What Spark Plugs ?
What Spark Plugs are you guys running with what modifications and boost ? Also why did you choose that particular spark plug ?
I'm currently running the OEM NGK BRK7 running 18psi on a GT2871r, however a friend of mines on the stock s14 sr switched to Iridiums and liked them. Any input as to which to use ?
I'm running the NGK Iridium BKR6EIX on a stock S13 SR20. I was only shooting for a completely stock low boost setup though.
"I want my name to be Spaghetti!" |
Heat range 8 iridiums are great and will suffice to 20 psi on pump gas
Like Me on FaceBook !
![]() Join Date: Nov 2003
Have you had pretty good results with these Steve? I wanted to but the price sucks and running richer than stock conditions I didn't know how long they'd last compared to the copper brk7e's.
Lower than a pornstar's morals. |
Get a wideband and a decent EMS - then run heat range 8
I can only imagine how much HP you are missing out on if you are afraid of fouling plugs + it's not good for the engines. I don't understand this philosophy that has been pushed on people (it's not your fault) that you buy big injectors before you buy a proper EMS. I have had great results, such as cars I have tuned running low 11s on pump gas - my own car lasting over 2.5 years now on stock bottom end and nearly 500 crank HP and more - I highly suggest them for HP over 350 whp and pressure over 20 psi on SR motors
#9 | |
I replace my plugs more often then not just because I'm anal, not because they actually fail (and they're cheap). I just wanted your opinion on them, good or bad, that's all.
