Closed Thread
Old 10-04-2008, 01:44 AM   #721
240kidd
240kidd's Avatar
240kidd is an unknown quantity at this point
damn this is such a nice build.. I didnt read all of it.. but are you doing and awd setup or rwd??
240kidd is offline
Old 10-04-2008, 05:16 AM   #722
CursedGTR
CursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfection
Rear Wheel Drive.
CursedGTR is offline
Old 10-04-2008, 01:43 PM   #723
xpl2007
xpl2007's Avatar
xpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfection
Guess i will see this in Tokyo Auto Salon in Jan...
NIce.. This is why i coming....
#/f/traderratings.html?u=57636
If i sold you something or gave you it for free post here! Thanks!
xpl2007 is offline
Old 10-11-2008, 04:53 AM   #724
CursedGTR
I doubt I will make TAS, but then again, if I was staying in Japan for another year, I probably would.
Today, I finished up the rear harness and got the tail lights squared away. I started looming and setting upp the front harness parts for the charging system and all the peripherals will go throgh a second harness. Each front harness will be about the size of a nickel in diameter so it should turn out really nice looking.
I also picked up another R33 E-Brake assembly to put to use, but I have to modify the back plates for the big rotors and fix a little rust hole in one of them. Since the rear rotors are for stock 296mm rotors, I am thinking about extending them out for the 330mm rotors I have for the rear.
Once the front harness and and e-brake assembly is complete, I will move into the cabin and finish up the dash and column harnesses with all the switches and switch panel, finish the center console for the dash.
After all this is complete, I need to order the caliper rebuild kits for the rotora brakes, some sway bar end links, tires and the pedal system with all the lines and I will have a rolling chasis.
Out with the old crap harness -
I used some black nylon braided loom that is tubular so you have to feed it over the wire like a sock but it is kick ass because it grips to the wire and does not move aorund after you set it in place. The rear harness was completed and I left a alot of play in the wires so that it is easy to service the wires in the area comfortably without worrying about pulling wires to hard or not being able to reach them.
Rear Grounding Center (I will be running 2X 2 gauge wires into the lugs on top on bottom in order to provide ground to chasis for all the electrical items in the trunk).
This is the picture of the front harness as you can see it is pretty nicely sized and the loom I am using makes it pretty moldable so it will be very nicely laid into the engine bay without having to use 700 zip ties to hold it in place.
Old 10-11-2008, 11:13 AM   #725
SlideAlliance
SlideAlliance's Avatar
SlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond repute
Brian I hate you, everytime I look in here I have to go do something new to my car
Battle Idol Works 2015
SlideAlliance is offline
Old 10-11-2008, 04:05 PM   #726
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
nice...that's gonna be so clean
96Turbo is offline
Old 10-11-2008, 10:16 PM   #727
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
i wish i had ur patience to rewire my car. sick shit man
blueshark123 is offline
Old 10-11-2008, 10:47 PM   #728
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
Originally Posted by CursedGTR View Post
Dude, thanks for the input on the wiring. I have a plan on the grounds but maybe you can hear me out and tell what you think.
I have Two 10 terminal brass grounbd strips that I intend on mounting in the trunk and in the Engine Bay. Each one will have a Chasis ground ran to the rails consisting of TWO 4 gauge Copper wires.
The Relay Grounds Will be separate and will consiist of an 8 gauge ground wire to the chasis rails and the grounding point on the terminal strips
and the Battery will get a 0 Gauge Ground to the Chasis.
I will also ground the motor using 4 or 6 gauge copper wire as well as grounding straps get ate up over here quite quickly.
Let me know what you think. I will post pictures of it as soon as I am done wiring all the positive wires.
grounding with any wire over 4gauge is stupidly over kill. (no offence) but with the multiple grounding points you will be fine with just 4ga grounds. make sure to go to an audio shop and get the Gold plated terminals to resist corrosion its adds up and gets expensive but in the long run its worth it. about the ground from battery to the chassis just be sure to get some nice multistrand copper wire 2Ga is the best for your application (assuming yo won't install mega baller omg 2000whatt sound system and jdm tyte underglow and 200 gauges all over the dash lol *sarcasm*)
the copper grounding plates are awesome i actually wish i would ahve thought of that. so far it looks good. keep it up!
Review Thread
bardabe is offline
Old 10-11-2008, 11:02 PM   #729
SilviaDoctrine
SilviaDoctrine's Avatar
SilviaDoctrine is an unknown quantity at this point
Wow! Can't wait to see it finished!
SilviaDoctrine is offline
Old 10-13-2008, 11:12 PM   #730
CursedGTR
I fully intend to install what I consider to be a monster baller stereo system, consisting of an IPod compatible ghetto blaster strapped to the roll cage
Got majority of the front harness assembled in the past two days.
The drivers side harness has all the charging system wires and the right blinkers wires. The passenger side holds the head light wires, blinkers and fans.
Next step is to cut and terminate all the wires, finish trimming everything up and then building the switch
panel for everything.
Old 10-14-2008, 09:01 AM   #731
Om1kron
Om1kron's Avatar
looking good man!
Wayne
Om1kron is offline
Old 10-14-2008, 09:18 AM   #732
KasperSlide
KasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choices
every time i see this thread i feel unaccomplished and less of a man......shits so hot it makes me sick
KasperSlide is offline
Old 10-14-2008, 09:48 AM   #733
Kyosuke
Kyosuke's Avatar
Kyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymore
this dude is a monster,on some tony stark shit
Kyosuke is offline
Old 10-14-2008, 10:06 AM   #734
Oo_Skyline_oO
Oo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud of
Send a message via AIM to Oo_Skyline_oO
how are you planning to cover up all the excess wholes into the cabin btw???
Oo_Skyline_oO is offline
Old 10-14-2008, 10:35 AM   #735
xtreme 2
Banned from the Marketplace
xtreme 2 is an unknown quantity at this point
Damn, totally Sick. Loving every bit of it so far, and will be checking back weekly to see more. Totally makes me want to take my S13 in a different direction.
What will you do the day the military tells you to go home?
xtreme 2 is offline
Old 10-14-2008, 04:25 PM   #736
CursedGTR
I plan on using aluminum, rubber and some bolts to make removable block plates
Old 10-14-2008, 04:27 PM   #737
CursedGTR
I am working on getting on with a couple government agencies doing what I do for the military and I am also considering some contractor positions. Basically anything that will allow me to travel and do what I do now and still afford my habit.
Old 10-14-2008, 04:30 PM   #738
Oo_Skyline_oO
nice............also, what fuel pump(s)??
Old 10-14-2008, 05:25 PM   #739
CursedGTR
I am going to use a low pressure in tank fuel pump, a swirl pot and a weldon external pump (forgot the exact model number but ti supports my fuel requirements easily).
Old 10-14-2008, 07:48 PM   #740
Modrified
Modrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of light
glad to see this is still going. those ground plates are nice.
Modrified is offline
Old 10-14-2008, 08:33 PM   #741
firelizard
firelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond repute
[jeff bridges]CursedGTR built this in a CAVE.
With a box of SCRAPS![/jeff bridges]
Every post impresses me with the intricate details and attention to function and form.
firelizard is offline
Old 10-30-2008, 05:36 AM   #742
CursedGTR
Put the Front sway bar on (It is from a C34) and got the rotor caps back from the powder coater. The Sway Bars and the Rotor Caps were powder coated by Hot Modz here in Okinawa. Very decent work IMO.
The Front Sway bar is using ARC end links and they are a bit slanted to the rear right now. I have been told this should not be an issue but if it turns out to be an issue I will make necessary m odifications to get the right angle. I also picked up some JIC adjustable rear End Links and will get the rear sway bar installed with those in the next day or two. Everything is hand tight right now so I will position it correctly and tighten it all down when I have everything assembled.
I am working on putting the E-Brake in right now. Shitty thing is the fact that the dust shield is not big enough to accomodate the larger rear rotors so I drilled out the spot welds and removed the dust shields completely. Later on, whenI have time to reapproach this with the right tools I will look at making some custom dust shields but for now, I doubt this will have any adverse effects on anything at all.
I also finished up the front lighting harness and the requisite plugs and grounds, now I am working on the necessary chasis grounds for the grounding bar and the plug for the main harness to the Engine.
Anyways, Pics down below, should have something resembling a rolling chasis in the next few weeks.
Fan Wires Waiting for some fans
Old 10-30-2008, 08:30 AM   #743
ZilviaKid
ZilviaKid's Avatar
couldnt you just take a torch and hammer to the ends of that sway bar. Or have you even test fit the piece yet?
2006 Honda Ruckus - Fat & Low
ZilviaKid is offline
Old 10-30-2008, 08:38 AM   #744
TriniGT
TriniGT's Avatar
TriniGT is making a name for him/her selfTriniGT is making a name for him/her self
I would think putting a torch to it would ruin the tensile strength of the item making it more brittle and you really don't want an item breaking on you with the kinda of power going into this build.
TriniGT is offline
Old 10-30-2008, 10:08 AM   #745
silnismo
silnismo's Avatar
silnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enough
I don't think the slant in the link will be a problem at all. Sure, the slant will cause the the end link to pull on the Lower control arm at awkward angle, but you have upgraded control arms so i think it could take the punishment.
1996 s14-RIP
1990 s13-SOLD
1995 s14-SOLD
1994 E36-Daily
1998 DC2- F.S
Originally Posted by aNskY View Post
your idea of "doing it right" isn't the same as everyone else's... no matter how many kids on here swing from your nuts
silnismo is offline
Old 10-30-2008, 11:54 AM   #746
wow-thats-a-cool-car
wow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfection
Send a message via AIM to wow-thats-a-cool-car
have you dyno tested the motor or finnished putting it together?
wow-thats-a-cool-car is offline
Old 10-30-2008, 04:27 PM   #747
CursedGTR
It is mounted now and the only issue is the slant in the end link. To combat this if necessary I was most likely going to utilize an offset bracket that would mount to the lower control arm and allow the link to sit vertical.
Old 10-30-2008, 04:33 PM   #748
CursedGTR
The motor is finished for the most part, minus some peripheral items, but there is nowhere to engine dyno anything on Okinawa. JUN will do it but I hardly think it is worth the money to send it all the way up there and pay their fees along with shipping to get a baseline number.
I may get this thing to rolling chasis and quit for a while. I am most likely going back to the states in the spring so I will just use the time to get it ready to be shipped. Once in the U.S. I will reassemble it and most likely have a computer professionally installed and tuned in order to get an accurate number out of it.
Brian
Old 10-30-2008, 07:18 PM   #749
96Turbo
96Turbo's Avatar
huh? i'm confused.
by computer do u mean ECU/EMS computer?
if so, why would you need it professionally installed?
96Turbo is offline
Old 10-30-2008, 08:12 PM   #750
bardabe
bardabe's Avatar
wiring looks clean man, very good job. and that monster audio system should be ok with 2Ga wire lol looks really good keep it going.
Review Thread
bardabe is offline
Closed Thread
