Old 11-09-2008, 02:55 AM   #1
gripster
gripster is an unknown quantity at this point
jb weld stud to hub?
In the process of removing my front wheel to get it balance, the stud got stripped from the hub. There are no grooves on the hub to hold the new stud in place.
A new hub is $140, a stud $2 <-- prices from courtesy nissan site.
Would jb weld keep a new stud from spinning on my old hub? I know it has to cure overnight for it to work effectively.
So, anybody know if this will work?
thx in advance
71, 72, 74 Celicas; 85 AE88 hatch;
89 S13 hatch; 04 IS300 5MT
gripster is offline   Reply With Quote
Old 11-09-2008, 11:10 AM   #2
mrmephistopheles
Inactive Admin
mrmephistopheles's Avatar
Just go get a new hub from a junkyard.
edit: ignore me - do this
VVVVVVVVVVVVVVVVVVVV
Originally Posted by PHLIP
Old 11-09-2008, 12:08 PM   #3
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
the hubs are not splined they just have a hole and the stud has splines that deform in the hole to prevent spinning when installed, plus the material for the hub is a lot harder then that of the stud, so chances are the hub isnt damaged only the stud is, so get a new stud and put in and u will be good
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 11-09-2008, 12:26 PM   #4
NISMO_tuner
NISMO_tuner's Avatar
Trader Rating: (64)
NISMO_tuner is an unknown quantity at this point
Feedback Score: 64 reviews
Send a message via Yahoo to NISMO_tuner
yup get another hub from the junkyard
NISMO_tuner is offline   Reply With Quote
Old 11-09-2008, 01:24 PM   #5
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
No need to get a new hub just yet. Just like japslapsilvia said, you should just try the easy thing first. Get the new stud impacted in properly and see if it stays put. More than likely it will. =)
Old 11-09-2008, 01:30 PM   #6
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
^ I agree with karl. Just get a new stud. They're $1.25 from AutoZone or most auto parts places. Just remove the defective one and replace with the new one. Use several washers and place them on the stud. Then use an open lug nut and tighten it down. Torque down as you would when intalling your wheels.
If for whatever reason it won't tighted then just get yourself a hub from the junkyard. They're $15 ea. (plus tax) at my local one.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 11-09-2008, 01:33 PM   #7
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
If you wanna cheap it out actually weld the wheelstud in, NOT JB weld.
racepar1 is offline   Reply With Quote
Old 11-09-2008, 05:15 PM   #8
RIMTUCK
RIMTUCK is an unknown quantity at this point
Send a message via AIM to RIMTUCK
__________
RIMTUCK is offline   Reply With Quote
Old 11-09-2008, 05:23 PM   #9
projectRDM
projectRDM's Avatar
Try a new stud first. As said, the stud is way softer than the hub, it's unlikely the hub is damaged enough to be trash. If so, tackweld it in, JB Weld will NOT hold under those loads.
FORMERLY R240NA
Old 11-09-2008, 05:46 PM   #10
RIMTUCK
__________
Old 11-10-2008, 02:05 AM   #11
gripster
Thanks folks. I will try a new stud first before welding it in or getting a new hub.
It really came in an inopportune time because I missed out on an autoX. Didn't have time to work on the car.
Old 11-10-2008, 02:20 AM   #12
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
welding the studs are rough...lol... been there done that...
lmk if you need a hub, I got a few... pay ship/
you can also go to auto store and get a stud with a larger nurl...
GL brudda
sillyvia13 is offline   Reply With Quote
Old 11-21-2008, 12:06 PM   #13
gripster
Just wanted to update you folks. Finally got time/tools to work on the car.
My hub is completely stripped. I got some new studs, and tried to put it in. It was loose, so i'm in the process of searching for a hub locally.
Old 11-21-2008, 01:05 PM   #14
japslapsilvia
that sucks...im curious to see how much damage was done to the hub, can you post pics of how bad it is?
Old 11-25-2008, 01:34 PM   #15
gripster
As requested, here's a pic of the stripped hub. The other good holes have serrated/grooved holes that hold the stud in place. As you can see, this one has been smoothed over and won't hold a stud in place.
Old 11-25-2008, 01:37 PM   #16
ZenkiCam
ZenkiCam's Avatar
ZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really nice
Send a message via AIM to ZenkiCam
damn.............
ZenkiCam is offline   Reply With Quote
Old 11-25-2008, 01:40 PM   #17
!Zar!
!Zar!'s Avatar
You should just post up a want to buy.
Hubs are cheap.
I wouldn't trust jb weld.
Best bet is to tack weld the new stud in there.
A welder could do that in literally seconds.
Shouldn't cost more than a few bucks.
Old 11-25-2008, 01:42 PM   #18
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
its as simple as that
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 11-25-2008, 01:51 PM   #19
gripster
I already have a new (used) hub installed. I just wanted to show you folks the damage done to my old hub.
