Old 05-16-2012, 06:22 PM   #1
LuckyX2
LuckyX2's Avatar
LuckyX2 is an unknown quantity at this point
Balance after rods and pistons?
Hi guys,
I'm gonna be putting in new rods, bearings and pistons in my SR20 shortly and was wondering if I'd have to balance everything to the crank. I'm tight on time and I'm not sure if sending everything to a machine shop to be balanced is an option...
I know at the very least I'm going to want to match the pistons and rods so that they are the same weight as each other but do I have to then balance it all to the crank since the new rods/pistons are lighter?
Thanks
LuckyX2 is offline   Reply With Quote
Old 05-18-2012, 06:54 AM   #2
LuckyX2
LuckyX2's Avatar
Thoughts anyone?
Old 05-18-2012, 12:27 PM   #3
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
if you want the engine to last longer, yes. you need to balance everything that is connected to the crankshaft. crank pulley, pistons and rods, flywheel, and pressure plate. don`t forget to smooth out all of the sharp edges on the pistons. these sharp edges can cause detonation. good luck with your build.
rcdad123 is offline   Reply With Quote
Old 05-18-2012, 11:02 PM   #4
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
I know allot of people balance the pressure plate and flywheel on the engine, however i balance it without and balance the flywheel and pressure plate seperate so if that is changed the rest of the engine is not dependant on that.
4x4le is offline   Reply With Quote
Old 05-19-2012, 07:03 AM   #5
LuckyX2
LuckyX2's Avatar
If you can balance the flywheel separate from the crank then why can't you balance the pistons/rods separate from the crank like I'm hoping I can do to save time?
Also, how do you go about balancing a flywheel and pressure plate? I know for pistons/rods you just scrape away material until they're all the same weight but I'd imagine it's more complex for a flywheel/pressure plate.
Old 05-19-2012, 08:05 AM   #6
4x4le
4x4le's Avatar
I dont know, I dont do it myself. The machine shop does my rotating assemblys and I have had them do the clutch too. My clutch builder did my last clutch however I dont know if they did it in house or sent it out.
Old 05-21-2012, 11:24 AM   #7
LuckyX2
LuckyX2's Avatar
So I called two high performance engine builders in my area today and both of them said an inline engine like ours does not need the rods/pistons balanced to the crank.
The rods/pistons all have to be balanced to the same weight and the crank has to be balanced (like it is from the factory) but they do not need to be balanced to eachother. The one shop even said that they had tried balancing inline engines before but there was no difference so they stopped doing that.
