11-09-2015, 11:42 PM | #31 |
...but is Takata safer than my monorail-auto-seatbelts-from-the-future? The thought of getting into an accident with these fucking things scares the shit out of me.
11-10-2015, 05:32 AM | #32 | |
11-10-2015, 11:37 AM | #33 |
In all seriousness though I don't understand the point you tards are trying to make here. Just because of an issue Takata's gotten into with their ABS division, suddenly none of their products are safe? Just a heads up here kiddos, pretty sure Nissan's OEM belts had been manufactured by Takata for decades. (as well as Honda, Mazda, etc.) The big belt recall back in the 90s wasn't even related to the belts themselves, but rather the plastic in the buckles. (which your 'racing' harnesses don't utilize) You're no more or less likely to die in a traffic accident using Takata harnesses than you are running Schroth, Sparco, Simpson, G-Force, or any other brand assuming we're comparing apples to apples. (same FIA certs, number of mounting points, etc. etc.) As long as everything is installed correctly and in good nick, you're not going to suddenly get killed when the geriatric in the caddy doesn't look before backing out in the supermarket parking lot. Hell, I'm sure you would be okay if you had decided a nice set of ratchet straps was going to be sufficient for a spin around the block. (not that I recommend this of course, but you get my point)
If you're concerned about the safety of different harnesses you should also be looking into add-ons like HANS devices and arm restraints, because clearly whatever sanctioning body you're racing in is going to be looking for these as well. All that said; yes, people bought into the JDM hype of Takata's simply because of all the feature cars that were running them in Import Tuner/Super Street/Etc. back in the day. This shouldn't add nor detract from their reputation however and if you want to run them so be it. If not, good on you as well.
-Robert R. |
11-11-2015, 06:11 AM | #38 |
Soooo happy im poor and never been able to afford fancy wheels/belts/engine parts. Saves me money and keeps me lucky charms!
lucky charms is probably negatively charged proteins or something |
11-11-2015, 11:18 AM | #41 |
Remember when that wasn't necessarily a bad thing?
Negative, my good sir. Can't say I've even had the good fortune yet to so much as visit either country. Some day though. Why do you ask?
-Robert R. |
11-11-2015, 12:45 PM | #43 |
Didn't know the terminology "in good nick" was used in the States!
11-11-2015, 04:41 PM | #44 |
well, wait. Don't I also need to buy a cage or some kind of special bar to bolt a real harness into a real race car?
Because my daily totally needs stuff like that, pretty bad. I can't use all these because race car stickers until I get far enough down the rabbit tunnel. |
11-11-2015, 06:07 PM | #45 | |
I want to replace my auto-seatbelts with some harnesses. Takata says you can use the rear seat belt mounts and feed the harnesses through the headrest. I'm no expert on racecars so the whole argument about position is lost on me. Anyone care to explain? I don't trust these auto-belts for the life of me...
11-11-2015, 06:10 PM | #46 |
^ dont worry, he is from florida. that should explain the good majority of rambling in his posts.
s13 owners should ditch the auto belt system and either go with canadian seatbelt system or what i did, roll bar and schroth asm harnesses. |
11-11-2015, 07:05 PM | #48 |
Is it really shitty to use harnesses with the rear seatbelt mounting points, though? Like you said I'm only using them to keep my face inside the windshield. I don't drive my car like a fucking cunt but I can just picture an impact and the fucking auto-belts sliding forward on their tracks...and me with them.
11-11-2015, 07:35 PM | #49 |
A professor once told me that,
"you do not need to know what the ducks are saying in order to understand that they are communicating" I'm not sure, but I think he was calling me a duck. |
11-12-2015, 01:10 AM | #52 | ||
much like doing wheels/tires/suspension - you need to consider the interior setup in detail, as it usually involves seats/rollbar/harnesses. i had no regrets going with the 4-pt ASM setup, although it might be a bit much for some people. if thats the case, just go with the canadian hardware. Quote:
:P |
11-12-2015, 01:06 PM | #53 | |
For $200 I can get the 4-point/ASM harness I want. $200 will also get me CDM hardware and (if I'm lucky) the A/B pillars...but I'd still have to source a headliner. I had the CDM stuff and missed the part about the headliner and sold the setup.
11-12-2015, 06:35 PM | #54 |
its not so much about being a retard with a 4pt setup, more about the fact that when different sized people sit in your car, that not each and every person has the knowledge or interest to sit there and attempt to re-size the harnesses for their body type.
my only real complaint about driving a car with harnesses is when it comes to making what I call a "slight right." there are some intersections where the right turn is not a 90° turn, its almost a Y-shaped intersection. When you need to merge its very difficult to turn your body, or in this case your neck, in order to see if any cars are coming up on you. essentially, you need to leave the inner belt a little looser in order to be able to bend and see that blind spot. no health risks with the ASM harnesses, thats what the ASM stands for: anti sub marining. there is a section of fabric that is designed to un-stich and give in the event of an accident, which allows one of your shoulders to extend. |
11-12-2015, 06:46 PM | #55 |
meh, a lot of auto seatbelt hate here,
You guys don't like auto seatbelts because your peasants who like unlatch your own damn seatbelts. I feel like the gangster badassery of having a small electric motor pull my seatbelt off more than makes up for all the dying and paralysis. |
11-12-2015, 06:57 PM | #56 | ||
...I just don't want to take the extra step of getting a harness bar and helmets for a weekend cruise lol. Quote:
11-12-2015, 09:29 PM | #57 | |
yeah... thats the lap of luxury alright. i like the movie christine the car, but i never wanted to be in it. fuck those seatbelts |
11-12-2015, 10:06 PM | #58 | |
Not only are the auto seatbelts flimsy as hell and easily breakable, but they encourage you to not actually put on the lower belt. For instance, in my car I rarely put on the lower belt, just cause the upper one is "auto", and with the one visible strap on, no one's gonna give you a ticket. You usually just forget, making them inherently unsafe, despite being from the dystopian safety oriented automatic seatbelt future. |
11-13-2015, 12:50 PM | #60 |
Obee pls.
On the bright side I can sell you my rare, JDM auto-belts for the astonishingly low price of $557.67 + you pay PayPal fees and shipping. Don't sleep. I definitely know what rare means.
