#4891 |
![]() Join Date: Nov 2009
Running 295s up front and low offset... wouldnt we want KPI and scrub radius adjusted (for grip/track setup) and also to improve braking stability as braking gets all shitty and snappy...
#4892 | |
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 2 reviews
#4893 | |
![]() Join Date: Dec 2009
Sent from my SCH-I535 using Tapatalk 2
MAddDsBRO LEHDABIHLOO |
#4894 |
i have 18x11 up front with 295/30/18... low offset i forget exactly now to fill out bn blister fenders.... kind of like that one black time attack except it uses s15 front on s13 hatch chassis.. same front width though...
Anyways... with lower offset... braking is shaky... and steering effort is greater with obviously heavier/wider tires and the scrub radius in question... I dont have any of these fancy knuckles but contemplating... and what would be the ideal for a wider grip setup with low offset like that... |
#4895 |
I'm going to guess that a good thing for you to do would be to extend your lca and bring the top mounting point of your strut out, and run a less aggressive offset? Just extending your lca should lower your scrub radius by making your sai a little steeper and likely bringing closer to the center of your contact patch, BUT then you would have excessive camber
#4896 |
A 295 does sound excessive though as far as practicality goes I could be wrong, and I understand your need to fill the fender Aswell
#4898 | |
#4900 | ||
![]() Join Date: Feb 2010
Anybody got any feed back on battle version arms?
Trying to get arms for my daily s14. Ideally I would want PBM/SPL but kind of on a budget.
#4901 |
![]() Join Date: Mar 2011
![]() ![]() ![]() Feedback Score: 7 reviews
how has this not been posted yet? another cool product idea from GKTech for the s-chassis.
![]() pros: inexpensive, uses the stock knuckle, corrects roll center, corrects bumpsteer, widens track, adds more negative camber, any ackermann angle possible depending on where they drill the new tie rod pickup hole. cons: heavier than a cut/weld knuckle or GKTech's billet knuckles, increases scrub radius. what else am i missing? obviously the geometry isn't 100% ideal, but it seems to nail all the basics in a concise package. are there any specific reasons to avoid this design entirely, besides guys doing high level competition? overall this looks like an AWESOME product idea for grassroots drifting. cheaper than modded knuckles, no downtime (since you don't need to send your knuckles out), corrects roll center and bump steer, and it's got that all-important billet gansterness. what say you, suspension geometry geeks?
#4906 |
Those look like they are placing the ball joint and tie rod pick up point at different angles than factory, which immediately effects Ackerman and the angle at which the ball joint and tie rod sit at which will allow then to reach there extremes with less suspension travel than previously, unless they are sitting that way to compensate from the added length downward and outward from factory
#4907 | |
![]() Join Date: Nov 2005
#4909 |
having just moved from a Toyota to a s chassis i thought i give my 2¢ Techno toy tuning made some nrca's for the corolla seen and i really liked them. trouble is no body makes them for 240s (yet) gk looks like they are on it like stink on $hit.trouble is they live half a world away so i just made my own. any constructive criticism? hit me up on FB for a faster response. i should mention this is a prototype, any machinists out there, don't kill me, i had to find out if my numbers meshed
![]() 40mm roll center correction (could change) 1" track width gain (likely to change) 2 tierod pickups that can be moved to create 2 new locations. totaling 4 pickup points. (most defiantly going to change ![]() Nathan Shewchuk ![]() |
#4910 |
Well man, I think you're the best judge of structural integrity, since you'll be driving with them.
You can use the chart in here a few pages back to determine what your total roll center correction needs to be. You can experiment with the tie rod pickup holes and figure out where you want yours, then make a final design with just that hole so it can be simpler if you wanted to. TO ALL: I've been REALLY slacking on getting that first page updated. Look for it in the coming week. |
#4911 |
thanks! ill take a look back a few pages
as for strength, this is a wonky prototype, i have some tricky plans for the next rev. still working on inserts, id like to have pres-fit inserts for the lower balljoint. also my boss pointed out a few things and some big changes are in the works i can say this. i have changed from 4 too 16 tierod pickups per block >.< |
#4912 |
![]() Join Date: Aug 2011
Dont forget you need to fit a wheel and a disc brake in there. I wanted to get the gktech version of these, but it will hit my brake setup, so i am back to square 1.
#4913 |
![]() Join Date: Jun 2010
Awesome, hope the front page mentions how much to shorten the tie rod point on the knuckle and what not. Been looking for how much people normally shorten them but cant find much. Guessing 30mm but I dont know.
S14 KA NA two cylinders, 75whp limper |
#4914 |
Croustibat
what setup have you got? brake wise? im checking clearance against stock s13 and z32 bits. i have designed it so that if it cleared a stock lca in the first place it should clear this, unless its some off the wall NASCAR brembos or something >.< |
#4915 |
I got 330x32mm rotors from a ferrari 456 GT/A and wilwood superlite 4pots calipers.
My current lower arms are only a couple millimeters from the disc, and i cant fit that kind of hardware. Cant fit ball joints with longer shank either for the same reason ... i guess i will have to change my brake setup someday. |
#4919 |
#4920 |
It will add as much angle as a driftworks knuckle. I'd say this is the best idea they've thought of. They'll be selling out of these for months at a time.
| anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
