![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
NEW PRODUCT!! AEM AQ-1 Data Logger at MVP Motorsports!!
OVERVIEW AEM’s AQ-1 Data Logger is an easy-to-use vehicle data acquisition device designed for racers and performance enthusiasts of all types who want dynamic, accurate data logging capability, but don’t want to take a second job to pay for it. Knowledge is power, and the information stored in the AQ-1 Data Logger can help users improve a vehicle’s tuning and set up, and their own driving ability. With easy to use software, lightning fast logging rates, extra-large memory, and unbeatable affordability, the AQ-1 Data Logger is the perfect choice for any user whether a novice or professional race team. FAST AND EASY TO USE AEM’s AQ-1 Data Logger is easy to use, feature packed, and it won’t break the bank. With logging rates of up to 1000HZ (1000 samples/second) per channel, the system is one of the fastest on the market, and with 2GB of logging memory standard it’s also one of the largest. Additionally it features an internal 3-axis accelerometer, a removable SD card for virtually unlimited logging (up to 32GB at a time), and includes an available RS-232 serial input for adding an NMEA GPS device. The included AEM sensor library makes set up and configuration a snap. Log files are generated for use with AEMLog, AEM’s proven software analysis program. LOG USING ANALOG INPUTS OR AEMNet The AQ-1 Data Logger includes three switched/digital inputs, four 0-5 V analog inputs with optional pull up resistor for RTD/Thermistor-style sensors, four additional analog inputs that can optionally be used to measure RPM or other frequency-based signals, and AEMnet (the new high speed communications network that links enabled AEM products together) capability for direct connection to a 4-Channel UEGO Controller, AEM Series2 EMS or other future AEMnet enabled devices. EASY INSTALL & SET UP AEM’s AQ-1 Data Logger includes a flying lead harness with a weather-proof connector and labeled wires for easy installation. Its compact size makes it easy to install (4.80” x 4.55” x 1.44”), and its rugged enclosure features a weather resistant dust cover for added durability. The AQ-1 Data Logger interfaces via USB connection to a laptop, and the included software is easy to use with detailed configuration screen and a comprehensive AEM sensor library to simplify set up and use. FREE UPGRADES! AEM is developing track mapping software that will be available late summer 2011. All AQ-1 Data Logger owners will be able to download these upgrades for free from AEM Electronics OBDII VERSION OF THE AQ-1 COMING SOON! AEM will release its AQ-1 OBDII Data Logger in the coming months. This version of the AQ-1 will plug into the OBDII port on ’96-up OBDII vehicles and will allow users to log both OBDII and analog data and view them on the same log. Please check this website or call our customer service department at (310) 484-2322 for release updates. AQ-1 Data Logger Key Features * Internal 3-axis accelerometer (+/- 4g MAX) * Removable SD card for virtually unlimited logging (2GB card included) * RS-232 serial input included for adding NMEA GPS device * Compact size (4.8" x 4.55" x 1.44") * Intuitive software included for easy set up and operation * AEM Sensor library makes streamlines configuration * Track mapping capability (Available free late summer 2011) AQ-1 Data Logger Technical Features * Four analog inputs for measuring frequency (RPM), 0-5 V or 0-16.5 V * Four 0-5 V analog inputs with optional pullup resistor for RTD/Thermistor-style sensor * Three switched digital inputs, 16.5 V MAX * AEMnet connection included for easy connection to AEMnet enabled devices * Up to 1 KHz logging rate (1000 samples/second) per channel * Data saved to single file with real-time clock * Log files generated in AEMLog software * Included flying lead harness with labeled wires and sealed Packard connector * Configurable CAN bus for interface with other manufacturer’s CAN-enabled devices (Coming soon, free download) Regards, Robert
940-683-8282 x20 Robert Del Angel CLICK HERE FOR OUR FACEBOOK PAGE!!! FOLLOW US ON TWITTER!!! Master Distributor for : RPS, Tein, Seibon, Haltech, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, Work, Volk, Fidanza, Defi, ....and so many more!!! |
