My brother inlaw gets his suspension work done at a shop near atlanta, so I went with him one day to check there progress on his rx3. Low and behold in one of the bays was an s14 full out race car this thing was full tubular frame and fully custom on everything. I was amazed so I went to take pictures and sh^t I left my cell at home. So pissed at myself I left.
So today we went out to road atlanta because he had a few friends testing today for scca. then I saw the s14, and finally got some pictures. I also got to see it in action that is the fastest na 240 I have ever seen. It was keeping up with the panoz cars and built vettes like it was nothing. Here are the pix enjoy.
![]() Join Date: Apr 2002
lol...it's 4 lug! EDIT: what? "VERY JDMIFIED CAR!" hahaha. The car is red white and blue...
89 S13 hatch/////98 Subaru 2.5RS |
yep its a ka24 and that is the only some what stock thing on the car the body is fiber glass the frame was redone. the suspension is a coilover setup with external reservior, all braided lines and more stuff I can't remember. this is all from memory of the first time I saw it so it might be a bit off.
#10 | |
#11 | |
![]() Join Date: Mar 2007
As for making 340hp...A lot of patience, time, and most importantly...money. |
Not the same S14, but it races the same SCCA class:
Engine Engine Builder: Dave Auerbach Manufacturer: Nissan Type: KA24 Displacement: 2.4 liter Induction: Twin Mikuni 44 side draft Heads: Nissan 12 valve Block: Nissan Main Caps: Nissan Comp Crankshaft: Nissan Comp Connecting Rods: Carillo Pistons: J&E Camshaft: Rebello Valves: Nissan Comp Valve Train: Nissan Comp Clutch: Tilton 2 disk 5 1/2 Pressure Plate: Tilton 5 1/2 Flywheel: Tilton 5 1/2 Exhaust: 4-2-1 Total Time: 1.2 hrs Races: 1 Fuel System Fuel Cell Manufacturer: Custom Fuelsafe Age: 3 years Capacity: 10gal Fuel Pump: 2 in cell and 2 pressure Fuel Type: 112 oct Oil/Water System Radiator: Nissan Water Rad Location: Front nose Water Pump: Nissan Oil Cooler: Earl's Oil Cooler Location: Front nose Electrical System Ignition: Electromotive Alternator: none Battery: Optima Yellow Data Logger: Seat of the pants! Computer: none Transmission Manfacturer: Saenz Type: TC840 Gears: 5 speed Shifter: Manual Trans Cooler: Yes Races: 1.2 hrs |
Admin Asshole
![]() Join Date: Mar 2002
svensko, please stop being useless wth all the "JDM" bullshit. It's annoying. This is your warning.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
#18 | |
#22 | |
Good work on that one, considering an s14 never came with a ka24e. There are quite a few gt3 240sx race cars. |
#23 | |
![]() Join Date: Sep 2005
#25 | |
There is not a restriction in G.T. as to using a single cam vs a dual cam, you are allowed to update, or backdate components on the car. The single cam may well make more power RELIABLY than the dual cam. |
#26 |
I dont think they care about reliabilty, these motors are based on how many hours they run.
IIRC, last time this car was talked about here someone said the SOHC head had alot more room to fit bigger valves in there.
![]() -Jackson.Vaughn.Photography- |
#27 | |
Yes, they do rebuild them frequently, but reliability is still important for the life of the motor. If you don't think reliability of the motor is important in a $50,000+ race car, stop talking. |
#28 |
![]() Join Date: Jan 2004
oh my fucking lord. Does that thing honestly have a stock radiator in it?!
dang car 100% looks like it needs to be driving in the Nextel Cup
I'm from Florida so I'm probably a bit more strange than you |
#30 |
^^^ that car is faster then anything you have ever ridden in or driven more then likely unless you secretly drive formula cars.
