![]() Join Date: Jun 2004
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
Dont really notice solid bushings other then it looses a lot of the rear end play. Still bushings for diff and suspension. that is s14 camber arm but s13 should fit also.
![]() Join Date: Apr 2006
you realize the bushings were/are pressed in backwards, right?
you need some sort of plate to secure the bottom end of your subframe. also, s14/15 subframes are damn near identical, if not identical. i have both. |
Trader Rating: (18)
it was temp fit in my r32. They are spaced down because the subframe it the frame rails in the r32. I used big washers underneath normally. Couldnt raise it anymore. s13 can go higher.
Man i have solid bushings on my s13 and they are LOUDDDD. I think its because the diff doesnt have the rubber bushigns like the s14.
![]() Join Date: Apr 2004
You can't use an S13 toe arm or RLCA on an S14/S15 rear subframe. The subframe mounting points are wider. Just as a heads up for potential buyers.
#19 | |
![]() Join Date: May 2004
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
Also, how tight are those solid subframe bushings pressed in? i.e. will I be able to take them out & flip them for install in an s13 w/o the use of a press/etc?
bew bews! |
#20 |
Trader Rating: (18)
The washers arent part of the kit from touge factory they only sent me bushings. They are pretty tight but they will come out with a hammer dont need a press. With them flipped you wont need the washers.
