08-20-2010, 11:27 PM | #1 |
KYB AGX Install HELP - Pic
I'm trying to install these struts along with sportline springs. I have everything in except for the spindle bolts! How do you compress the strut upwards to slide the bolts in. Is there a trick?
edit: pic is too fucking big
Shift_Chirp Last edited by NightSlider; 08-20-2010 at 11:57 PM.. Reason: wow uploading pics has become pretty bad here |
08-21-2010, 12:02 AM | #4 |
You using a spring compressor? Easiest way, I found. If not, you can try putting a jack on the bottom with a cloth to avoid scratching the housing... But really, spring compressor, best bet.
08-21-2010, 12:11 AM | #5 |
how do you compress the spring while the top plate is mounted? not much room for a compressor up in there. maybe mount spindle bolts first, then compress and mount top portion last? and how would you jack up from the bottom of the housing? there's a lower control arm in the way. unbolt LCA?
my stock struts are so blown, it's ridiculous. can't wait to test these out. thanks for the help guys
Shift_Chirp |
08-21-2010, 12:21 AM | #6 |
The compressors I used (rented) you could compress midway along the height of the spring itself, I didn't need to clasp over the top plate at all. Just compressed in the center and bottom, mounted the whole thing as an assembly, loosened the compressor off and mounted my wheels. As for the jack, that was honestly a guess. I didn't have to do that, and it's been 2 years since I've mounted my AGX's, so my memory on the area is a little fuzzy.
08-21-2010, 11:44 PM | #8 |
the spring compressor is for dismounting the tophat from the shock. If your trying to get the bottom 2 bolts to line up, then just aim the top, affix those first.
Then just jack up the lower control arm till they are close to alignment. Then tap in bolts and tighten. |
08-22-2010, 09:27 PM | #9 |
had to jack up both sides...DUH. thought i could just jack up one side and install one corner at a time. as soon as i put the other side on a jack stand, the holes pretty much fell in place. sorry to waste everybody's time. haha
Shift_Chirp |
