Old 10-05-2013, 10:40 AM   #1
Thedriftbadger
Thedriftbadger is an unknown quantity at this point
Seam in front wheel well slicing tire
As the title says, that seem in the front wheel well is slicing the shit out of my tires when i hit bumps or turn. I bent it and hammered it down as much as i could but it's still hitting a little. I can't seem to find much info on this for some reason. It seems like it should be a common problem. Anyway i read one thing that said he cut it out and rewelded it. I have a grinder but i don't have a welder. Would i be ok just cutting it out? I was thinking i'd just cut out where it's hitting so the rest of the seam is still there... What have other people done?
Thedriftbadger is offline   Reply With Quote
Old 10-05-2013, 11:15 AM   #2
jaysgottaredtop
jaysgottaredtop's Avatar
if you don't want to cut/weld, just slice it vertically to the frame every few inches and then hammer this shit out of with the biggest sledge you can find. that said, i don't see why cutting and welding would be bad. you wouldn't be losing anything structurally compared to my slice/flatten method.
after you beat/cut/weld/whatever that inner seam, the next one you'll hit would be the outer one. this one is easy enough to hammer up and out:
^ but real talk, the best fix for all this shit is to get shorter front tires! haha
Old 10-05-2013, 08:16 PM   #3
Thedriftbadger
Thanks i'm gonna try the cut and hammer the shit out of it method. I only need a little bit of clearance cause it just barely rubs. My tires are 215-40-17's, idk how much shorter i can go lol
Old 10-05-2013, 09:16 PM   #4
jaysgottaredtop
oh yeah, just bash the hell out of it. that picture is with 255/40/17s, so you should be fine with 215/40s
