Old 10-05-2014, 01:12 AM   #1
jza80king
jza80king is an unknown quantity at this point
cylinder head write up????
I have searched but can only find removal info/guides...is there anywhere I can get a write up for re-installing my rebuilt cylinder head on my KA24DE? I have the FSM already but was hoping someone could provide a tutorial to help me along the way.
jza80king is offline   Reply With Quote
Old 10-06-2014, 12:59 AM   #2
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Have you tried looking up maybe ka24de headgasket install in Google? I tried that and found a bunch of info..not sure exactly what your needing if you already have the fsm though
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 10-06-2014, 01:05 AM   #3
Primo's Silvia
Primo's Silvia's Avatar
Primo's Silvia is an unknown quantity at this point
Couple of vids on youtube but in reverse order aswell.
Originally Posted by adams 02rs View Post
Here yee have found zilvia...WELCOME TO HELL.
Primo's Silvia is offline   Reply With Quote
Old 10-06-2014, 09:50 AM   #4
jza80king
I found some videos by a 'S13xCrazy' but he only REMOVES the head. I just wanted to hopefully get something where the actual REBUILD is shown specifically the timing and cams. Found another video on youtube with a ka24E motor and I'm a little concerned with the valves and TDC and all that being an interference motor I do not want to crunch my valves. The FSM jumps from installing the cam sprocket cover to tightening the cyclinder head bolts. I already have the cams sprockets zip tied to the chain as I removed them so i'm having a difficult time in how the cams themselves have to point in what direction. If my 1 pistion is TDC, then the cam lobes should be in what postition? 9 o clock intake and 3 o clock exhaust? Make sense?
Old 10-06-2014, 10:22 AM   #5
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
The FSM has all the information you need and specifies order of install and torque specs, what more do you need?
My SR20VET
Old 10-06-2014, 10:37 AM   #6
jza80king
I am looking at the FSM page EM 18. It shows the pattern of tigthening the camshaft brackets.....my equestion is between step 5 'Install camshafts and camshaft brackets' and step 6 'Install camshaft sprockets' should the cam lobes on the intake cam and exhaust cam be in the 9 oclock position (intake) and 3 oclock position (exhaust)? not trying to cause frustration with anyone but that's what i'm wondering. The mating marks from the sprocket and chains have been zip tied but the cams themselves I am wondering with the 1st pistion at TDC, how the cams should be set.
Old 10-06-2014, 10:39 AM   #7
wawazat8402
wawazat8402 is an unknown quantity at this point
Send a message via AIM to wawazat8402
Maybe search for setting mechanical timing for the engine. I know the SR has a ton of threads about it.
wawazat8402 is offline   Reply With Quote
Old 10-06-2014, 11:46 AM   #8
jza80king
Think I found what I need.Line up the TDC notch and have cylinder 1 cam lobes facing out.
