Banned from the Marketplace
Is this normal?
I have a ka24de and have tried doing everything to get my idle down. Nothing seemed to work, but today I fabricated a bracket to pinch one of my air lines that goes to the intake manifold. Before my idle was at 1500 now I am able to adjust the idle as much as I please by turning the bolts. The current idle is at 900 rpm. Here is a picture, has anybody else had to do something similar to this?
#3 | |
![]() Join Date: May 2009
Why not find the real problem and fix it instead of make a band aid? Anyways this is pretty damn comical.
You should tell people to ditch their IACV's and buy your new bracket system, it'll sweep the market by storm!
#7 | ||
EDIT: I know you want help, but you know the issue you have why not post about how to fix the problem instead of post this thing.
#8 | |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
instead of throwing parts at the car...why not invest in a consult port link for $80 and plug into your car with a laptop... that plug is under your dash for a reason, just saying.
Trader Rating: (129)
Check the adjustment for the throttle stop, and the adjustment for the throttle cable itself.
#12 | |
Have you noticed a little something in all my posts? It may just fix your issue because in your long list of things you did not address the important one.
![]() Join Date: Jan 2009
Trader Rating: (25)
Just because you cleaned and replaced the gasket on the IACV doesn't mean it isn't bad. Buy a full KA intake manifold from someone for 20 bucks and take the iacv off.
#16 | |
You must have missed the stuff past the adjusting the idle part. Set your timing and look for vacuum leaks, betting that is what you have.
#17 |
#19 |
![]() Join Date: Oct 2009
Well here's a quick fix, how about you check the resistance on you IACV first. Find one of the FSMs online which are free, get a voltmeter and measure the resistance. If the resistance is out of spec, then replace with either a used or new one. Although if you do end up buying used, check the resistance first to make sure its good. Then install.
#23 | |
Sent from my SPH-L720 using Tapatalk |
#24 |
![]() Join Date: Mar 2008
You should get a turbonetics manual boost controller inline with the IACV to adjust your idle lmao
but seriously, there's a way to properly adjust the idle. Unplug the plugs near the TB there should be two. Start the car and let the idle stablelize after the engine is warmed up. Turn the adjustment screw on the IACV-this should be near the back of the intake manifold. Plug in the plugs and it should be lower. |
#26 | ||
| air, idle, intake, problem |
