST PM US OR CALL US TO GET THESE SICK DEALS!!! ![]() ![]() ![]() ![]()
Here are some question that keep arising that I figured I will answer right here: 1. Is there an installation guide? This has mostly to do with the installation kit...how the whole thing gets intercepted and all. The kit comes with and installation guide, pretty basic but explains it. All the kit is doing is interrupting the stock system. Kind of like a bypass valve. 2. Can you still use your stock ebrake? Yes and no...if the car is cable driven then yes if its oil line then no. also if you have an after market big brake kit...then most of the time no. 3. Can you take out the stock ebrake and be able to replace it with the Ksport permanently? (meaning does the Ksport act as a regular ebrake too...if say parked on a hill? Yes it will act like a regular ebrake. 4. Pros and cons of resevoir sizes? Do they matter? 5/8 is typically for oem brake setups and 3/4 is for a more upgraded like big brake for example. If for example you get a 3/4 for a oem setup it will feel sluggish before the brake engages because there is a lot more fluid flowing. And vice versa if you get a 5/8 on a big brake rear it will not engage properly and could possibly damage the reservoir because to much oil is being force through a smaller reservoir. INSANE PRICES!!! YOU MUST PM US OR CALL US TO GET THESE SICK DEALS!!! Last edited by Thmotorsports; 11-17-2009 at 02:59 PM.. |
#23 |
![]() Join Date: Mar 2008
Shipped to 08068
Nissanparts.cc... Enjuku-Racing Ever bought anything from me? Leave a review http://www.zilvia.net/f/showthread.php?t=200877 |
#24 |
Trader Rating: (28)
OK guys....thank you all for all the PM's
I have PM'd everyone back as of now ( some possibly twice ![]() Price are good for the first 10 people. LMK...all in stock. Adam THM |
#28 |
Trader Rating: (28)
1. Is there an installation guide? This has mostly to do with the installation kit...how the whole thing gets intercepted and all. The kit comes with and installation guide, pretty basic but explains it. All the kit is doing is interrupting the stock system. Kind of like a bypass valve. 2. Can you still use your stock ebrake? Yes and no...if the car is cable driven then yes if its oil line then no. also if you have an after market big brake kit...then most of the time no. 3. Can you take out the stock ebrake and be able to replace it with the Ksport permanently? (meaning does the Ksport act as a regular ebrake too...if say parked on a hill? Yes it will act like a regular ebrake. 4. Pros and cons of resevoir sizes? Do they matter? 5/8 is typically for oem brake setups and 3/4 is for a more upgraded like big brake for example. If for example you get a 3/4 for a oem setup it will feel sluggish before the brake engages because there is a lot more fluid flowing. And vice versa if you get a 5/8 on a big brake rear it will not engage properly and could possibly damage the reservoir because to much oil is being force through a smaller reservoir. |
#30 |
![]() Join Date: May 2008
![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
will the clip that holds the piston in keep falling out and causing brake fluid to explode all over me and the inside of my car like my last k-sport hydro brake?
i hope not |
