Old 11-21-2002, 04:36 PM   #1
Dark
Dark's Avatar
Dark is an unknown quantity at this point
I've known about ceramic engines for a while now but I didn't know what made them special. Today I did a search and found this and now I'm getting more interested. I want to know more if anybody can help please do.
93 Fastback, 5spd with obx shortshifter
Power is in the control of strength.
Dark is offline   Reply With Quote
Old 11-22-2002, 06:14 AM   #2
wherezmytofu
wherezmytofu is an unknown quantity at this point
ceramic engies go on the same concept as all ceramic car parts: better heat removel, light weight, ect. the main problem with it was say it got real hot then u splash water on it....bam its gone...ceramic is also weaker then aluminum...which is weaker then iron..so the block strenght isnt so great... &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
wherezmytofu is offline   Reply With Quote
Old 11-22-2002, 08:39 AM   #3
negular
Dr. Neg
negular's Avatar
negular is an unknown quantity at this point
Send a message via AIM to negular Send a message via Yahoo to negular
and when ur done with the engine, maybe u can make it into a nice ceramic flower vase. &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
The louder the radio, the better I sing.
negular is offline   Reply With Quote
Old 11-22-2002, 10:02 AM   #4
hurleyboi514
hurleyboi514 is a well-known jackass
Send a message via AIM to hurleyboi514
hmm, thats really fascinating... &nbsp;i wonder if you could just use all ceramic internals (piston walls, pistons, rods, crank, or whatever they do) and then put it in a metal block to protect it from the water and such. &nbsp;intresting... &nbsp; <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/eh.gif" border="0" valign="absmiddle" alt=':eh:'> &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sigh.gif" border="0" valign="absmiddle" alt=''>
HighTach Motorsports
hurleyboi514 is offline   Reply With Quote
Old 11-22-2002, 02:04 PM   #5
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
I don't understand how it creates no emmisions.
As far as I can tell it's still an internal combustion engine that simply uses a new material. &nbsp;Yes it needs less energy and is more efficient, but internal combustion doesn't create emmisions due to the block material, but rather the combustion process.
Otherwise it sounds pretty cool. &nbsp;It would be nice to have an 80lb engine in the engine bay. &nbsp;That's good for like a 300lb diet on my 240.
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 11-22-2002, 03:10 PM   #6
Dark
Dark's Avatar
From what I understand the ceramic engine allows the combustion to occur at a higher temperature which I'm guessing lowers emissions significantly. Kind of like the gas burner in chemistry when the flame is yellow black smoke comes out when it's blue very little black smoke comes out (if any) .
Old 11-22-2002, 04:42 PM   #7
wherezmytofu
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (hurleyboi514 @ Nov. 21 2002,12:02)</td></tr><tr><td id="QUOTE">hmm, thats really fascinating... i wonder if you could just use all ceramic internals (piston walls, pistons, rods, crank, or whatever they do) and then put it in a metal block to protect it from the water and such. intresting... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/eh.gif" border="0" valign="absmiddle" alt=':eh:'> <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sigh.gif" border="0" valign="absmiddle" alt=''></td></tr></table><span id='postcolor'>
paper machette time?
